Is there a difference between Shimano brake cables and shift cables?
I replaced my shifter cables with new Jagwire Stainless Steel cables and was planning on changing my brake cables as well. A buddy told me they are different cables. True? if so, what cable is recommended. When shopping on Amazon and Ebay I saw no real differences???
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
The direct answer to your question is, "yes, there is a difference between Shimano brake cables and shift cables." There's a difference between brake and shift cables regardless of brand -- brake cables are typically thicker (1.2mm rings a bell to me) and have different cable ends than shift cables, which are usually thinner (1.0mm?).
Many people use the multi-packs you can get on Amazon and eBay, many people use only high-end stainless cables, and many people prefer to trust the quality of whatever the local bike shop carries (which is usuallly Jagwire). Most bike shops carry both standard and stainless varieties, so you usually have a few choices there.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Not sure I understand your question. Are you asking if shift and brake cables are different? If so I don't understand how anyone could not see that they are in fact very different.
Well, I haven't had the brake cables out to inspect them and have not done this before. The shift cable replacements were easy enough. I just didn't know the brake cables were different. Thanks for the confirmation and now I need to order the correct configuration to replace my brake cables.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Don, also be aware that Shimano compatible road bike brake cables and mountain bike/hybrid brake cables use different ends.
Based on your profile, you own both kinds.
Likes For rccardr:
Quoted: 6196 Post(s)
Liked 4,811 Times
I think that on the very old bikes of the 70's that the cables were about the same diameter if not the same. But the terminus or whatever the proper word is for the thing on the end of the cable was different depending on whether it was to fit in a shifter or a brake lever.
When indexed shifting came along and particularly with STI's and their cousins, the shift cables got even narrower in diameter.
I might be speaking nonsense, someone else should double check what I'm spouting from just off the top of my head. <grin>
Quoted: 839 Post(s)
Liked 1,064 Times
I would also recommend using the Jagwire Brake Housing from their top tier group as they are much less prone to compression sponginess. You'll notice a difference when switching from Shimano and others that the brakes will feel firmer and easier to modulate. Also, Shimano uses a 1.2mm shift cable and Jagwire plus some others use a 1.1mm. I've used both cables in JW or Shim housing and no issues so basically interchangeable.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,999 Times
Yes they are very different.
If I were buying new stuff I would go with Jagwire Elite Link kits for both brakes and shifters or at least the Pro Level and I would make sure I am getting the right stuff. Luckily your local shop can help you out both with getting the parts (if they don't already have them) and also with install. Buy local Billionaire Jeff Bezos does not need any more of your money, he is plenty rich without it plus he is useless when it comes to bike queries or fixing anything.
Always buy the best slick stainless (and ideally polished) cables and the highest quality housing for your bike as it will improve things quite a bit without costing a whole lot.
Likes For veganbikes:
Quoted: 1438 Post(s)
Liked 1,092 Times
The inner cables are different and, crucially, the housings are of very different construction, shift housing being substantially weaker. Never use shift cable or housing for brake systems, ever.
Quoted: 114 Post(s)
Liked 119 Times
Just to add an illustration to the above info, here are end differences in the cables (note, don't pay too much attention to the cable lengths shown in the bottom right. Most likely the cable you buy will be sufficiently long and you just cut to fit). You can get road or mountain specific brake cables, or you can buy universal brake cable that has the road (mushroom) and the mountain (barrel) configuration on each end and you cut off what you don't need.
Likes For MudPie:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Liked 4,811 Times
At the time I did this back circa 2010, there was a site talking about how the diameters changed over the progression from down tube friction shifters and just 5 speeds on the rear to more modern indexed shifting with more speeds on the rear.
Of course now that I need some backup I can't find the site or article I thought I'd read. So it's not a big worry one way or the other for me.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
If it's of any help, I wrote in some detail about the shifter, brake cable, and housing standards - with pics and all.
Liked 762 Times
It's clear that I was off with my thickness recollection above. I appreciate the resources listed giving the correct info!
Likes For hokiefyd:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Well, I switched to the linked housing from the cheap TRLREQ brand and it is the same for brake and shift cables and superior, mostly vastly, in other ways. Actuation is more precise, tight turns are possible, no housing ends are needed, the links are reusable and color combinations can be used to mark individual cable runs.
Quoted: 1562 Post(s)
Liked 1,734 Times
BTW unless you have a problem with yuor cables rusting, stainless cables are not better than galvanized cables. Galvanized cables are self lubricating and less brittle.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Likes For tcs:
Liked 4,811 Times
Since the bike was just acquired by me in 2010 it's probably very likely the cables weren't original to the bike made in 1978. Perhaps this better explains why they seemed the same size.
Bikes: lots
Liked 2,932 Times
Please provide a link to this as I've never heard of it. The cable diameter is different, 1.6mm for brake and 1.1-1.2mm for shift. Explain how this would work. There are 'universal' brake cables that are mountain on one end and road on the other, and shift cables that are Campy on one end and Shimano/SRAM on the other...but a cable that doubles as both shift and brake? I doubt it.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
This, and the size (1.2mm shfit vs 1.5mm for brakes) and the cable ends are different.
Palmer
Liked 1,826 Times
In the 10-speed, friction shift, single pivot brake, pre-mountain bike era, things were more forgiving. As were people.
Liked 4,811 Times
You might also have to explain that 40 years ago, 10 speed was 5 on the rear times the 2 on the front.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Well that's interesting. I wasn't aware of that or if I was then old age and dementia have addled my mind. <grin>
