Question re: stem adjustment
Quoted: 15 Post(s)
Liked 8 Times
Hi!
I recently finished building a bike that I love, but that upon completion I realized I had set up just a bit too long for me, and was finishing my rides with significant upper back pain. Ive currently got a 10 cm nitto dirtdrop stem, and I decided to fix the problem with a 5 cm nitto techmonic. However, once the techmonic arrived I realized by holding it up next to the current stem that while it will move the bars backward about an inch and a quarter, it will also drop them about an inch and a quarter lower, from just above the saddle height to just below it. This feels a bit like creating a new problem to solve my first problem. Does anyone have any alternative stem suggestions? Or should i just accept the lower/closer trade-off? I already have my seat shoved as far forward as it will go without turning the set-back post around backward.
Thanks!
Thanks!
Quoted: 897 Post(s)
Liked 9 Times
A 5 CM stem? Sounds like you need a frame with a shorter top tube. Sliding the seat forward to decrease reach can cause problems.
Frame sounds like it's at least two sizes too big.
Quoted: 15 Post(s)
Liked 8 Times
So to clarify, the significant back issues were when I had the seat shoved all the way back. Today I completed a 50 mile ride with the seat forward (at about the midpoint of where it would be on a non-setback post) and had only mild discomfort. I estimate that at current bar height I need to lose just 1 or 2 cm to be fully comfortable.
Quoted: 51 Post(s)
Geometry is cruel. If you have a short high angle stem and you make it shorter it gets lower, as you found out.
You can get steering tube extensions that just move things up, and then use a short 0 degree stem.
Hi!
Thanks!
Thanks!
banaeatingbiker
Bicycle Mechanics
10
01-02-18 08:09 PM
magilla
Road Cycling
7
10-29-10 10:57 AM
