recommend a rear wheel or wheel set
Old 07-16-19, 08:05 AM
chaser77
Bikes: 2016 Specialized Diverge A1 61"
I have a 2016 specialized Diverge road bike with disc brakes and factory wheels. They say Axis sport. After reading through here trying to trouble shoot a couple different craking sounds, I found that there are about a half dozen spokes in the rear that have cracks where they enter the rim. Some have one crack. Some have two. One has 3 cracks that are about a half inch long. Front rim looks fine. Could you recomm end a replacement ? Durability is more important than weight. I'm 210 lbs. Ride mostly 25-30 mile road rides and then longer 50-70 milers on the weekends. Suggestions for an easy swap with something that is durable. Could I replace just the rear and keep the front or is it wise to replace as a set? Thanks.
chaser77 is offline
Old 07-16-19, 11:26 AM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
https://www.universalcycles.com/shop...s.php?id=82311 36 spokes and a good quality rim should last you quite a few years.
davidad is offline
Old 07-16-19, 11:39 AM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Quoted: 100 Post(s)
Liked 84 Times in 53 Posts
Personally, I’d just replace the rear rim with an eyeletted rim that has the same ERD and spoke count. No need to touch the front if it ain’t broke.
frankenmike is offline
Old 07-16-19, 11:56 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
I'd agree if the spoke count looked reasonable. 24 spokes, and OP is cracking the rear rim? I'd say it's time for a new wheel with more (32 or 36) spokes.
Oh, and a rear wheel is recommended for a bicycle, otherwise it'd be an awkward unicycle.
pdlamb is offline
Old 07-16-19, 11:58 AM
chaser77
I would like to find a rim with 6 bolt rotor attachment. From the brief looking I've done, everything seems to be centerbolt. I do have an 8 speed cassette too.
chaser77 is offline
Old 07-16-19, 12:25 PM
Brocephus
Professional amateur
Brocephus's Avatar
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times in 92 Posts
He needs 6-bolt disc hubs, not rim brake. Plus, these look to be out of stock.
Hey OP, what's your price limit ? I'd take a look at BicycleWheelWarehouse, they do good work at good prices, though I didn't see any of their best prices on the road/disc options.
Brocephus is offline
Old 07-16-19, 01:33 PM
mrt2you
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 17 Times in 14 Posts
maybe check out Vuelta wheels. https://www.vueltausa.com/vuelta-whe...eel-parts.html
they have a set of corsica pro II disc wheels for $220. and thru August free shipping on orders over $100.
i have ran corsica pro rim brake wheels on my 2010 roubaix for the last 4 years without problems. never even had to get them trued in that time and i was 200-255 in that time span. granted that was only riding on smooth paved trails.
mrt2you is offline
Old 07-17-19, 07:15 AM
chaser77
I checked out the bicyclewheelwarehouse and emailed them with what I needed. They were quick to respond and very helpful. I am going to order the wheels they recommended: cxdpro gravel/cx/road 700c tubeless clincher disc.
chaser77 is offline
Old 07-17-19, 07:42 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
The "gravel" model I think you mention has 32 spokes, which is what you want. The "road" model only has 24 spokes which might be a tad light for us bigger fellows. Good luck.
WizardOfBoz is offline
Old 07-17-19, 07:54 AM
chaser77
Yes, I got the 32 spoke. Thanks.
chaser77 is offline
Old 07-18-19, 07:56 PM
chaser77
One more question...the wheels will have an 8/9/10/11 Shimano mtb freehub. I’m using an 8 speed Shimano cassette. Will i need a spacer?
chaser77 is offline
gquirk
Bicycle Mechanics
4
04-11-14 06:31 PM
prebsy
Bicycle Mechanics
5
10-17-11 08:48 AM
ultraman6970
Bicycle Mechanics
4
06-15-11 03:08 PM
L.L. Zamenhof
Commuting
42
06-06-11 04:20 PM
YingYang
Bicycle Mechanics
4
08-16-10 11:00 AM
