Ultegra Di2 12speed cables
Old 03-11-24, 04:28 AM
lupo68288
Quoted: 26 Post(s)
Liked 5 Times in 4 Posts
Hello everyone,
I have a bike with the newest Ultegra Di2 (12 Speed) and I want to update the lever firmware. So I need to wire the lever with the system. My Idea is to remove the cable from the front deraileur and wire a new cable with a junction Box to the lever. Now my question is, which Cable Type do I have. I know that there are 2 Types, the EW_SD300 and the EW_SD50. The EW_SD300 is more expensive. If I have the EW_SD300 installed, is it possible to get a junction that adapts the EW_SD300 to an EW_SD50 and put the EW_SD50 in my lever or do I need a EW_SD300 Cable to get the firware updating?
lupo68288 is offline
Old 03-11-24, 07:07 AM
Kai Winters
Quoted: 242 Post(s)
Liked 455 Times in 266 Posts
https://www.nashbar.com/shimano-ewjc...jc302/p1298030
https://www.nashbar.com/shimano-ewsd...5304?v=1292457
These are the two components you need. Connect one end of the wire to the shifter and the junction to the other end. Connect the junction to the front der wire and you will connect that shifter to the etube app...switch the wire to the other shifter and repeat.
This is how I do it and it works great.
Kai Winters is offline
Old 03-11-24, 07:28 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
The guy that does this site seems to know....BetterShifting
Iride01 is offline
Old 03-11-24, 08:39 AM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times in 694 Posts
If you know anyone with a SM-PCE02, it plugs directly into each brifter for updates.
I like having one, though most think of it as a shop tool.
Barry
Barry2 is offline
Old 03-11-24, 10:32 AM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
The disc version needs this I take it? Can’t do it wirelessly?
choddo is offline
Old 03-11-24, 10:45 AM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
The 12sp mechanical (rim) brifters are wired and not an issue for updates.
The 12sp Hydraulic brifters are capable of both wireless and wired.
When these are wired... no issue for updates
When these are wireless, some updates cannot be performed wirelessly and require the brifter to be temporarily wired.
Barry
Barry2 is offline
Likes For Barry2:
Old 03-12-24, 06:44 AM
Shadco
Resident PIA
Shadco's Avatar
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times in 186 Posts
Don’t know about anyone else’s situation but my battery is in the seat post I just pop it out and run a 1.2 meter Di2 wire from there to the lever and do the updates, then pop the seat post back in. It’s 1 bolt and I have the seatpost marked easy peasy.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shadco is offline
