new BB w/ old c-record?
Quoted: 804 Post(s)
Liked 2,985 Times
greetings.anyone use a modern 70 x 111 mm Centaur Bottom Bracket Square Taper with a mid '80s C-record crank? description reads "*Fits Daytona, Racing Triple, Centaur, Veloce and Mirage, 1193 and later Athena and pre-1995 Record and Chorus". any hands one experience here? thanks.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
So long as it is the correct taper and length you should be just fine.
Likes For veganbikes:
Quoted: 5792 Post(s)
Liked 2,582 Times
The spindle must extend to 2mm or so below the end when tight. Too long and you can't tighten it, to short and the crank isn't properly supported.
On the bright side, Campagnolo has been fairly consistent in taper dimensions over the years.
Likes For FBinNY:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
Agreed. A lot of these mix and match combos especially across component generations can only be validated with a "try it and see".
measure the overall length of the spindle and compare to the old one.
/markp
/markp
Likes For mpetry912:
Quoted: 4409 Post(s)
Liked 1,565 Times
Specific to the OP's question, the C-Record, Croce, Chorus and Athena of that magic era all used 111mm BB spindles with what was later called "ISO" taper. So that will work.
Likes For Kontact:
Quoted: 506 Post(s)
Liked 639 Times
Agreed. But if the old axle is marked for length (and it almost certainly will be) then all you need to do is get the same length axle. Taper will both be ISO and therefore identical.
Liked 1,565 Times
Quoted: 804 Post(s)
Liked 2,985 Times
update.
a centaur bb came up on fleabay in Ita for a price worth gambling on to try a Triumphe crank & keep the Pinarello more oem correct.instructions said was made to work with 10-11 speed groups.after installing the tapers seated as they should & being the cranks were made to work with 114bb the new 115.5bb. chainline is 43.5 centered,as Sheldon Brown recommends.so old does jell with new.
