Tire Width--At My Limit?
Quoted: 67 Post(s)
Liked 50 Times
I am riding more on gravel these days, so I have tried to increase my tire width for more comfort. I went up to 28mm on my Panasonic Team Japan, and while the ride is good, I'm was hoping for a little better.
I was wondering about going up to 30mm, but I may already be at my limit. I've attached photos of the current brake clearance. Could I go to 30mm here?
Quoted: 3467 Post(s)
Liked 2,843 Times
I would be confirming wheel dish and fork alignment.
I would not attempt a bigger tire.
Likes For repechage:
Quoted: 574 Post(s)
Liked 618 Times
I have read there is an ISO ( Internal Organization for Standardization ) standard of 6mm, I see lots of 4mm on frames/forks/brakes and in my retirement community where the roads are kept clean I can get away with slightly less but no way in gravel/wet.
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 771 Post(s)
Liked 1,640 Times
I think I'm more OK with running things close to the clearance limit than perhaps most people, and that's about as tight as I'd go. You could take some measurements and see how much clearance a 650b conversion would get you, but that'd involve new wheels/tires/brakes. Or use this as an excuse to get another bike that can run fatter tires for gravel rides!
Likes For ehcoplex:
Likes For Hondo6:
Quoted: 3850 Post(s)
Liked 6,936 Times
I suggest getting some calipers on those tires to measure actual width. You might already be over 28mm.
Quoted: 939 Post(s)
Liked 1,355 Times
I'd say that both front and rear wheels do not appear to be centered. Something's bent and/or the wheel dish is way off. Also note that the clearance shown is as low as I would go. Furthermore, I've found that the tire width limiting factor is usually clearance at the chain stays, not the brakes.
Likes For davester:
Quoted: 67 Post(s)
Liked 50 Times
don't try this at home.
Quoted: 989 Post(s)
Liked 536 Times
So, I'd want a lot more clearance for gravel road riding than for riding on paved roads.
Likes For rm -rf:
Quoted: 5920 Post(s)
Liked 3,587 Times
I'd be thinking about a 650b conversion assuming that this measures out OK for that conversion or a different bike with more generous tire clearance. Finding a vintage bike that can take a 35c tire isn't hard; it's a little harder to find one with 38c clearance if we're talking about road bikes. If you really want an all roads bike, an old school mountain bike or hybrid can work well. I did a drop bar conversion on a 90s Specialized Stumpjumper for gravel riding and I'm running 26 x 1.95 tires on it.
feros ferio
Quoted: 1406 Post(s)
Liked 1,364 Times
That sounds like my Bianchi. Works fine with Continental 700Cx28s, which run a bit small, but I could never use Specialized or other 700Cx28s that run large. That was the one big advantage my same-vintage Peugeot PKN-10 had -- larger tire clearance.
Quoted: 1175 Post(s)
Liked 454 Times
Which rims do you have the 28’s mounted on? I haven’t made actual measurements with wider tubeless type modern rims But I’m thinking you might eke out a bit more width with something with more internal width like a HED Belgium +, a Pacenti Brevet or a Velocity Quill. My theory is that a 28 would fit more like a low profile car tire and possibly ride a few mm lower.
The older standard Mavic Open Pro type aluminum clincher rims are like 14mm internal width which leads to the “lightbulb” tire profile with certain wider clincher tires.
It appears from the photos that you have adequate side clearance for a bit more tire width, it is the height under the brake caliper that is the limiting factor.
Quoted: 67 Post(s)
Liked 50 Times
