Simplex RD question
Bikes: Masi, Olmo, Miele, Masi, Masi
Quoted: 40 Post(s)
Liked 34 Times
Simplex RD question
I have a simplex RD to use on my Peugeot PX10. This new RD has a hanger attached to it which seems to limit the rearward travel of the main body. Taking the hanger off is easy enough, and it looks like the mounting nut could be used on the RD mount in the dropout. Is there any problem with just removing the hanger and just bolting it to the dropout?
The hanger in question.
No threads in there.
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
Be careful not to commit the Simplex rear derailleur cardinal rule as I did in post number 21 here --> https://www.bikeforums.net/classic-v...hink-play.html
Quoted: 157 Post(s)
Liked 113 Times
Which model exactly do you have? With most of Simplex derailleurs removing the hanger won't work for you because the mounting bols are different for two versions plus you will need some extra bits. See the scheme below for SX 410 derailleurs. It's much easier to find the proper version without a hanger than to modify it from one version to the other.
Quoted: 40 Post(s)
Liked 34 Times
Quoted: 40 Post(s)
Liked 34 Times
Quoted: 1607 Post(s)
Liked 2,216 Times
Based on the diagram, there is not simple in Simplex! Even the RD body is different!
Quoted: 790 Post(s)
Liked 1,760 Times
A Suntour RD will not readily bolt to this bike since the DR hanger is different no threading or stop tab. If you want to run a none Simplex RD you will need to modify the hanger. On a PX-10 your best option is to find a nicer Simplex DR that is right for the bike.
