Here's a tough question for ya. 😉
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I recently acquired a set of XTR M952 brifters, which are the first ones marked for Mega 9, rather than 8-speed. These were gunked up with old grease when I got them, and still are, lol, because I haven't cleaned them just yet.
Now on to the pertinent question. The left shifter, for the chainrings, is supposed to be for either 2 or 3 rings, adjustable I think. 🤔 How do you change that? It's probably incredibly simple, but I'm not seeing it in a search, and would prefer NOT to screw something up, by experimenting. 🙄😉
BTW, it feels like it's set for 2 rings now, and I want to use 3, hence this thread. I still need to clean, like I say, and I'd just feel better, knowing how things are "supposed" to sit, clean or dirty. 😉
Thanks. 🙂
Thanks. 🙂
Quoted: 101 Post(s)
Liked 49 Times
https://si.shimano.com/#/
There are several levels of manuals there, the Dealer's Manuals are pretty comprehensive.
Likes For Ronsonic:
Quoted: 1438 Post(s)
Liked 1,092 Times
First rule of troubleshooting is to fix what you know is wrong. I would suggest cleaning it up and lubricating it first, it may start shifting to 3 positions when everything is moving freely.
Edit: if there are 2 "clicks" the shifter is set up for 3 rings already.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
I might be getting old & senile, I "usedta" search pretty good. 🙄😉
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
BTW, not trying to sound like a commercial, but I used a spray called White Lightning 2 in 1, which is a degreaser and lube, combined. 🙂
Quoted: 1572 Post(s)
Liked 643 Times
I used to own a 9-speed Ultra equipped road bike and a 9-speed Ultra equipped tandem. The road bike had 2 chainrings and the tandem had 3 but they both used the same model Ultegra brifter with 4 shifting detents. On my double equipped road bike I had 2 shifting positions for each chainring. On the triple equipped tandem I had one shifting position on the granny, two on the middle ring and one for the big ring. Maybe that's hows your XTR shifter works too.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
These XTRs just started working well, as soon as I shot that cleaner inside them. I mean in about a minute. 👍 I think someone else described that gunk inside, as being like hardened glue, and that's pretty accurate. Probably most degreasers would work well enough, but that's what's needed, alright. 🙂
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Glad it worked out, but I have one request: make your thread subject more specific. Not doing so forces people who may have no interest or relevant knowledge to open your post and read it. Not to be too pointed, but its disrespectful of other's time.
Brifter mechanicals seem to be very similar to what is inside an ordinary rachet (socket) wrench to me. Not much to them. I pull the rubber hoods off. Soak them in a container of diesel fuel. Put on nitrile gloves & manually work them up & down and all around. Drain & dry. Replace the hoods. Bolt onto handlebars. Install new cables. Good as new! BAM!!!! Lets go riding.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
Turns out you were right, cleaning fixed them right up. 👍 I kinda hoped & expected it would, but was trying to cover all the possibilities. I had a weird feeling, that there was a little switch or button somewhere, to change from 2-speed to 3-speed. 🤔😉
Jeff Wills
Jeff Wills
Quoted: 453 Post(s)
Liked 104 Times
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
I'm not stuck on using this spray lube, either, it's just what I found first, that seems to work reasonably well. 😉
And for the rude comment dude, get over yourself. Nobody made you read this thread. 🙄
