derailleurs don’t belong
Quoted: 138 Post(s)
Liked 81 Times
I’m getting closer to bullding up an Enviolo rear hub even if the lowest gear isn’t as low as I’d like. With the BBSHD set at higher power levels, above 3 out of 9, things happen faster than I can react when a stick gets tossed into the jockey pulleys. Or maybe I should just get a motorcycle. Anyway with a big cassette that derailleur pulley is just inches off the ground catching stuff all the time.
Anyone have experience with Enviolo and BBSHD?
Ride more, eat less
Quoted: 716 Post(s)
Liked 740 Times
Start with some riding parameter.
Budget?
Rider weight?
Cargo weight?
Desired top speed?
Desired range for battery?
Mainly MTB trail riding? tight single track?
All Mt., ski trails or downhill stuff?
Budget?
Rider weight?
Cargo weight?
Desired top speed?
Quoted: 668 Post(s)
Liked 529 Times
Don't fully understand your problem. Why is your derailleur cage so long and low to the ground? Especially with a 1x front derailleur?
Rather than run a "big cassette" why not use a smaller front chainring? 30 tooth rings are available for the BBSHD.
Been riding a long time and never had an issue with sticks in the jockey wheels. Not sure what power levels and reaction time have to do with that if it did happen.
Quoted: 884 Post(s)
Liked 826 Times
There are lots of BBS & IGH conversions with everything from Shimano 3 - speed to Rohloff (someone here might have one on an R & M e-bike), but not many here AFAICR. You just need to search for them.
Quoted: 138 Post(s)
Liked 81 Times
Likewise I’ve been riding a long time off road but never through this kind of stuff. It’s as different from packed dirt as mud clay is.
I’m using the bike as I would a motorcycle and a derailleur bike just isn’t a motorcycle.
I’m on my fourth derailleur and one wheel rebuild.
