Hill Climbing: Cadence and Power?
Hi, I've had some questions about hill climbing that I've never had unanswered. I've looked online but it still needs clearing up. On hills I'm told to maintain a steady cadence, 80-100 rpm, but I can achieve this cadence in multiple ways - pedaling very hard in a higher gear to bring my cadence up to that range (more anaerobic) or going into an easier gear and spinning, with less effort (aerobic). Which way is preferred, or do they each have their own specific situations?
i'm just beginning to learn about this topic myself
check this out~
https://www.bikeforums.net/showthread...e-for-a-newbie
check this out~
Which way that is preferred depends on how fast you want to get up the hill, and how long you can sustain the pace. The faster you go up the hill, regardless of your cadence or gearing, the more anaerobic you will be.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
This. It's simple physics. If you want to haul 150lb up a steep hill, you need more power to do it fast rather than slow. If you can ride up a steep hill in the big ring at a cadence of over eighty rpm for more than a minute or two, do it. Most of us can't, which is what lower gears are for.
Quoted: 660 Post(s)
Liked 601 Times
It's quite simple really. How much do you want to have left over at the top and can you recover to finish your ride when cresting? If you are on a double century you might not want to attack hills but rather let them come at you as they are.
SpeedFreak
Bikes: Motobecane Le Champ Ti
I may add that it also depends a great deal on your fitness level. I know some riders who are strong in the flats and can maintain 18+ mph for long periods by themselves, but then just die in the hills. OTOH, I know some riders who are great climbers but has a hard time maintaining 18+ mph by themselves in the flats. It's puzzling to me.
In general, on long hills the ideal is to maintain a 70-85 RPM cadence all the way up it. Nevermind the gear, just pick one that will allow you to do that cadence for the whole climb. On short hills, you can probably just stand and attack to quickly get over it, as long as you don't burn out doing that. Having said that, you fitness level will dictate if it's possible. If you are not able to do the above and find yourself just surviving a long climb at 60 RPM at 5-6 mph, then you need to work on climbing more hills.
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
on a road near you...
Maybe you just don't know any strong riders then.
Strong riders go 18mph on 4% hills ... I know I do ... and I'm not even a really strong rider.
OP: Definately try to keep enough cadence ... don't jerk the pedals straining your muscles.
If you keep a good cadence you can use more of your aerobic power and hopefully won't have to use up too much of the anaerobic.
You shouldn't think about how to reach this cadence though ... you should already be in it at the bottom of the hill
Do you really consider someone managing only 18mph in the flats to be a strong rider?
AdelaaR is exactly right. You TRY to keep your cadence and shift as you need to. To make progress your goal is to keep leg tension to a minimum cadence (I go for about 70RPM), shift down (check cadence) etc. Also keep leg tension until you are fully done climbing otherwise you'll lose any forward momentum and will need to fight the wind just to get back to where you should've been in the first place. This is key in keeping your cadence high enough as well, I usually see my cadence pump to 100RPM after cresting (TT speed I like to think) and push it to a nice cruising speed/leg tension.
Bikes: Trek FX 7.2
My personal take is that I really want to improve on climbing and I find that this occurs when I take a lower cadence and use more anaerobic power. Yes it does drain you a bit but that's the only way the body will improve. Spinning up a hill makes sense if your goal is to preserve energy but it's going to do a lot less for improvement purposes.
Alright, well now-on steeper hills, I can shift down and down and down, maintaining an 80rpm cadence, not straining myself much, but by then I'm only crawling along at 7mph. What if I want to take the hill faster-do I stay in the same gear and INCREASE cadence to around 100-120, or use a higher gear that forces me to pedal harder to maintain that 80rpm cadence?
yes? You can do either. There is no one accepted way of climbing. Many people will alternate between high and low cadence on a long climb.
Despite all my rage, I am
Bikes: LeMond Zurich, Colnago C-50
Going up it as fast as you can is the way to improve. The "should I spin, or should I mash" question is really irrelevant - go as fast as you can.
Bikes: Sab, Diamondback MB, Kawasiki MB, Huffy hybrid fixed gear junk yard build, Huffy cruiser motorized.
Being a bit on the large size pedal, push or pull until i get up the hill. watching others i see some cranking hard others spinning away. Seem to me you just want to hammer away until you get it done.
https://tickers.TickerFactory.com/ezt...W08/weight.png[/img]
[/url]
[/url]
Bikes: 2010 FUJI SL-1 Comp
What is the maximum distance you can sustain this rate? I'm just curious. I wouldn't consider myself strong at all, but anything over 3% and longer than a mile and I'm usually in the lowest gear tooling along at 8mph.
Bikes: Trek 1200
The whole point of shifting into lower gears and into higher cadence when climbing is so you shift some work over to your cardiovascular system...If you mash on high gears in order to get higher cadence you are going to incur oxygen debt/blow past your lactate threshold a lot faster, resulting in the onset of muscle fatigue sooner. This doesn't mean you are using less energy, its just you lower your power output per rotation, flex ALL muscles for a complete rotation more often, therefore use up more oxygen from your bloodstream, and shifting work over to your cardiovascular system.
Now its perfectly fine to use lower cadence/higher gears for climbs for training (e.g. hill repeats) to increase your LT...But I wouldn't do that for say, on a century...I just recently learned this at my LBS, and it works well for me. I've started doing hill repeats for 2 weeks now, and in conjunction with high cadence climbing, I've noticed huge increases in my climbing ability. YMMV of course.
Hope this makes sense.
If you hammer it as fast as you can on the first half, you won't have any energy left for the second half and you'll be slower in the end ... or not finish at all.
The hardest part in cycling is finding the right intensity.
Around 5 minutes or a bit more. That may sound silly to people doing huge mountains but there aren't any longer hills around here
SpeedFreak
Oh of course. You go 18 mph on hills because you are a superstrong rider and nobody can keep up with you except the pros.
SpeedFreak
Quite long. Never really measured it exactly and hills around here tend not to go exactly the same grade for long stretches so it's hard to say.
There aren't any actual mountains around here and so after max 5 minutes of ascending there is always a descent.
