Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Tubulars on track wheels?
Old 11-02-19, 10:43 AM
brooklyn6640
brooklyn6640's Avatar
Bikes: Tommasini, Caad 7 , Seven, Pinarello
Quoted: 64 Post(s)
Liked 14 Times in 9 Posts
On track bike the tubulars are glued or not? glue ,or adhesive strips like Tufo or Velox?read on French forum that tubulars are not glued.
brooklyn6640 is offline
Old 11-02-19, 11:17 AM
rustymongrel
Quoted: 67 Post(s)
Liked 4 Times in 4 Posts
They are most definitely glued. No track racer I know trusts tape. Back in the day trackies used shellac too.
rustymongrel is offline
Old 11-02-19, 11:27 AM
brooklyn6640
Quoted: 64 Post(s)
Hi thank,s I not that about the shellac but is it really safe vs the glue, Continental, Vittoria etc? Today shellac are used by cabinet makers for finishing furniture.
Old 11-02-19, 03:00 PM
taras0000
taras0000's Avatar
Quoted: 318 Post(s)
Liked 15 Times in 14 Posts
Shellac works very well. It's a very strong bond, but it's not very resilient. It sets up hard, unlike most glues which still keep some flexibility when they are fully cured. If you use shellac, then be sure that you plan on treating your wheels carefully, and that you plan on throwing the tire out when you remove it from the rim. Often times the base tape from the tubular will still be stuck to the rim, with the rest of the tire carcass separating from it when it is removed.
Shellac offers the lowest rolling resistance of all tubular adhesives, so it is often used on wheels for record attempts and important competitions.
taras0000 is offline
Old 11-02-19, 08:35 PM
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 317 Post(s)
Liked 32 Times in 22 Posts
Please do not use tape! Please!
Baby Puke is offline
Old 11-03-19, 04:58 AM
brooklyn6640
Quoted: 64 Post(s)
Hi , I have only 1 rear whell with tape but it,s on my road bike , the 2 track wheels are Nemesis with HB7600 hubs , but without tubular , I,m asking before going wrong with the tubulars thank,s
Old 11-03-19, 07:24 AM
topflightpro
topflightpro's Avatar
Quoted: 1425 Post(s)
Liked 142 Times in 98 Posts
Glue and plenty of it.
Rolling a tubular on the track is not fun - I unfortunately know this from experience.
topflightpro is offline
Old 11-03-19, 08:44 AM
brooklyn6640
Quoted: 64 Post(s)
Hi What happened?
Old 11-04-19, 06:50 PM
taras0000
taras0000's Avatar
Quoted: 318 Post(s)
If your glue bond is not strong enough, then the tire rolls off the rim and you crash. This usually happens At high speed when you are changing your line. The added G force as well as the sideways force from the direction change put huge forces on the tire, causing it to roll off.
It is rare to be able to recover from a rolled tubular and ride it out. I've also seen a front tubular roll off and get caught around a riders foot. That was a nasty crash.
Old 11-04-19, 11:10 PM
Baby Puke
Quoted: 317 Post(s)
I've seen a few tape jobs now, and the biggest problem I see with them is their insosnsitency. I've seen a few that simply pushed off the rim with minimal effort. That is scary. I have now seen one that was a strong bond that probably would not have come off under normal riding conditions. In general, glue is dependable and seems harder to mess up than the tape from what I have observed.
When preparing your equipment, you must always keep in mind that if you go down because of an equipment failure, there is a chance you will take others with you. I always try to have my gear over-prepared rather than under for this reason.
Old 11-05-19, 07:44 AM
brooklyn6640
Quoted: 64 Post(s)
Thank,s guys
Do you know where I can find the Continental sprinter tubular manufacture date ? these tubulars have a deadline for normal use ?.some lbc sell less products, so some be old stock vs online dealers? thank,s
found.
Old 11-07-19, 07:36 AM
FinkFloyd
Quoted: 20 Post(s)
It is impossible to see someone roll a tub on track without feeling the need to check and re-check your own wheels the next time you ride. I remember seeing a video of (I think) Gregory Bauge rolling a tub and staying upright; he managed to roll to a stop without hitting the deck (until he was going quite slowly) but it absolutely shredded the rim of the wheel that lost the tyre.
FinkFloyd is offline
Old 11-08-19, 11:10 AM
rustymongrel
Quoted: 67 Post(s)
Thank,s guys
found.
I don’t think continentals have a date on them, but I know some brands do, veloflex for example have the date printed on the base tape.
That said as long as the rubber of the tire is supple and not showing any signs of cracking or drying out they should be fine. I’ve used “old stock” tires plenty of times, they last quite a while.
Old 11-08-19, 12:54 PM
brooklyn6640
Quoted: 64 Post(s)
Date of manufacture on Conti found, all conti have manufacture date on the side . I think more about the old inner tube . I keep my Veloflex at least 1 year not glued on rim , to dry.
Old 11-08-19, 02:04 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2678 Post(s)
Liked 551 Times in 397 Posts
Inner tubes last a long time since they're protected from UV and ozone (mostly) inside the tire. The inner tubes in my English 3-speed are perfectly fine after decades of service.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
