Repair gouge in Vibram sole
Quoted: 318 Post(s)
Liked 149 Times
Any idea how to repair a gouge in a Vibram sole? I have a chunk out of the side and center of a lug, cut by my cage-style mountain bike pedals. I've had these boots a total of three weeks and I haven't ridden that much with them, probably 100-160 miles.
I got Vibram because I thought that compound was supposed to last, but now I see that Vibram is not a single compound but a brand which markets dozens of compounds and soles. The boot is Vasque Talus Trek UltraDry. They say the compound is Vibram XS Trek, which isn't listed on the list of compounds that I saw:
https://us.vibram.com/on/demandware....-june-2015.pdf
although it is mentioned in the following link, apparently trading off some durability for grip, hence my situation. (I did go hiking in wet weather yesterday, and I can verify that I kept my footing despite every opportunity to bust my a$$.)
XS Trek
I tried ShoeGoo but that didn't adhere, maybe because the tube is old. I was also thinking epoxy. There's also this StormSure stuff, which mentions curing so may be epoxy-related? Does rubber cure too?
https://www.stormsure.com/index.php/...-15g-tube.html
Any ideas will be very appreciated.
Bike-related because these are supposed to be my riding boots. Looks like I'll be going for different pedals now.
XS Trek
Sr Member on Sr bikes
Is there a shoe/boot repair cobbler in your area? If Shoo-goo didn't work I'd check with them.
Dan
Dan
Likes For _ForceD_:
Likes For coffeesnob:
I had a pair of leather boots with Vibram outsoles resoled by a cobbler. Three months into a yearlong deployment to Afghanistan the outsoles started to separate from the boot. This was a less than ideal situation because Afghanistan. So with a sample size of one my experience with resoling boots has not been positive.
Likes For Groundsloth:
Likes For woodcraft:
With a mighty wind
Quoted: 1087 Post(s)
Liked 862 Times
That's not where shoes wear out from hiking. So you can hike as much as you want and ride as much as you want and you won't be doubling the wear.
In other words, do nothing.
The only sole repair option that works is a resole (with occasionally mixed results). Yours are not resoleable.
Likes For rosefarts:
Quoted: 318 Post(s)
Liked 149 Times
I might ask the cobbler what he/she thinks about slicing off the lug and putting a new one (block of similarly-shaped material) on with glue. It seems to me that I risk tearing off the front side of the damaged lug.
Hard to accept the getting worse scenario with boots that are so new.
It seems like a dental cavity -- a situation that creates the circumstance for its own worsening, unwise to ignore.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
From my experience with rubber soles, about all you can do is wear the shoes until the split gets bad enough to let water into your shoes. Then pitch 'em.
Likes For FiftySix:
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
as others have said, wear them til they wear out then chunk them. and stop looking at the bottom of your shoes
Likes For Flip Flop Rider:
Quoted: 18413 Post(s)
Liked 15,536 Times
Likes For indyfabz:
Quoted: 5224 Post(s)
Liked 3,581 Times
you might snip that little curved part which might help prevent it catching on the pedal?
Likes For rumrunn6:
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Shoe goo is great for sneakers, etc. With real Vibram soles I would slice off the damaged lug to get a smooth surface (no crack) to prevent the cracks getting deeper. I did that with a pair of field boots and they are still good to go after about 14 well-cared for years. They were are my favorite field/hiking boot, full leather with kangaroo upper shaft and are light, foot formed and now unavailable. My damage was in the outer edge near where a pedal may hit.
I avoid pinned pedals for the reason that they can damage soles (and shins and calves).
