Suggestions for 135mm QR Rim Brake Hubs
Old 03-26-24, 02:51 PM
Yan
Yan's Avatar
Quoted: 1965 Post(s)
Liked 647 Times in 443 Posts
It's hard to find 135mm QR rear hubs for rim brake. Any other suggestions beside the below 3 that I'm aware of? And any with SRAM XD driver option?
Novatec F162SB/AA-11S
https://www.ridewill.com/p/en/novate...-qr135/557660/
Shimano FH-T610
https://www.bike-components.de/en/Sh...H-T610-p36005/
Velo Orange (expensive)
https://velo-orange.com/collections/hubs/products/rear-cassette-hub-silver-and-noir
_
To be paired with a DT Swiss R460 rim:
https://www.bike24.com/p2123285.html
I could also use a disc brake hub and just not install a disc, but it would look odd.
Yan is offline
Old 03-26-24, 03:27 PM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
Shimano seems to have multiple offerings, buy it seems that high end stuff is all disc brake.
No surprise, since high end rim brake is on the endangered species list.
OTOH you might check for 130mm hubs that might be convertible to 135. Likewise, USA makers with the right shell might offerv135mm as a special order.
FB
Chain-L site
FBinNY is online now
Old 03-26-24, 04:09 PM
KCT1986
Quoted: 346 Post(s)
Liked 320 Times in 234 Posts
Shimano FH-T610
_
Another consideration is what cassette you are considering. The Novatec and the VO seems to be 11 speed length freehub bodies and the Shimano 8/9/10 length. The Shimano will take a Shimano 11 speed MTB and a couple of 11 speed road cassettes.
The 11 speed length freehub bodies usually means that the wheel will have a larger dish (more left/right imbalance), and/or narrower flange spacing (less bracing angle).
A hub with 135mm OLD and disc brake mounts will usually have narrower flange spacing.
Things to consider if wheel strength is really important.
KCT1986 is offline
Old 03-26-24, 04:29 PM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,292 Times in 744 Posts
Shimano FH-T610
_
Another expensive option. https://www.rivbike.com/products/hub...=8645336203375
phughes is offline
Old 03-26-24, 05:27 PM
bboy314
bboy314's Avatar
Quoted: 332 Post(s)
Liked 744 Times in 386 Posts
Suzue Classica road hubs can be converted from 130 to 135. In case you needed another expensive option.
bboy314 is online now
Old 03-26-24, 08:53 PM
nick_a
Am-a-tour
Bikes: 2020 New Albion Privateer, 1983 Schwinn Super Sport, 2022 Rivendell Atlantis
Quoted: 44 Post(s)
Liked 65 Times in 40 Posts
There are a number of late 90s-early 00s Shimano hubs out there that fit the bill.
nick_a is offline
Old 03-27-24, 04:15 AM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 442 Times in 315 Posts
Look for new old stock mountain bike hubs if you are ok with 10 speed cassette and don’t need 11 speed. WTB Momentum is one brand that pops up occasionally at decent prices and seems to be good quality. Velo Orange has their 135mm hub (comes with different end cap to run 130mm too) on sale if you keep an eye open for sales. I bought one for $75 and had a touring wheelset built using this for the rear.
masi61 is offline
