Can I use wet chain lube to lubricate shift cable?
is it ok to give a squirt of dumonde tech lite formula into the housing before running the cable through and calling that good? all these lubes are like $10 - $15 a piece and i'd prefer not to buy a bottle when i need a drop if i have something that will suffice. thanks.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Right or wrong i do. Never had an issue.
Jon C on GCN just uses what ever lube he has at hand too.
Between slick, polished or coated, cables and lined housing, I call that good enough and don't bother lubing cable. Hasn’t been an issue.
Quoted: 1438 Post(s)
Liked 1,092 Times
Me, too, I find that lubing them just helps them to pick up dust and grit better. I use the die-drawn(slicked) inners and lined housings, the coated ones are difficult to clamp securely and the coating comes off and causes problems.
Agree about coated cables. Die drawn is the way to go.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,214 Times
Stuart Black
Stuart Black
Quoted: 4559 Post(s)
Liked 2,802 Times
Depends on the lube. I tried Park CL-1 chain lube on cables a few years ago. When I finally replaced the cables I realized the CL-1 had become tacky, making the cables feel a bit sluggish. That's probably the same characteristic that makes CL-1 a good wet weather chain lube.
But not problems with Boeshield T9, Tri-Flow and most other wet lubes, especially penetrating lubes. They don't get tacky after the carrier evaporates.
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Made a huge difference in the short term.
But what about all that "WD 40 is NOT a lubricant!" conventional wisdom?
It freed things up, but I can't help feeling like we really need to use something else for actual lasting lubrication?
Quoted: 1062 Post(s)
Liked 665 Times
Just did that thisafternoon to the "slow" rear brake cable on the sat in a garage for years craigslist find that became my nephew's new ride, because it was borderline unusable the can was right there.
I'd use it if I had it, before going out and buying something else to sit on my shelf.
Oddly enough I just found out that chain lube works as a tapping fluid.
Likes For UniChris:
Quoted: 1943 Post(s)
Liked 2,164 Times
Depends.
Over time I’ve use a lube and not used one at other times.
I’ve stopped using a lube on my mountain bikes as dust goes everywhere. I’ll clean my housings with WD-40 and leave it at that. If find that using the “slick” cables are the biggest improvement with trigger shifters.
John
John
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Slotted cable stops allow you to very easily pop the cable out, slide the housing out of the way, and lubricate the cable within. I regularly apply a little Tri-Flow to mine, and notice an immediate improvement in brake response and lever feel. But if you really want them to be slick, use a bit of this:
dglevy
Bicycle Mechanics
33
09-13-18 09:17 PM
DRietz
Bicycle Mechanics
29
05-20-10 10:13 PM
