What's the best way to do force training?
SkinnyStrong
I've been working on force by doing Force Reps (as Friel describes them) once per week. My only problem is that I don't feel like they're doing anything because I don't feel sore the next day or like I even did anything hard at all.
This morning, I went out and did 5 sets of 4 reps on a steep hill nearby (ea. rep is 12 revolutions of the crank at max power with cadence around 50rpm). 2 min rest between intervals, 4 min rest between sets. It took about a 1.5 hours and started to get boring towards the end.
I'd appreciate any insight you guys may have regarding building force. Is this the right route? Would weight training be a better use of time? What about going longer with a slightly higher cadence?
starting pistol means war
Bikes: Cervelo R3
What's the purpose? Are you training for the velodrome?
I see no reason for stomps, or Force Reps or whatever else coaches may throw out there.
Going uphill on a gear a bit too big is good enough for a road/crit racer
SkinnyStrong
I want to increase my jump and sprint power. I tend to get dropped on the short steep climbs but I catch up the longer climbs or if the climb is late in a race. Makes sense, as I spent virtually all of my training time last year working on FTP and endurance. Also, crits are so common around here that my lack of power is also a limiter in the in the races most available to me.
Bikes: 2012 Parlee Z5
Whenever I've done specific force training it's been 3 min at VO2 max power around 50 rpms. Do a couple of those and it really hurts.
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 43 Times
I disagree. Having a good "jump" (but not so good that it can be the winning sprint) gets a gap if you are in a crowd that is alert on the road. If you can then follow it up with "the $h1t" it can be a winning move. This can be a winning strategy for those that don't possess the classical sprinter's abilities.
EDIT:
Originally Posted by friel's blog
I have riders do 1 to 3 sets of 3 reps each. That means a total of 3 to 9 reps within a workout. ...
https://www.joefrielsblog.com/2010/11/force-reps.html
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
SkinnyStrong
When doing squats I usually only take 2 minutes rest in between sets, at most. That's pretty normal for gym workouts, right? I figured it should be the same on the bike. The reason I did 20 sets is because the last time I did this I did 3 sets of 3 reps like Friel proposed and I felt like that wasn't enough work.
Interestingly, in his book he doesn't make any mention of Force Reps, just hill climbs.
Like I said though, if the workout isn't hard, then make it harder. The whole point of "force training" is you do them with enough explosive power that 3-9 reps feels like a day. Believe you me, it is a different mindset than most roadie workouts. It was something I had to get over when I switched from a road racing/cross team to a track team towards the end of last season. It was like I wasn't getting my money's worth with a ride where we go back and forth on a 1/2 mile stretch of flat road with a big hump in it for an hour. The solution is to get out of the "money's worth" mindset and start sprinting harder.
Bikes: Cervelo S1
Something i noticed above, if you are doing this on a 14% grade, it might be too steep to achieve some spin up. If you do these on a 6-8% grade. Get into a 53/14 gear, slow to a crawl, then go to max effort for 12 revolutions.. you might get to 50rpm +/-. If done correctly, you should feel this in your legs, arms and across the shoulders.
Does Not Exist
If you are getting dropped on steep climbs, it is not strictly a force issue. Those climbs ask a lot of your anaerobic energy systems. If you can find a climb of the same length and steepness that you tend to get dropped on, do hill repeats on it almost as hard as you can, with long recoveries in between efforts.
Must Go Faster
Bikes: Trek Madone 5.9, BMC Road Racer SL01, Orbea Aletta TT
One speed: FAST !
Bikes: Ebay Bikes... =)
this.
peak power is very low compared to a "sprinter" ... thus, I attack early = win!
