1983 Bianchi Specialissima in white. How rare is this? Rallye frame?
Quoted: 4237 Post(s)
Liked 2,949 Times
I wonder if "custom ordered" in this case means bought as a frameset and then built up with parts as desired. To lots of people, "custom ordered" can mean very different things.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Likes For himespau:
In my area a bike like that would top out at about $500 and it would take a while to sell. Bikes that sell quickly are priced very low. It will take a fair amount of work to bring it back to its glory. The bike should be completely disassembled , polished , greased , and perhaps add new cables , brake blocks , and bar wrap. The tires , depending on age might need replacing . Old tires tend to fail at the worst time. I hope your father enjoys this bike , it should be a nice riding machine. Joe
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 956 Times
We're having trouble finding tires in the right size because the rims were custom made. We're not sure if there's a standard from metric equivalent, or if we need to replace the rims too. I doubt we'll get imported tires if that's the only option; replacing rims makes more sense.
Likes For SwimmerMike:
My guess is they are standard 700c tires. The 22 width is not something you see everyday, but a 23 (or potentially wider) tire should fit. My initial thought was that these were tubulars (sew-ups) that you glue/tape on. But with a quick look on line, they could be clinchers. Either way, finding tires for the bike should be fairly easy, you will probably just need to go for a slightly different width, which does not require changing the rims. Since this bike is from the early 80's the max tire width might be pretty small (I run 700cx25 on my 81 Bianchi but it is 2 years earlier). The concern is the tire hitting the chain stay, brake bridge, or the seat tube, so you just need to look to see how much clearance you have with the 22's.
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,385 Times
They are VERY small. But this is very helpful information! Thank you! We're going to to take it to the bike shop where my husband's father worked and put it together, but they're closed for the season until the end of March. We found out yesterday it's owned by the same family, so fingers 🤞, somebody remembers something or can give recommendations.
Not sure if taking it to a shop is a good idea, because it will add to the cost of the project significantly. I guess a lot of this depends on how mechanically sophisticated your father is. Someone stated it's a good "project bike", to completely dismantle and put back together, with the parts cleaned of dirt and old grease, and all the bearings freshly serviced.
Unfortunately, bike shops, in general, need to charge so much for their time on something like this, that it makes taking a project bike to a shop financially unwise. Most, if not all, local bike shops will tell you this.
Likes For 3alarmer:
...there's some confusion here. Nobody custom makes their own rims, but it's a commonly used terminology for wheels, that have been assembled from hubs, spokes and rims. Thus "custom built wheels" gets thrown around a lot. Many enthusiasts have done this.....I have done it a number of times. The tires that are on there whould have some easily readable information as to both diameter and width. As stated above, 700c is the most likely diameter, for the early 80's.
Liked 2,949 Times
622 is 700c, it is literally the most common diameter of road bike wheel you'll find. You shouldn't have a problem fitting 23x700c tires on there, which you should be able to easily find. Nothing custom about that size. Once again, this appears to be a terminology issue where someone took readily available rims, spokes, and hubs, and custom-assembled them into a "custom built" wheel, just like they appear to have taken a readily available bike frame, and "custom built" it by putting parts on it to match the rider's expectations/desires.
Likes For himespau:
Quoted: 334 Post(s)
Liked 753 Times
Likes For bboy314:
Friendship is Magic
Bikes: old ones
Liked 10,385 Times
...if you ask, I'm sure they will tell you that those "rims" were purchased from some company that makes and sells them. I'm not suggesting your FIL is telling stories, only trying to point out to you that he built the wheels, from individual components (rims, spokes, hubs). I'm sure he was an excellent mechanic. I'm sure he worked on bicycles. He doubtless assembled and tensioned those wheels.
Nobody makes their own rims. It would make fitting tires almost impossible.
Here's a link to the wheel rims currently available on Amazon. Maybe this will further clarify what I'm trying to communicate. The rim is the aluminum alloy ring, that runs around between the spoke nipples and the tires. The entire construction is commonly called the wheel.
I'm not trying to belittle your FIL's mechanical skills. Only trying to point out that you're making this seem more difficult than it actually ought to be.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,385 Times
At the shops where I’ve worked, I’ve done many, many rebuilds/overhauls of bikes just like this. Yes, if you know how to do all the work and have the required time and tools, or if you plan to sell the bike for profit, it may make more sense to skip the shop. But plenty of people are happy to lay down a few hundred bucks to have their bike brought back to life by professionals. OP, if you or your FIL do decide to work with a bike shop, try to find one that has experience with vintage bikes.
Quoted: 334 Post(s)
Liked 753 Times
There is one in town that we've had really good experiences with. Gave me a discount on a used bike when my e-bike was stolen. 4 years later, they recovered the stolen bike when somebody brought it in to try and sell (found it in basement of new rental). So we go there for anything we can't/don't want to do ourselves. Truly spoken in Milwaukee- such a great name too!
Likes For bboy314:
TL/DR- we're pretty confident it was a special ordered frame FIL picked everything out for as it was an anniversary present and It's what he did for a living.
Truly Spoken is great! Another place I highly recommend checking out is Vulture Space. It’s a DIY/community shop, the person who runs it is truly passionate about old bikes and helping folks learn to fix them up. They might have limited winter hours, so check before you visit.
