Stripping threads on crank arms
Quoted: 24 Post(s)
True to my name, I just trashed a set of crank arms! They cost $350 to replace. On the previous set, on which I had 4,600 miles, the steel pedals were going bad. That's not a major crisis, but then when I removed said pedals to replace them, it was really, really hard to remove them, and a huge amount of aluminum came off on the threads of the pedals. And then the crank arms were unusable. I have done this to previous cranksets, too over the years, stripping the crank arm threads in a manner the mechanics said they didn't previously think was possible but then this is you, Eric.
To give a little background, I weigh 350 pounds and am 6 feet 9 inches tall. A year and a half ago, I got a new Rodriguez custom frame bike built for me and they put High Sierra 210mm crank arms on it. I called the High Sierra people to order a new set and they did have a pair in stock and then the salesman told me to use anti-seize lubricant, something I'd never heard of. Turns out it's the sort of thing car mechanics use on spark plugs to keep them from bonding to the other metal. So I got some and boy is it gooey and gets on everything. But I put it on the threads of the new pedals and have been riding for a few weeks since then.
Ok, so the question I have for you: Has anyone here stripped the threads off of crank arms this way? And have you found a solution to it?
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
No, I still have the same cranks on my 35+ year old bike (but it hardly gets ridden any more). For 10 years it was my only bike and I put about 3000 miles on it annually.
Quoted: 2604 Post(s)
Liked 1,929 Times
I haven't stripped the aluminum threads at the pedal interface, probably because I always put plenty of grease on the pedal before I thread it it. Plenty means as much as the threads will hold. If any squeezes out, wipe it off with a paper towel or rag.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I have broken the threaded insert in a set of Hussefelt downhill cranks on my fatbike. They are now obsolete, so had to replace cranks and bottom bracket to current standards. I have snapped bottom brackets and worn the interface of square taper cranks and bottom brackets. I change pedals regularly, so grease on the threads keeps those from seizing.
+1. I also try to remove them, clean the threads and reinstall once a year or so. And watch the thread direction!
Likes For hammond9705:
anti-seize is a good idea. dissimilar metals can corrode and/or cold weld together. be careful using it on torque-critical fasteners though, because it can cause inaccurate or inconsistent torquing.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I have always used grease on crank arms. I put grease on the pedal threads and on the axle ends before attaching the cranks. I use grease on the bolts that hold the cranks on the axle. I put grease on my aluminum seatposts before putting them in my steel and aluminum frames. I have never had one slip. I grease both quill stems and threadless fork type stems before attaching them to their forks. Never had any of them slip either. Anywhere things bolt together I put on grease as a form of anti-seize. Pay heed though to khyatt's warning about over tightening. It is easy to do with greased bolts.
