Just curious, Schrader valve
Not a big deal but I was just curious when I was topping up my tires.
When you remove the pump from the schrader valve, how much psi is lost when when you get that hsss?
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
Basically none, the air's coming from the pump hose.
Likes For Korina:
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,309 Times
I've wondered this myself (I'm like that). It's going to depend on the pressure and tire volume. I'm guessing around 0.5 psi.
Mark
Mark
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,221 Times
That is true only for a Presta valve. Prestas are check valves that only allow air flow in one direction. Schrader valves have to be held open to fill. Any hissing is air being lost from the hose and tube. How much air is lost from the tube would depend on a number of factors and would be difficult to quantify. It would also vary widely.
Stuart Black
Old School When It Wasnt Ancient bikepacking
Stuart Black
Likes For cyccommute:
Quoted: 1248 Post(s)
Liked 1,323 Times
Quoted: 569 Post(s)
Liked 586 Times
Easy to check and if your pump head is getting sloppy might be worth it to check with a gauge after inflating which will also catch gauge inaccuracies.
A clean Schrader value can work as well as a Presta in limiting the air escape as demonstrated by their use in high-pressure hydraulic systems on Aircraft.
Quoted: 1820 Post(s)
Liked 1,696 Times
A lot will depend on the volume of the tire you are pumping. Most bicycles with tires that use schrader valves are high volume/lower pressure tires. With these tires very little pressure is lost and the pressure loss is of very little consequence
Likes For alcjphil:
Likes For Charliekeet:
My old Fuji S-10S came with a screw-on hose for the factory Primus frame pump. I couldn't get that hose off the Schrader valve quick enough, losing lots of pressure while doing so. Soooo.... I ditched the Primus pump and got the Zefal HP with a quick-release chuck withn the first month or so. That old Fuji still wears a Zefal HP today, albeit it's fourth one for various reasons...
BTW, even back then, I was inflating my 27x1-1/8 tires to ~100psi. WITH Schrader valves!
Quoted: 6196 Post(s)
Liked 4,811 Times
I suppose it depends on what type chuck you use for Schrader. However many that lock on to your valve stem probably release the pin almost as soon as you release the locking lever. Just like prestas, what's being heard is air escaping from the chuck, hose and sometimes the pump.
However if you have a 60 plus year old floor pump like I have with a chuck that you screw onto the Schrader valve, then yes there is some air loss while you race to unscrew it quickly. However I'd really be surprised if they make air chucks for bicycle floor pumps like that anymore.. Besides, it had no gauge on it so I still had to check with a gauge after I removed the chuck to see if the tire was full. So how much air is lost wasn't an issue since I had to check the pressure any how.
That pump is pretty much not used ever anymore. I only keep it around because it's been here as long as I've been here, maybe longer.
Likes For Iride01:
Liked 4,221 Times
If you hear hissing from a Schrader valve, air is being lost from the tube as well as the hose. With a Presta, air is being lost only from the hose.
Stuart Black
Stuart Black
Liked 1,323 Times
Most pump heads Ive seen and used for Schrader have a plunger that is nearly flush with the outside of the head. The pin of the plunger engages the valve almost as soon as the chuck is placed on the stem. The seal isnt that tight around a Schrader valve either needing either a thumb lock or screw on mechanism to hold it in place. Flipping open the thumb lock or unscrewing the chuck results in some pressure loss (how much is difficult to quantify) because the pin engages the stems valve until it is clear of the stem.
Quoted: 590 Post(s)
Liked 445 Times
Hiss duration is a factor. How long do you hear the hiss? If you have to fumble around for a few seconds to get the pump nozzle off completely, while it's hissing the entire time, you're likely losing more air pressure from the tire than you want to.
Likes For Riveting:
Quoted: 440 Post(s)
Liked 264 Times
Likes For Bmach:
Quoted: 1944 Post(s)
Liked 2,164 Times
The only way to tell is with a separate pressure gauge. The issue with that is the pump gauge may not be accurate.
You could use the pump on a car tire and then compare the pump reading with the pressure gauge. There is so much volume that a small amount probably wont impact the reading. It will also indicate if your floor pump gauge is off.
I have an inexpensive floor pump that is off by 3psi. Not a big deal at 75psi, but more so at 30psi.
John
John
Likes For 70sSanO:
Likes For MNBikeCommuter:
Quoted: 5224 Post(s)
Liked 3,585 Times
I'm a schrader user
related: when I check my tire pressure with a hand held gauge, a little air escapes. so when I'm deflating the tires on my Jeep, when I get close to the pressure I want, I use the gauge repeatedly to get it perfect. meaning the more I check the pressure, the lower it goes. because bike tires are so low in volume, checking the pressure may change the pressure more than one wants. so when you get it where you want it, leave it alone
Quoted: 321 Post(s)
Liked 263 Times
It must be very little because we use Schrader valves on mountain bike shocks. The pressure is about 80psi but the volume inside the shock is tiny. So if really any amount of air came out you would lose a lot of pressure.
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Fun fact: the Schrader valve was patented in April 1893 by George Schrader of New York City, New York, USA.
Safety bicycle --> pneumatic tire --> Schrader valve
Likes For tcs:
Likes For Fredo76:
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
