Bottom Bracket Cup Identification and Removal
Hi there!
I've watched all Park Tool's Youtube videos and read all Sheldon Brown's articles on bottom bracket ID and removal, but I'm still not sure what bottom bracket I have and what sort of tool I need. The diameter of the cup is 44mm. The cup on each side is individually threaded and they are not connected. The internal edge of the cup has 12 notches. The external edge of the cup is perfectly round and there are no notches.
The only discernible markings on the cup are the letters "VIA".
It's an older Schwinn road bike. Not sure of exact model, as there is a thick new coat of paint covering any markings.
Pictures are below, hope you can help! Thank you!
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
The photo is a little blurred, but looking through the cup, it looks like an unthreaded shoulder on the other side. Except for the notched hole, it looks a lot like the old pressed-in one-piece crank BB. Can you see threads anywhere?
Have you tried a cassette removal tool in there for fit?
Can you post a photo of the cranks and spindle?
How many speeds is the bike?
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
My guess is it's an old FFS Front Freewheel System setup.
Google "Shimano FFS"
Might need tool #4 or equal.
Shimano Bicycle System Components (1984) page 159
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Since the tool in the manual is out of production, do you think this FR-5 from Park Tool would do the trick? : https://www.biketiresdirect.com/prod...xoCxPIQAvD_BwE
Stuart Black
Stuart Black
No. The splines are wrong. The Shimano TL-FW20 is the only tool that will work. You might try Sheldon Brown's bolt method could be a work around
Old fart
Liked 3,400 Times
Old fart
Liked 3,400 Times
If the proper tool is the Shimano TL-FW20, then the repro Kengine FR-04 may work THis tool claims to "compare" to the TL-FW20 and to work on FFS. I bought one a while back for a very old (late 70s) Shimano freewheel that the typical Park tool would not fit.
SE Wis
Liked 3,391 Times
Personally, first I'd get a piece of flat steel bar stock and grind until it fits in a couple of the splines and try to turn (the correct direction) the flat stock with an adjustable wrench on it.
Or maybe a cold chisel that fits and turn that.
