What Did You Do To Your Bike Today?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,646 Times
Thought it would be interesting to see how people maintain and improve their rides. This could include bike builds, how to, and tools used. Could be learning or just interesting what people are doing. Pictures highly encouraged.
Today, I added new Cinelli bar tape/plugs and adjusted the seat back 3 CM and raked the nose down 2 mm.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Likes For BobsPoprad:
Grupetto Bob
Liked 5,646 Times
Likes For Airfehr:
Likes For rydabent:
Grupetto Bob
Liked 5,646 Times
Quoted: 18424 Post(s)
Liked 15,573 Times
Put on new tires for my upcoming tour.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Pumped up the tires and went for a ride!
Likes For JohnDThompson:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I've been building up a fixed gear, and it's in the final tweaking stage. Following the last two rides, I've: rotated the bars very slightly to level (forward maybe 3 degrees), re-taped the handlebars center-outward to eliminate the adhesive strips, added a 2 mm spaces above the stem to enable better headset pre-load, re-tensioned and trued the front rim (new, machine built wheel), moved the rear wheel slightly to increase chain slack just a bit, and attempted to solve the real problem: slipping in the seatpost-to-saddle rail clamp.
This one is a bugger. Here's the as-built original seatpost. Note the miniscule actual clamping area on the rails. While highly adjustable, these tiny wings provide insufficient clamping force, no matter torqued I make the bolts.
Because the bike is all black and intended to be very light, I went with a carbon seatpost.
Here's the temporary fix found at my local co-op. Bead-blasted aluminum is not the look I'm after, but it does (at least) function.
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
It's early yet, but my plan is to pump the tires and ride it. I may wipe the chain after. Would you like to know what I'm having for breakfast?
Likes For shelbyfv:
Zip tie Karen
Liked 1,542 Times
Here's the latest solution to the seatpost problem, a new carbon post with a larger clamp surface. All carbon clamp parts (aside from the fasteners), and they were slipping on a brief test ride last night. So, complete disassembly and cleaning of the saddle rails and clamp, and then liberal application of carbon paste.
Although (in theory) only the rear bolt needs to be tightened, I decided to torque down the obscured bolt by cutting down the working end of a spare 5mm hex key and working it into place to tighten. All torqued down now. Another test ride this evening, and this should (could? might?) work.
Likes For Phil_gretz:
Likes For kahn:
Expired Member
Liked 5,438 Times
Thanks for asking! I had a bagel with peanut butter, a banana, grapefruit juice and coffee. I pumped the tires, attached the rechargeable blinky and Wahoo, went for a short ride. I really should go back down to the garage and wipe the chain. I'll get to it before I ride tomorrow.
Likes For shelbyfv:
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
3 Uno stems from Amazon were delivered yesterday. I plan to use one on a road bike I dont ride often as it needs a longer stem, and take the quality stem thats currently on it and switch it to my gravel bike.
Then one of the other two will be for one of my kid's bikes as she needs a bit of rise and length due to growing. Hopefully the stem makes it possible to keep riding that bike for the rest of the year because there is 0 chance we are buying a bike or even a frame right now.
Return the unused stem.
I usually only buy the lightweight Uno7 stems off ebay, but I cant find a single seller with the length I need.
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
Not today, but on Sunday and Monday I converted my daughter's bike to an ebike. It's a mid-mount 500w motor and 48v battery. I'm not as comfortable with electrics as with mechanical stuff, but it all went surprisingly smoothly. I still need to figure out how to tidy up all the wires.
Likes For Oldguyonoldbike:
Zip tie Karen
Liked 1,542 Times
Grupetto Bob
Liked 5,646 Times
Quoted: 129 Post(s)
Liked 177 Times
One could save hundreds of dollars by going with a smaller battery or a less powerful motor. There are also hub-mounted options, but the price difference is not great and I imagine that the mid-mount motor feels more natural and has less of an impact on handling.
Bikes: An old Panasonic Sport
Quoted: 10 Post(s)
Liked 28 Times
I looked at it sadly and said “sorry, I don’t feel like getting wet today, I’m gonna take the subway.” and then quickly left the apartment before either of us had a chance to say anything else.
Likes For Vismund B:
Quoted: 6196 Post(s)
Liked 4,811 Times
I lubed my chain and wiped off the excess prior to my ride. Since I rode yesterday and had aired up the tires then, I only squeezed them to make sure they had enough air.
Sorry, no pics or video of such an exciting thing to watch.
Are these the rules?
Last part seems to leave a lot of lattitude IMO.
Likes For Iride01:
Quoted: 383 Post(s)
Liked 690 Times
Yesterday I moved my new saddle about 1/2 to 3/4 inch rearward. I THINK it felt better for the 30 hilly miles - I think my butt is none the wiser today "butt" I think my perineum appreciated the change!
Likes For kahn:
Got it dirty. Very dirty. I decided to ride to work, and pick up my wife's car at the repair shop near where I work at lunchtime. It must have rained overnight briefly in a few spots along my 12.5-mile commute since the roads were still wet in a few places. BOY, did I get road splatter, and those old-school TireSavers really flicked off any moisture/dirt from the tires! Just a few miles of wet road and the bike is a splattered-up mess! It is gonna take me hours to clean properly. Well, since it will likely be the last time I commute by bike this year, I might as well just give it the good-ol' off-season detail overhaul.
Oh, and when I got home I ordered a couple of rechargeable 120 lum LED taillights since the one of the bike must have given up the ghost. It was working when I left the house, but less than a half mile later it was dead. Not just dead from no charge - just plain old dead.
Expired Member
Liked 5,438 Times
Today, I again wiped the chain and pumped the tires. I think I'll lube the chain tomorrow, may have heard a chirp.
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Besides the usual before-the-ride cleaning & inspection, after my ride on my Kona today, I tightened the water bottle cage screws, which loosened during the ride. tmrw, Im gonna adjust the front der cable.
Likes For epnnf:
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
I had been having slow shifts with a rear Sachs New Success derailer that I bought on eBay, so decided to take the pulleys out and clean and lube them. I soon noticed why my shifting was bad when I saw the guide pulley was wobbly, made by simplex, and missing the side plated that cover the bushing. I had some sealed bearing aluminum pulleys in my parts bin so I cleaned them up and installed them. Once everything was back together I made some adjustments to the cable while shifting through the gears and it seems to be working great now.
Likes For Flatforkcrown:
