Shortening a spoke
Shortening a spoke
Old 10-22-06, 02:23 PM
ppc
Senile Member
Shortening a spoke
Hello everybody,
Here's my problem : a friend of mine rides on a 20" wheeled recumbent. The rear wheel is strangely laced and uses custom-made spokes with a special lengths. He broke a spoke this week-end and wasn't able to get a replacement at the LBS. Unfortunately, he needs his bike to commute, and asked me if I knew how to make a replacement spoke in a hurry.
Since I don't have a thread rolling machine, I thought about shortening a standard spoke at the elbow end, then forge a new elbow and swaged end. Of course, that would require heating the spoke and therefore removing any heat treatment it might have received.
So my question is this: does anybody know exactly what kind of heat treatment spokes receive ? I assume the metal needs quenching then annealing and/or stress-relieving, but I don't know the exact tempering temperatures for stainless steel, and I don't know if this would work for cold-drawn steel, or even if spokes need any heat treatment at all.
ppc is offline
Old 10-22-06, 02:27 PM
gwhunt23
No bike shops around you have a spoke cutting and threading machine? I'd check that first thing Monday. In the meantime though, true up the wheel best you can (you should be able to get it pretty straight despite a missing spoke unless it's a really low spoke count wheel.)
gwhunt23 is offline
Old 10-22-06, 02:36 PM
ppc
Senile Member
That's what I told him to do yesterday. He went to all our LBSes in our area, a grand total of 3 in a 20 mile radius, but no luck. Bike shops around here aren't much good besides selling new bikes and doing simple repairs.
I'm not too worried about the wheel, but he's not too light and his commute route is a nasty tooth-rattling paved road that makes Paris-Roubaix look like a walk in the park.
ppc is offline
Old 10-22-06, 02:38 PM
Landgolier
THIS SPACE FOR RENT
I might try this as an experiment, but I wouldn't send someone riding off on it and call it "repaired." Call around and see if you can't find a shop with a spoke cutter/threader. Also call all the shops that do a lot of BMX business, they're likely to have a lot more of the shorter spokes that 20" wheels take.
Landgolier is offline
Old 10-22-06, 02:39 PM
Landgolier
THIS SPACE FOR RENT
Also, post up where you are, you never know who's hiding under a rock near you.
Old 10-22-06, 03:13 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
I'd try wheelbuilder.com. If you need a goofy spoke he might have it or be able to make it. Once you add on the shipping, however, it isn't going to be cheap.
Retro Grouch is offline
Old 10-23-06, 04:31 PM
SaabFan
The AVatar Ninja
SaabFan's Avatar
Here's a good temporary repair so your buddy can commute until you can get a correct-length spoke.
Get a spoke that's too long, and cut the elbow off. Figure out how long it needs to be, and make a Z bend where the new elbow should be. To do this, make one 90 deg bend a few MM from the length, then another right at the length. The "at length" bend is there to emulate the elbow itself, allowing the spoke to pass through the hub. The other bend emulates the flared end of a real spoke, keeping the elbow from slipping out. If you're having trouble visualizing what I'm talking about, go to a hobby shop that deals in R/C stuff and ask them about a Z bend. People use them to connect servos to other controls on R/C stuff all the time. They even sell special pliers to kink wire into the Z bend shape.
The best part about this sort of temporary spoke is that you can thread it in without disassembling the wheel at all. You can re-use the existing nipple without removing the tire, and you can simply wiggle the Z-bend into the hub. Here's a photo of what the Z bend should look like:
SaabFan is offline
Old 10-23-06, 06:06 PM
thomson
thomson's Avatar
Maybe Phil Wood knows who has his spoke cutting machine in your area.
If you are going to cut the elbow off a spoke, I would not use a butted spoke. Perhaps obvious.
thomson is offline
Old 10-24-06, 10:44 AM
Trakhak
Trakhak's Avatar
Quoted: 2483 Post(s)
Liked 2,955 Times in 1,678 Posts
[QUOTE=SaabFan]Here's a good temporary repair so your buddy can commute until you can get a correct-length spoke.
The best part about this sort of temporary spoke is that you can thread it in without disassembling the wheel at all. You can re-use the existing nipple without removing the tire, and you can simply wiggle the Z-bend into the hub.[QUOTE]
Excellent suggestion. The Z-bend spoke modification was used as long ago as the mid-'70s by savvy BikeCentennial cross-country tourists, who often carried the modified spokes by shoving them into their handlebars, knowing that a few more bends wouldn't hurt. I've never heard of a Z-bend spoke failing at the hub.
Trakhak is online now
Old 10-24-06, 11:41 AM
SaabFan
The AVatar Ninja
SaabFan's Avatar
The trick with a Z bend is getting it crisp enough. If you don't, it'll be sloppy enough to fatigue and break in no time flat. That's why the special pliers come in handy, they make a really nice, tight bend.
SaabFan is offline
Old 10-26-06, 11:33 PM
mike
mike's Avatar
SABfan's response is obviously from a guy who has been around awhile. Nicely done, SABfan.
The bike essentially hangs from the rims rather than being lifted. So it is also quite possible to use a long spoke, thread it through the hub eyelit, and bend it around like a hook. It is a bit tricky to do this and get the length right, but it can be done.
I have done this and enjoyed thousands of miles out of the cobbed spoke without incident.
mike is offline
Old 10-26-06, 11:45 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
Go to store and buy a fiberfix kevlar spoke ~ $15.
operator is offline
Old 10-27-06, 10:38 AM
TheBrick
Tinkerer since 1980
TheBrick's Avatar
Bikes: Coppi racer, Old school BMX, some random a fixed wheel convertion
See if you can find a small engineering work shop or a garage or friend with lotts of tool simlar that may have a small enough die to cut threads down a long spoke.
TheBrick is offline
Old 10-27-06, 11:08 AM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
Hozan makes a threading tool for about $100 and you can cut the spokes with a dremel.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
