Mini Front Rack Advice
Ok everyone I need some advice concerning a mini front rack for my recently complete Soma build. I have been looking at the usual suspects...
As much as I like the looks Nitto rack I have read some of the stories about people overloading the rack , and that Rivendell has said to use a strap on the bars to provide additional support, I have not heard such accounts involving the VO or SOMA racks .
What rack does C&V prefer , and what front bag?
Thanks !
- VO Randonneur
- SOMA CHAMPS ÉLYSÉES
- Nitto M18
Thanks !
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
I have a Nitto Mark's rack with long struts and an Acorn compact bag.
With the Acorn tool roll on the back
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I just installed a VO Randonneur canti rack yesterday. Seems pretty sturdy but it is rated at 5kg (11 lbs)
If you intend to go heavier than that, consider the constructeur front rack or similar models that connect to the dropout eyelets.
If you want to go C&V there is also the Specialites TA front rack.
Quoted: 95 Post(s)
Liked 50 Times
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
for C & V, the Ene Ciclo is somewhat less expensive - https://store.somafab.com/enecifrra.html
Jedi Master
I bought a VO first. It's not adjustable and didn't fit on my bike, so I sold it and got Mark's rack. Since my bag is also supported by the decaleur, and I run a front fender, I don't feel the need to strap the rack to the handlebars. I was going to double-strut the rack, but it seems solid enough with one set of struts so I didn't bother.
Quoted: 767 Post(s)
Liked 1,898 Times
I use a Soma Lucas Mini. Not as pretty as the other racks mentioned, but plenty useful. The bag is an eBay find - like $5 or something like that. I made the handlebar support from an old shower caddie hanger. It is a sturdy setup and easily takes a full bag of groceries, beer growlers, what have you.
Quoted: 964 Post(s)
Liked 1,451 Times
Macbook 13" and GB28 bag for comparison.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
But yeah it's tiny. Just some support and that's it.
One small splurge that makes life a lot easier on a front rack are Grand Bois's bag clips: Grand Bois Velo du Reve EB
Just slide in the decaleur and slide the clips in place to connect it to the rack.
Quoted: 964 Post(s)
Liked 1,451 Times
And that's not even a large beer (by size. By alcohol it is huge, and perfectly appropriate for Liège-Bastogne-Liège). I was just surprised, I don't even think the ENE Ciclo is adequate for a Berthoud bag, especially given the narrowness of the backstop. It also did not say anywhere that the rack was made of wire and not hollow tubes. I know I was probably expecting too much at that price, but it's kind of comical looking at it next to the bag I hoped to support.
Jedi Master
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Pelago x Restrap bags use them on a bracket to connect the bag to their front rack.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
That's the GB28 12L bag right? I'm always surprised when I look up the size of the Gilles Berthoud bags. Because they are so short they tend to be very tall and look huge!
Nothing wrong with hollow tubes. Especially in larger diameters tubing can be a lot stronger. Imagine our bikes being made out of thick wire. I don't think that would be all that comfortable.
Quoted: 5224 Post(s)
Liked 3,581 Times
fwiw ~ don't make your own unless you've got experience with that sort of thing. I might come back w a pic of my attempt which was fine except I needed to refine the p-clamps on the fork so they would stay put better. plus it was ugly as heck. here we go, from August 2008. hope no one just ate ...
Quoted: 1136 Post(s)
Liked 650 Times
@scarlson I use the ENE Ciclo rack with a medium-size Swift randonneur bag and it works fine.
It makes no sense to make this rack larger when it is only supported by the centerpull pivots. It can't be a heavy-duty rack basically only attached to the fork by the brake mounting bolt so making it larger would just encourage people to overload the rack. A heavy load should be supported by a rack that also mounts to fork bosses or canti studs.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Exactly. A Velo Orange Constructeur front rack would be a much better option. Or a Nitto 27F Campee which also has removable panniers racks.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4681 Post(s)
Liked 5,799 Times
Did someone say racks?
I've mounted most of the one's you've mentioned. There are pros and cons to all of them. Odds are none of the off-the-shelf models will fit well without modification - typically involves bending them up a bit. Most of the time it's a small coldset that's not very obvious. The issue is that the mounting positions they make the racks for are assumptions around "standards" that aren't so standard. The Nitto Mark's rack design takes care of that by making the stays adjustable. The problem with adjustability is they can loosen, but properly installed, it isn't an issue. I started making my own when I can across the limitations of commercially available racks. I've also modified racks when needed.
The Velo Orange models are probably the best value. I have one of those vintage TA racks on a bike that I didn't want to use P-clamps on due to the quality of paint. I probably put no more than 7 pounds on it including the bag. The bag bounced a bit more than a fully triangulated rack, and you definitely want a sturdy decaleur with it.
I'm not a fan of the racks that attach to the fork dropouts, as it stiffens the fork significantly, and if you're going over rutted roads it transmits those forces up to the bag and handlebar rather than the fork flexing and taking up some of that shock. If that's all you have, ride it, but if you're looking to purchase something, take that into consideration.
Quoted: 7348 Post(s)
Liked 2,465 Times
Quoted: 964 Post(s)
Liked 1,451 Times
33cl (11 oz) of 9% triple goodness.
Plans to make my own rack are in the works. I've TIG'd decaleurs from stainless tubing scrap, I reckon I can do the same thing for a rack. Perhaps incorporating a Spence Wolf style booster plate for the centerpull into the mounting hardware.
Liked 5,799 Times
Go for it! Post pix of the process.
Quoted: 964 Post(s)
Liked 1,451 Times
I think when talking about fork flex, @gugie is talking about a rack that attaches to the fork dropout eyelets. Attaching a rack to those "mini-rack" braze-ons on the upper mid blade shouldn't have any discernible effect on fork flex.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've got a Nitto M18 on my Sequoia, and I think it's fantastic.
I'm not sure what the weight limit is, but I don't think I've been near it.
Whether or not it fits is kind of a crap shoot. It depends on where your braze-ons are. I'd be happy to take measurements to help you figure out if it will fit your bike.
My Bikes
My Bikes
Liked 5,799 Times
@gugie , so you are saying that mounting a rack on the braze ons of the fork will cause the bike handling to suffer adversely ? My Stanyan has mini front rack braze on's and fender mount braze on's .
https://cdn.shopify.com/s/files/1/21...g?v=1505391218
Yeah.
If'n you were to get one of these:
Then no.
I've got all 3 of the VO variants, the Rando rack that mounts to fork blade eyelets, a canti mounted Rando rack, and the Constructeur that mounts to the dropouts, all one different bikes.
The VO racks are well made, light enough, and fit well, although my favourite is the one that mounts to the fork blade eyelets as it sites at a nice height and close to the brakes, the canti version sits a bit higher and more forward, still good but doesn't look quite as 'integrated'.
I've had them for several years and no issues, ridden in all weathers and no corrosion issues, apart form having to take your time with initial fitting I think they are almost perfect.
I also have a Nitto canti-mounting rando rack, forget which model exactly but it's slightly better made than the VO, but not so much as you'd care, again no issues with it in use, would recommend but the VO seem to be 99% as good for a bit less cash, but there are more options form Nitto so if you have funny mounting requirements you might be able to find a Nitto version that will fit better in some cases.
By contrast I also have the Ene Ciclo, which in my opinion is a bit crap. It's solid/wire not tube construction, heavy for it's size, not particularly strong, and bends easily even under light loads, but more annoyingly it has started rusting after only 6 months and hasn't even seen much bad weather. I'm disappointed with it and wouldn't recommend it.
