Calling all Nitto Front Rack Experts - advice needed
Bikes: 1983 Trek 600, 1973 Mercian
I have a Nitto M18 mounted on my 83 Trek 600 to hold a small handlebar bag.
It is a small frame, 21'', and the rack without anything bent looks like this:
I just received a very nice small Swift Industries Ozette bag; when I try to mount the loop around the tombstone I can get it on but it is a bit awkward. Ideally the front rack would be a bit lower and more forward, but I am at the end of the forward adjustment on the tang that mounts to the brake bolt. I don't really want to mess with the stem height as my position is comfortable now.
Any ideas? I'm also thinking of what decaleur would work best, as the VO one looks like it will be too low.
Thanks!
Thanks!
Unimatrix Zero
Quoted: 7 Post(s)
Thanks!
Thanks!
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
Can you flip the mounting tang and run it under the brake?
Also, what front light do you have mounted there?
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
The light is an iq cyo senso.
Thanks folks. And keep the ideas coming!
Quoted: 1871 Post(s)
Liked 670 Times
REALLy nice Trek frame, it looks like original paint and decals?
Yu can also tilt the front of the rack down by loosening the daruma bolts that clamp the struts and sliding the struts up a little. That will lower the rack and tilt the tombstone forward, perhaps just enough to make your bag fit easier.
Of course, clumsy stupid me managed to bugger up the stupid $15 daruma eye bolt that my light was mounted to with the Boulder Bicycles' light mount and also sever the wire connection coming from the Cyo -- I managed to do some MacGyver splicing of the wires with electric tape but will have to look up the proper way.
The Trek is indeed original paint and decals -- it looked like it was hardly ridden when I scored it off of CL, and all the internal bits were well greased.
Have you considered using long stays connected to the eyelets at the fork end? That's how I mounted my Nitto Mark's Rack (similar to M18?) and it allowed me to get the rack perfectly level and in the right position. Of course, I have a bit more headtube height than yours so that make bag clearances a little easier. You need to use a stack of small lock washers at the lower connection so the stay clears the fork blades. It gets really interesting when you add fenders
I don't know much about the bag you're using. This set up works good with my Acorn Bag.
I'll echo that's a fine looking Trek. Cheers!
^Thanks. Your Nishiki is gorgeous and one of the inspirations for my build. I will likely order some of the longer struts and give it a shot.
