1970's Raleigh Competition
Friendship is Magic
Bikes: old ones
Quoted: 26389 Post(s)
Liked 10,365 Times
+1
The 531 frames on these take them to another level. If you're used to mid-range bikes, I think you'll notice a definite difference in stiffness and lightness. These have some pretty racy geometry too. And they'll take wide tires as well, 35's with a 700c wheel, and probably still room for fenders. I'd grab that thing myself if it was local (even though i already have a '76 Competition) they don't come around that often, and they're really something special. Especially at that price.
And those derailleurs do , indeed, seem to be pretty pricey on the used parts market right now.
There have been many fatter tyre, fender, and 650B conversion projects that started out with a Raleigh Comp. Which is probably why they are seen for sale less commonly now.
Quoted: 3803 Post(s)
Liked 3,324 Times
Liked 3,324 Times
Phamilton -
no worries as to expenditures.
item now gone.
Phamilton -
item now gone.
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Those look like washers designed to convert Campagnolo and Simplex derailleur hangers to Huret though, not vice versa, right?
I was looking at a Raleigh Competition a while back, so I did some research on whether anyone made a washer to convert Huret hangers to Campy-style derailleurs. I found nothing.
Liked 3,324 Times
https://www.bikeforums.net/classic-v...ed-washer.html
Quoted: 4791 Post(s)
Liked 3,918 Times
I have that same frame. Same size, same color. 531 with the chainstays Reynolds made exclusively for Raleigh with a short tapered portion to neck down the diameter from typical chainstay to a typical seatstay diameter to a softer ride on harsh surfaces. (Those frames are plush!)
I don't know what was original wheel-wise but you can easily run either 700c or 27" with fenders. Lots of room. (Edit: And as pointed out above, the brakes will work with just about any rim. If you want more braking power, use Mafac Racers.)
Ben
Bikes: 1973 Raleigh Competition, 2010 Rivendell A. Homer Hilsen, 2010's Bike Friday Pocket Companion
Quoted: 19 Post(s)
I have the same year and model. The TA three-pin crankset is original. Original 531 decals stated butted tubes forks and stays. This is a really sweet ride. A couple years later Raleigh dropped the mention of butted forks and stays, and the frame rode much more harshly.
Originally came with tubulars. I converted mine to 27" early on as I found the tubulars a complete PITA, and 700c was quite uncommon at the time, having just come to the US market. No problems with brake adjustment. Note the brake levers were drilled-out with ovals on the front to 'lighten'. I also put a Suntour Ultra-6 on the back having replaced the original Normandy with a custom Regina before converting to the 6 for touring. At the same time put on a TA Cyclotourist. The Jubilee shifts just fine over the 46-43-26 chainset, just use a light hand and don't power through on the pedalling.
Rear mech-wise, took off the rear Jubilee to first replace with a SonTour Cyclone the wider range for touring. Then tried a Campy Rally (which I never got to work (Huret rear drop-outs? although not a problem with the SunTour). Finally ended up with a Hueret Duopar Eco, which is still on the bike. Oh, and I still have the complete Jubilee set -- a work of art. (Not for sale).
Cheers!
Cheers!
Bianchigirll
9
03-12-12 10:46 PM
sethplate
3
03-23-11 11:32 AM
BrazAd
3
03-23-11 11:01 AM
