Truing stand modification
Old 02-28-23, 03:01 PM
awac
awac's Avatar
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times in 78 Posts
What modifications have you done that has improved (in your opinion) your truing stand, or made it fun?
To kick off here is my modification done today on my Park tool TS-4. A base made of two layers of 3/4 plywood. It has “clamp ears” so I can move outside when the weather is good. When you have marked the base out, just slide the stand to either side and use the side to draw the curve on the sides. The calliper arm adjuster knob at the front now does not touch the surface the stand sits on (that always annoyed me!). It now weighs a bit more and that adds to the already solid feel of the stand, it now does not move and I like the the pockets at the front to be clear off the surface. Plywood can be slippy on varnished wood so I put a grippy sheet underneath, don’t ask what it came in some packing! I might paint it, or just use it as is, I seem to have too many projects waiting in line, you know how it is!
Clothes pegs are very handy if you have to stop and don’t want to loose the spoke your on!
awac is offline
Old 02-28-23, 07:41 PM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
Eons ago, I mounted my truing stand (not Park) to a "sink hole" sourced from a local cabinetry. I added 4 feet in the form of brake shoes.
Now it's completely stable and portable.
FBinNY is offline
Likes For FBinNY:
Old 02-28-23, 09:30 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4210 Post(s)
Liked 3,878 Times in 2,315 Posts
I have two pics of modded truing stands.
The first is what I suspect most here will drool over, to some degree. A TS-2 with home made dial indicator mounts.
I do like the TE-2's solidness but just like back 40+ years ago when i first tried dial indicators I still find them too distracting, jumping about enough to make the macro hard to see it's center. Just the same visitors seem impressed
Next up is my VAR #485 Preciray. A legend of the 1970s, to speak of.
I got this stand as vacation pay way long ago. What i like is the rock solid wheel/axle clamping ability and the rim followers multiplying the amount of deviation. Note the different radial roller follower which is the mod. The white lateral roller follower is OEM. At some time the radial one became "broken", I just used its stub held in place by that home made C clamp (off to the upper LH in the shot, this was one of my first school shop projects back in 1972 or so) until I came across available roller followers. Note the extra holes for the radial lever pivot, spring and limit mounts. This shift to the right increased the "wiggle" of the pointer from the OEM amount.
One of the big aspects of a truing stand for me is its solid/stability and repeatability. The Park TS-4 series is way bad in this. The axle retention is poor and the really long rim indicator "fingers" are equally flexible. I know this is the cost of tubeless and wide rims/wheels/tires. too bad because a solid stand is a pleasure to work with. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 02-28-23, 10:10 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 699 Post(s)
Liked 409 Times in 255 Posts
I bolted my old Park stand to a 16"x20"x3/4" marine plywood board. It's heavy enough to not require clamping to the work bench and portable enough to slide up on a shelf when not being used.
drlogik is offline
Likes For drlogik:
Old 02-28-23, 11:16 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
I have a cheap stand made from tubing and flatbar and a dishing tool of the same ftatbar. Both serve me just fine but the dishing tool had a tube that fitted over the axle so I had to remove the nut or QR every time I checked and put it back on for a secure stand mount. So I made a sideways "U" from two pieces of aluminum angle. Now I just slide the wheel in so the "U" flange fits between nut and locknut. So nice I wish I'd made it years ago.
Sorry, I am still digital photo ignorant and hope to stay that way.
79pmooney is offline
Old 03-01-23, 03:37 AM
awac
awac's Avatar
Quoted: 69 Post(s)
How do you find accuracy of the preciray/park tool compared to each other? I understand the pointers are x10 magnification, what does that equate to on your dials? Do you use the preciray to get a “working wheel” and then dial in closer, or is the accuracy the same?
I am going to France this summer……I will be scouring French websites before I go….just missed one on ebay in the UK, dammit!
awac is offline
Old 03-01-23, 10:28 AM
Andrew R Stewart
I don't consider a truing stand to have anything to do with accuracy or precision (as I think is the better term for your question). These are the duty of the person turning the spoke wrench. A stand only holds the wheel in a manor that can make the wrench's job easier. Like any stand the VAR is a stupid assembly of metal parts that wasn't made for exacting measurements. It does have a few adjustments for getting the dishing aspect quite close to being "spot on", still I would not rely only this, or any other stand, for dishing if at all possible (that's why dishing tools are made). I often will hold the indicator/pointer still and observe the rim/roller gap and not rely on the swing action of that indicator/pointer at all. How much deviation from the scribed line (red for lateral and a scratched one that didn't show well in the pic for radial) compares to what a dial indicator might show is not something i care about. What is nice for a beginner is the indicator/pointer will swing to the same side that spokes would need tightening to bring the rim and pointer in line (for the lateral work). This is easier to remember for a newbie that the "looking in a mirror" aspect of which way to turn what spoke. Once the wrench gets comfy with truing this aspect is a needless one.
Having said that, I would not suggest a Preciray for anyone getting into wheel work these days. It won't handle modern axle designs and specs well and can't be used with a tire mounted. If all one was to work on are "classic" nutted and QR hubs of common widths than it is great. But to limit oneself so much WRT future spec drifts in not a good choice IMO. I do suggest a TS-2 (and only a TS-4 if really wide tubeless tires are in play). Save your $ and get both a TS-2 and dishing tool. Andy
AndrewRStewart
Old 03-01-23, 11:17 AM
CliffordK
CliffordK's Avatar
Quoted: 18378 Post(s)
Liked 4,512 Times in 3,354 Posts
I think you came up with a similar solution, but slightly different implementation on the VARS truing stand to what I did.
Stock Stand:
Modified Stand:
Most of the rims I true are narrow rims. But, in theory I could make this adjustable.
The bar on the right is for side to side wobble. It doesn't significantly impact the accuracy of that indicator as it pushes straight right & left.
However, What it does is push the wheel all the way to the left. So the bar connecting to the radial true/hop indicator is extremely short. That maximizes the sensitivity of that indicator.
And I still have everything in the original spot, so spot on with the reference lines on the gauge.
It gives the gauge extreme sensitivity, and I can view oscillation between a tight spoke, and the area between the spokes.
CliffordK is offline
Likes For CliffordK:
Old 03-01-23, 11:27 AM
79pmooney
79pmooney's Avatar
This nicely sums up why I'm in no rush to get a fancy stand. My shop does everything, not just bikes. I am often moving everything around so I can build this or temporarily store that. My big workbench has two semi-permanent items bolted to it. A drill press and a vise. No way is anything else going on other than fastened with clamps. Bike bench is just a mechanic's drawers with a table top and back I made. My current el cheapo stand folds up to almost nothing and can either be stashed in a box or drawer or hung from a nail. I prefer building wheels in my dining room. Good light, comfortable chair, music. Shirt sleeves comfortable. (I have to dress for the unheated garage.)
Now, if I want to take a quick look at a wheel, the stand is just steps away from the workbench. To grab, unfold and set on the bench takes seconds.
Yes, a better made stand where things stayed put when I removed and replaced the wheel would be nice. A stand where the axle sits more reliably in one place every time. But if that meant heavier or harder to fold, it would be a barely at most overall improvement to my life. And fun! That el cheapo stand has built a lot of really good wheels. Early on a set of GP4s laced to Sanshin Pro-Am hubs with bladed Wheelsmiths. Rear rim collapsed at 17,000 miles of Pacific NW riding. (That "Pacific NW" was the culprit. No sidewalls left. I could have read newsprint though them.) In that 17,000 miles I might have touched each wheel with a spoke wrench twice.
Old 03-01-23, 03:10 PM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times in 407 Posts
Not having seen them before but it always seemed logical to me that a truing stand, if it has dial indicators, they should have roller tips. Did you make those? A truing stand is one tool I do not have yet but is on my list... dial indicators would, I presume, be a great help (and show me how far off my "by eye" touch-ups while still on the bike are ).
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
tiger1964 is offline
Likes For tiger1964:
Old 03-01-23, 04:16 PM
Andrew R Stewart
Dial indicators will have a significant amount of dial needle jump, with or without roller tips. But like the VAR's pointer that of the dial is an easy feedback device to learn with. Perhaps continue with. I have found some people like that visual feedback, others can work with the audio of a simple finger (of the stand) against the rim. Few initially look for the gap between that finger and the rim. I like to have some back light so better see this gap.
This Park stand is at least third one I have dealt with that had dial indicators. Each time I think they would be a nice addition and after a bit of use I discount their presence and find "watching the gap" to be what I do. But this is like so many other tool preferences. The best way to figure what you like is to try different ones. Andy
AndrewRStewart
Old 03-01-23, 04:49 PM
awac
awac's Avatar
Quoted: 69 Post(s)
Personally I use the calliper arms to get close, and the noise of the rim touching them. The white patch on the calliper arm is helpful to see the gaps. Once I am close I put the dial indicators on and I find them a great aid, especially for even spoke tension, it allows you to watch the rim move, keeping an eye on both lateral and radial at the same time.
It all depends what you are after, I like the challenge of getting as close as I can (we are all on the spectrum, just depends whereabouts….lol), again and again….I build wheels for fun and friends, when I retire it will be for friends of friends as well!
Build a wheel to do a job, that’s cool, but I have to satisfy something in me while I do it. You choose why you do it.
awac is offline
Old 03-01-23, 05:27 PM
Garthr
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times in 127 Posts
Hey, that's a nice mod awac ! Bravo.
I agree, we all have our reasons for what we do. No explaining necessary or even possible.
I bought a Unior 1689 recently to start building again after letting someone else do it the last 25 years. I really like it, it's relaxing, calming, it's like art .... painting a portrait as the wheel itself. The 1689 stands stable on it's own, that's why I chose it. It's "good enough" for what I do.
Garthr is offline
Likes For Garthr:
Old 03-01-23, 11:02 PM
CliffordK
CliffordK's Avatar
It looks like all my old images have come back!!!
Here is my nephew working on truing a wheel using the stand that my father made many years ago.
For one reason or another, the stand wasn't designed to be adjustable for wheel width. But, it has enough flex that one can jam front or rear wheels in.
A pen will work as a reference point. Although at one time I found that old BIC razors made the best tone when the wheel hit the reference.
Unfortunately it is very difficult to adjust axial and radial at the same time, so radial accuracy tended to suffer some.
Old 03-03-23, 03:16 AM
awac
awac's Avatar
Quoted: 69 Post(s)
I like Unior tools, their stand was always on my radar. Good to hear a recommendation for it.
Perhaps any others on here can give their opinion on stands they have bought, or made from plans, either their own or bought.
My Park Tool came along at the right price from someone who had an idea to wheel build during covid, then when they could get out again decided that staring at a revolving wheel was not a fun thing to do (I don’t understand them…). I am very happy with it, it also came with the centring gauge, which in my opinion should be included in the price of a new one. An accurate stand gets more new sales for the company. Mind you, what do I know, they are making more money than me! Lol.
I always check my work with a dishing tool, but I am always very, very close using the callipers. It feels like it will last my lifetime. Just as important is that I like the tool! A tool that I like becomes a pleasure to work with, and work becomes leisure.
awac is offline
Old 03-19-23, 10:25 AM
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
Liked 632 Times in 229 Posts
my addition to my home built ( a gift to me) truing stand has been to add a light that shines up between the wheel and the adjustable reference blade so that the gap is easy to see. Without it the shadows make observing the wheel runout very dificult.
capnjonny is offline
Likes For capnjonny:
Old 03-19-23, 02:33 PM
awac
awac's Avatar
Quoted: 69 Post(s)
I have been thinking of that, the eye sight is not as good as it once was, come to think of it, nothing is as good as it once was! Lol. I have a flexi-stand light that I direct but it never seems to be in the perfect place! I might have to make the effort now you have suggested it! So much to do, so little time!
awac is offline
Old 03-27-23, 07:06 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
I occasionally build electric hub motor wheels. The 12 mm axles with 10mm axle flats have a very annoying habit of trying to climb out of the V slots making the truing process a pain.
My fix was to modify a set of old style adapters that were designed to accommodate 29er wheels with tires in a TS2.
I cut slots to accommodate the 10mm flats and now I can spin the wheel both ways and the axle stays firmly seated.
Dan Burkhart is offline
Likes For Dan Burkhart:
Old 03-30-23, 12:25 PM
awac
awac's Avatar
Quoted: 69 Post(s)
Nice modification!
awac is offline
Old 01-06-24, 08:43 AM
awac
awac's Avatar
Quoted: 69 Post(s)
Now this is something I have been promising myself for a while, and pulled the trigger on it just before Christmas.
An Islandix truing system, from the website, “Islandix Wheel Analytics reads data from digital indicators and creates useful visualizations for wheel building”.
https://www.islandix.com/
I am so excited, my days off this week are now planned, so you will have to wait to see the set up. It is not cheap when you add up everything you need (nothing good is), but really as a small manufacturer, the price is extraordinary when you factor in research, development, manufacturing & post!
I have a raspberry pi 400 keyboard to power it all up and a large TV screen on an adjustable bracket. One of the main reasons, large dials, don’t have to wear my glasses all the time is the thinking!
As ever the import and tax hurts £80.02p. Glad I am paying enough tax to subsidise the multi-billion pound corporations who are not! (You know I heard on the radio here the other day, the UK tax payer is subsidising the tax bill of said corporations to £100 billion a year, and the health service which is in a precarious state “only” needs £55 billion over 15 years to make it good again. Sorry I digress).
Yes, it was a three biscuit moment…..
Islandix package
Islandix package
awac is offline
Old 01-06-24, 09:35 AM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 839 Post(s)
Liked 1,258 Times in 663 Posts
@awac I am looking forward to hearing your experiences with that Islandix system, super cool.
/markp
mpetry912 is offline
Likes For mpetry912:
Old 01-06-24, 09:45 AM
wheelreason
Quoted: 503 Post(s)
Liked 634 Times in 374 Posts
Truing stand provides it's fun at the cash register, no mods required...
wheelreason is offline
Old 01-06-24, 02:14 PM
awac
awac's Avatar
Quoted: 69 Post(s)
/markp
Now Mark, I know you like a well made piece of kit, so will let you know my thoughts. I have Tuesday or Wednesday pencilled in, anyone knocking at the door will be ignored, phone switched off, biscuits ready. I bet it is a bright sunny warm day, after weeks of wet weather……..!
Mark.
awac is offline
Likes For awac:
Old 01-06-24, 04:34 PM
CliffordK
CliffordK's Avatar
How much was the Islandix? All I'm seeing is the deposit + shipping.
Old 01-06-24, 05:45 PM
awac
awac's Avatar
Quoted: 69 Post(s)
£308. The extra £80.02p was my charming government. Is Canada to US the same import tax and vat?
You then need a pc to run it, I have an old laptop that would work, but it is bulky so bought a raspeberry pi 400, amazing thing, turns a old tv into a smart tv by using it as a monitor, lots of uses, first seen it suggested on Islandix site blog, £110ish new, lots of cheaper used ones on ebay.
https://www.islandix.com/blog/page/2
https://www.raspberrypi.com/
Then Mitutoyo cables, they are not cheap in the UK, £50 each, but found 2 new and unused for £40.
Mitutoyo gauges, are expensive, on the Islandix site he suggests the option of igaging. I dropped lucky on auction, someone had put wrong serial number and I scooped it up for £40 and another for £60.
https://www.islandix.com/blog/catego...tors?order=asc
Oh yes, a screen or monitor. Mine was free from a friend upgrading his tv.
There is an optional twin port for a digital tension-meter which is £200. You don’t need it, you can swap ports to do the tension, but obviously if you was in a fast paced environment you might want it, as the company owner Ryan points out.
If you then add it to the cost of a truing stand & tools, you have to be prepared to make that investment.
I know some people are going to say why? So let’s get past that, why not? I love tools and building wheels. It is a hobby, but when I retire I will keep building some to supplement the state pension we have here, the big screen=big gauges=no glasses! I am not rich but I have a little metaphorical jar I put away a bit each month, and when you have just got past the big “C”, you fair run with it to the sweet shop, lol!
Is it worth the cost? Now that is a fair question. If it does what I bought it to do, then it was a bargain. I will let you know. This is a big leap for an analogue loving mechanical dinosaur. I liked it because it projects bigger analogue looking dials! I know, I know…
Goodnight everyone, up for work in 7 hours!
awac is offline
