My first Colnago
Using just aluminum foil I've managed to remove quite a bit of rust already (see below). These photos are not "photoshopped". The problem I'm having is the small crevices of the letters. The foil does not reach into them. I was planning on buying some vinegar today and putting a few drops over the letters and letting stand for a bit to see how that works unless somebody here has a better idea.
PS - I have sent Laura my "serial number" to see if she can provide some history on frame. More info to come as it becomes available.
The mystery thinkens....
Response from Laura.
Hello Ron,
this should be a Super of mid 70ies
Unfortunately we don't have records of serial numbers of 70ies/80ies frames
Best regards
Laura
Hello Ron,
Best regards
Laura
Parolini Laura
e-mail: laura@colnago.com
Tel.: +39 02 95308082
Fax: +39 02 95067379
Sky.pe: parolina3Web: www.colnago.com
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I am not sure what you are implying...I have seen many chrome parts that were scratched by using steel wool no matter the grade. Maybe the plater that does the restos on my cars is also incorrect but he never recommends steel wool to "clean" chrome...steel wool will clean the rust but I have seen it leave micro scratches that the "lessen" the shine on the chrome plating.
The chrome plating is applied over the nickel and perhaps that is what is scratched.
Others may use steel wool but it's not my go to.
The Colnago fork that you cleaned certainly removed the rust but the rust had already destroyed the chrome..it does, however, look acceptable.
TETO, Ben
Voltaire
Voltaire
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
More frame dating info
Here's a link to Ray Dobbins website showing a Colnago catalog from the late 70's - 1978-1980?
https://www.raydobbins.com/misc/Colna...go_catalog.htm
Ray is a well known authority on C&V bikes - nice eye candy: Ray Dobbins Bike Photo Gallery
He mentioned was that Colnago started stamping their name in the chain stays and chrome plated the right side in 1981 plus they switched to braze-on front derailleur mounts in 1982. The also went to the full slopping crown on the Super around 1982
My 1983 Super:
1983 Colnago Super catalog page. This shows straight seat stays with fluted plugs with Colnago cast in. I've seen very few pictures bikes with those style plugs. That was most likely a transitional change. Most from Colnagos from that era have bi-conical stays and flat plugs with Colnago cast in like my bike.
A few last comments, Colnago was known farm out frames to other builders when they were busy so that accounts for some variation in specs. Also, there were no rules demanding adherence to any specifications. A lot of frames were built to order:
"Le specifiche sono soggette a modifiche senza preavviso"
Without stripping the paint, there's no telling what changes CycleArt made to the frame (or repairs)! They did good work but took liberties. I've heard tell that they never wanted to reproduce exact features so they added their touches to the frames.
I bought my Colnago to ride and enjoy rather than a work of art. I like that is has a few warts. If it were concours, I wouldn't ride it for fear of getting dirty or scratched up.
After a few rides, if you like it, most of the flaws will disappear, especially once you get some shiny bling on it.
Enjoy. I'd like to find another Nag in that color.
verktyg
My 1983 Super:
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,238 Times
Hardness of Chrome plating
HUH**********
TETO, Ben
TETO, Ben
Chrome is primarily used as an alloy in other metals, in abrasives, pigments, as a catalyst, and for electroplating. The red color of synthetic rubies is due to chrome. Many yellow, red and green pigments contain chrome and so on.
Chrome plating is softer than the 80rc hardness of chrome itself because of the nickel underplating. The thicker the nickel (and copper) and the thinner the chrome plating, the softer the surface will be.
I'm not sure why your plater said not to use steel wool but I suspect the the chrome layer he does is very thin and can be easily abraded away.
When I was in Japan in the mid 60's chrome plating was dirt cheap. We got everything made of steel on our motorcycles chrome plated plus lots of other things. The problem was they used very little nickel or copper plating under the chrome layer which was very thin so after a short time the stuff would rust badly!
Much of the chrome plating on my Colnago Technos fork has been polished away and the nickel shows through the surface (I got it that way). Nickel appears slightly yellowish compared to the bright blue white of chrome plating.
XX or XXX steel wool should not damage quality chrome plating, even heavy anodized aluminum.
"The Colnago fork that you cleaned certainly removed the rust but the rust had already destroyed the chrome..it does, however, look acceptable." I Photoshopped the picture, it looks pretty bad up close.
Oh, BTW, the reason why aluminum foil works is there is a thin layer of aluminum oxide which forms on the surface. Aluminum oxide is abrasive and acts as polish. If you expose pure virgin aluminum to the atmosphere it will immediately start to oxidize which forms a protective layer that slows down surface corrosion.
verktyg
Chas. ;-)
Chas. ;-)
While we're on the topic, what are some opinions on painting the clover/logo? I've tried outlining lugs on other frames myself and wish I hadn't afterwards. Seems like a decent job requires a professional hand. Has anybody done it themselves?
Liked 2,181 Times
verktyg [/QUOTE]
VK,
You are correct if the chrome layer is thin this could cause scratching and since the thickness of the plating can vary widely, I stay away from steel wool for polishing chrome...since there is already rust to me it would suggest that the plating was weak and abrasion could cause scratching
Best, Ben
VK,
Best, Ben
Voltaire
Voltaire
Hear, Hear
verktyg
Liked 1,238 Times
Laura and serail number dates
I see a Colnago frame.... It's getting clearer now.... It's from the 1970's or 80's....
1981 seems about right but there were so many variations that it's hard to tell for sure.
I found a flat top crown Colnago fork in the UK, just like on your bike. I like them so much better than the newer full slopping ones. Not sure why I never switched???
Encountered my first Colnago in 1973. It was orange with a light blue panel on the down tube and Eddy Merckx picture decals on the head and seat tubes. Never saw another one like it but it was a real Colnago with the logo paragraphed in the chrome fork crown. One of the guys who worked at a shop a few blocks from ours owned it. He let me ride it a few times. Even offered to sell it to me but it was out of my league at the time (his too).
I finally got my grail bike in 1978. I bought an orange frame and a blue one like yours. I couldn't decide which one I wanted. Finally picked the orange one and hung the blue one up for sale.
It got stolen in SF in 1981. For years I looked for another orange one in my size. Got away from road bikes for about 25 years. When I got back to riding on the road in 2006 I started shopping for the grail again. I found my 1983 red frame instead and it was so nice that I couldn't resist.
BTW, great job on cleaning up the forks!
verktyg
Chas. ;-)
Chas. ;-)
Before and After...
Before and after of fork crown only. Lugs and paint still need touch-up and headset will be swapped for Campy Record Headset.
Quoted: 2588 Post(s)
Liked 4,824 Times
That looks great! You know, looking back at the pics in the first post, the rust didn't really look too bad - not to the point of pitting and/or flaking, so your result isn't too surprising.
DD
DD
I think the frame itself is circa 81, 82, quite possibly a Superissimo, which would explain the chromed head lugs.
The fork to me looks like an earlier '78-ish model.
This might also explain the respray.
Nice call! I've found multiple photos of 1982/83 Superissimos which aside from the 2nd set of cage mounts match mine exactly (ie. chrome lugs, flat fork crown, flat seat stay caps, painted DS chain stay and underneath bb cable routing).
Links:
https://forums.thepaceline.net/showthread.php?t=127574
https://thecabe.com/forum/threads/19...issimo.115440/
https://www.******.com/r/Bikeporn/co...2_saronnipr82/
https://www.bikeforums.net/classic-v...perissimo.html
Links:
Bikes: '83 (?) Colnago Super, Campy equiped, needs restoration, '90s Trek 8700
Quoted: 7 Post(s)
My Colnago has a mixture of the features of '81 to '83 dated frames. It has the fluted seat stay plugs with "Colnago" cast in, Chromed right chain stay with "Colnago", no front derailleur braze on, sloped crowned all chrome fork, chromed frame lugs on the steering tube only. The black anodized 3T stem is engraved with "Colnago" along the sides and the "club" on the front. The original non aero brake levers were drilled out and a "C" encompassing the "club" engraved on the front of the brake lever just below the hoods. The Colnago decal on the frame was just yellow letters without the white background.
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
Back in the 80's and 90's I was quite good friends with a local Australian bikeshop owner who imported a few brands of Italian bikes for sale in his family's bikeshop such as Pinarello and Colnago. His family had been in the bikeshop business since the 1930's both building and selling bikes. His main Italian frames were Colnago and he travelled to Italy each year to deal directly with each manufacturer. At times he dealt directly with Ernesto Colnago and Giovanni Pinarello through interpreters but mainly with other company executives.
In the very early 90's I recall a conversation I had with this bikeshop owner regarding Colnago's. I vividly remember asking him about the chromed features on Colnago frames and whether the amount and location of chrome on a frame meant anything? He told me that it didn't matter what the frame was, he could order any model with chrome in any position on a frame he desired. The Colnago factory could deliver his requirements. He didn't really expand on that statement only to say that the chrome really didn't indicate the model of frame it was featured on. (I guess his ordering would be based on models with the same frame finish to make it viable for the factory to produce.)
I know Superissimo's of that era have chromed head tube lugs but other frame models could be ordered with the head tube lugs chromed as well. I do have a mid-eighties Superissimo (SLX tubing) that doesn't have any chrome on it but it has been re-painted.
I'd be guessing that 1983 would be a good place to start investigating the build year for your bike. I think 1984 is too late for what you describe - but who really knows?
Quoted: 7 Post(s)
Thanks for the info Gary, I bought the bike new in either '82 or '83, probably the later.
Quoted: 179 Post(s)
Liked 198 Times
I've had heaps of great bikes over the last 50 odd years but only one new bike - a Colnago (frame only). I still have it and it's really special to me. I can only imaging your connection to your Colnago.
Quoted: 7 Post(s)
No pic on file yet of my Colnago. It really needs some attention, chromed fork is badly rusted but the rest of the bike is in fairly good condition. Unfortunately, the original brake levers are no longer on the bike, swapped out for aeros long ago and one of the originals is not to be found. I will try to clean it up and post a picture later.
Quoted: 1608 Post(s)
Liked 2,216 Times
Interesting thread all! I dated my Colnago from the rear RD, 1983. More often that not I am thinking it is either '83 or '84.
I know it is a Superissimo as one of the labels/decals survived.
P9161245, on Flickr
It has flat ST caps
P1000527, on Flickr
Chrome fork, head tube and lugs, CS only (paint chips near the stamping shows chrome).
Low Gear, on Flickr
Stamped "Colnago" in the CS's
P1000536, on Flickr
Original paint and decals.
1983 Colnago Superissimo, on Flickr
P9161245, on Flickr
It has flat ST caps
P1000527, on Flickr
Low Gear, on Flickr
P1000536, on Flickr
Liked 2,216 Times
@tarsi - That was the limit for this configuration. I could only use the large sprocket with the small ring! It worked well while I got into shape!. I don't ride this bike as much since this picture. IRD freewheel, BTW. Now sports a Regina with much smaller large sprocket.
Thanks for the comment too!. It looks pretty good from 30 feet!
Quoted: 7 Post(s)
Photo before any clean up, needs a lot of TLC! Pariba tires hold air but are dry rotted, would be afraid to actually take for a ride. Chrome fork has no chrome left. I was considering having it re-chromed, but I think it is too rusted, may just paint it myself. The whole bike needs to be torn down and all parts gone over, rusted nuts and bolts replaced, bearings repacked, cables replaced, etc. l will remove the Scott h’ bar extensions.Other than the chrome, the frame paint job is in fairly good shape, just the usual nicks and scuffs found on a well used bike. This bike has seen a lot of miles from a time when a bicycle was my only form of transportation. All the Campy components work well.
Quoted: 7 Post(s)
Don't know what's going on with my pics, they double load , disappear, reload, etc. If a moderator could delete the extra photo, that would be good.
Update
Below are photos of completed build. Looking for tire suggestions. Would love to go as wide as possible (25 or 28's?).
