Tire dust-leading source of environmental pfas contamination
Quoted: 92 Post(s)
Liked 20 Times
I was watching an informational video advocating against artificial turf which is just another source of plastic toxicity in the environment.
https://vimeo.com/803691477
The expert mentioned that tire dust is the leading cause of pfas contamination in the environment. The EPA just set a threshold of 4 parts per trillion for pfas substances:
https://www.epa.gov/sdwa/questions-a...%200.004%20ppt
Are we being contaminated potentially by breathing in tire dust?
Cop Magnet
Microplastics have infested everything down to the cellular level. I don't think we have a good way out of this mess in the near future.
Likes For JW Fas:
Quoted: 3777 Post(s)
Liked 1,047 Times
And some are saying that EVs will make the problem worse, since they are a much heavier than conventional cars, therefore quicker tire wear.
https://jalopnik.com/tire-pollution-...oad-1849490346
Electric cars may have zero tailpipe emissions but they still emit noxious waste through their tires. Really, all cars shed pieces of spent rubber when they drive along roads, as rubber and other toxic compounds in tires are ground away.
Since EVs are heavier and they accelerate faster than ICE-powered cars, they chew up tires faster and shed more of these dirty particles, or tire emissions. But a London startup called the Tyre Collective is trying to clean up after rubber-burning EVs — and ICE-powered cars, too — with a device called the “box” that bolts on after the wheel. It’s basically a catch-can for tire emissions.
Likes For work4bike:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
The EPA limit was for drinking water. I have no idea whether this stuff gets airborne in any significant amount. This would be one component of many in road dust, which contains all sorts of stuff primarily from brake pads and solids coming out of tail pipes. Worth discussing, but really involved questions unlikely to affect your own behavior much.
Quoted: 96 Post(s)
Liked 292 Times
I believe it was in 1969 that Mason Williams, in his book Mason Williams Reading Matter posed the question of 'what happens to all the worn off tire dust'.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Tragically Ignorant
Liked 9,098 Times
Hey liar, I thought you had me on ignore. But then you reply to a post that wasn't aimed at you just to insult me just because you have a grudge.
I'm perfectly comfortable stating I don't know something, while you are perfectly comfortable making things up to make issues cycling-relevant. Nice try.
My only substantive point there was that the EPA standard didn't have much to do with the question being asked, but like I said in your thread, I think someone starting a thread about road dust in a cycling forum would make sense.
Got anything constructive to add to this discussion? Any data on pfas-contaminated dust becoming airborne? Didn't think so. You'd rather say in one thread that I'm not worth bothering with, then go out of your way in another thread to lamely insult me yet again.
Punk Rock Lives
Location: Throughout the west in a van, on my bike, and in the forest
Bikes: Long Haul Trucker with BRIFTERS!
Quoted: 119 Post(s)
Liked 45 Times
Tragically Ignorant
Liked 9,098 Times
Yup. One of the things I always notice is the smell of overheated brake pads from cars and RVs (not trucks, they know how to use their transmission for braking) as you come down long, steep passes. To be honest I lean on my bicycle brakes a lot myself. Do bike brake pads release nasty stuff?
Seems doubtful as there's just so much less energy involved.
A great deal of microplastics are created by the current recycling practices. Less than 5% of plastics is ever recycled and there are good substitutes for 99% of it. The microplastics are found in over 75% of fish tested and in the human body the chemicals leach out and alter normal body functions as many of the chemicals are hormone mimickers.
The good news is the increasing levels of male sterility and so the problem of human caused environmental destruction may fix itself over time.
Quoted: 4806 Post(s)
Liked 3,931 Times
Edit: Good thing was that I added just relatively inert aluminum dust to the environment in that experiment. That and skin and blood; a feast for a few microbes.
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,442 Times
Quoted: 18378 Post(s)
Liked 4,512 Times
Time to return to natural rubber from trees?
Tragically Ignorant
Liked 9,098 Times
They definitely wear, but "proportional" is a problematic word. Motor vehicles are both heavier and faster, and since the kinetic energy increases with the square of the velocity, that's a heck of a lot more friction on the motor vehicle pads.
Likes For livedarklions:
Quoted: 5791 Post(s)
Liked 2,581 Times
Since this is a bike forum, the real question is whether this is a specificly unique issue for cyclists.
The answer is no. We're no worse off than any living, breathing or drinking animal.
For better or worse dust is ubiquitous, and it'd be hard to say which of its components is worse for anyone. However, here we are drifting from rubber tire dust, to micro-plastic pollution, and.....
Not that these aren't real concerns, but as a cyclist, I'm far more concerned about the living, breathing humans I share the road with.
I'm not a moderator, but politely suggest that we should try to stick to specific bike related issues, rather than drift off into environmental, or other issues that are more universal.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Q. Does this tire crumb contain per- and polyfluoroalkyl substances (PFAS)?
The study did not specifically test for the presence of any PFAS target analytes. No PFAS chemical was identified in the non-targeted analyses (see Section 4.12).
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,219 Times
Natural rubber from trees is already used in tires. It makes up about 19% of the total weight of the tire while synthetic rubber makes up about 24% or they are about equal in terms of rubber used in the tire. That’s for car and light truck tires. Heavy duty truck tires have 34% natural rubber/11% synthetic. Natural rubber provides tear and fatigue crack resistance while the synthetic rubber is used for the rolling resistance, traction, and wear characteristics.
Stuart Black
Stuart Black
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
What does this have to do with cycling? The nimrod driving a diesel pickup "rolling coal" on you is going to get you before his tire dust.
Quoted: 92 Post(s)
Liked 20 Times
Sorry to hurt anyone's feelings. When I heard that tire dust is the leading cause of microplastics and pfas contamination I was a little concerned on how it would affect human health, through breathing or other sources. Now that people more knowledgeable than myself have chimed in I'll have no qualms about hitting the roads again.
Microplastics have been found at high levels in wilderness areas far from any obvious nearby source, IOW, yes it becomes airborne and is distributed everywhere.
Single use plastics are the primary source of microplastics and much can be generated from inefficient plastics products recycling. Only 5% of recyclable plastic is actually recycled into new products and the rest is burned or dumped. I do not buy anything that comes in a single use plastic container. It is better for my personal health and better for the environment.
Micro plastics from tires are a problem but a bigger one is the 99% of the tires end up in a landfill dump. We pay a "disposal fee" for each new tire for our vehicles but that money never goes toward recycling tires but instead ends up in our state's general fund. Twenty years ago there was a major tire recycling plant in my state but it was closed as it did not produce enough of a profit. Capitalism is what is killing the planet, when profits come first and people come second and the environment is not considered at all.
Tragically Ignorant
Liked 9,098 Times
This really seems like a tail wagging the dog thread.
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
I'll do the same. We can form a splinter group.
