Long rear derailleur for 11/32 cassette
I recently purchased a Merlin extralight with 7800 dura ace drivetrain. Love the bike, but it is certainly not geared for my mountainous neck of the woods.
What ten speed rear derailleur would be a good choice to go with a 11/32 rear cassette?
LBS Employee/Commuter
Bikes: 2007 Trek Soho, 2010 Gary Fisher Monona w/ Xtracycle FreeRadical, 198X Facet BioTour 2000
New Shimano XT/XTR is going to be 10 speed. I'm sure there will be a long cage of both that will accommodate 11-32 and still work with your Brifters.
Quoted: 140 Post(s)
Liked 162 Times
Ironically, if you need to install a Shimano mtb rear derailleur to work with your road shifters, , you can use pretty much any Shimano mtb rear derailleur EXCEPT the new "10 speed Dyna Sys" models to work with your road shifters because Shimano has changed the cable pull ratio on these models. Keep in mind, the number of "speeds" is in the shifter, not the derailleur, it's the cable pull ratio that needs to match between shifter and derailleur. Also keep in mind that the cage length only affects chain wrap capacity, not largest cog compatibility.
Advisor
If yours is not a triple, you may want to consider putting a triple crank on. And a double, you may also want to consider a 34/46 crank, both with a 28 cassette. Small chainrings I think go down to a 24.
Quoted: 3355 Post(s)
Liked 5,432 Times
Quoted: 2026 Post(s)
Liked 1,095 Times
Installing a 9-speed XT or XTR rear derailleur should allow the 11x32 cassette to work with no other changes.
I have a triple on my touring bike. This Merlin is meant for randonneuring-type riding; ultra light long distance.
I love the simplicity of the dual crank. 50/34 (or 33) front with an 11/32 rear ought to be low enough. This setup sacrifices close gearing, but I'm not willing to sacrifice the 50/11
Bikes: Raleigh 12sp road, Specialized Hard Rock MTB, 1977 Schwinn Hurricane 5-speed
Should a 52-42-30 front crank work with a 12/26 rear via a shimano 105rd with long cage? I took 2 links out of the 114 link 9sp chain because the cage didn't seem to be hanging right.
I use an ultegra gs (long cage) on my triple with a 11-32 just screw the b screw all the way in to make sure you have enough clearance and I'd probably avoid using the 50/32 and the 34/11 combos.
Liked 1,095 Times
Liked 1,095 Times
If you want a smaller chainring, the next common bcd is 74 mm which will accept a minimum of a 24T chainring. This bcd is used for the "granny" chainring on most current road triple and older MTB triple cranks paired with a 130 mm or 110 bcd for the two larger rings.
Front derailleur capacity is another issue. most can only handle 16T though older models would be spec'd at 14T and still handle the gap of a compact. As stated, the BCD becomes an issue though.
