Building a 12 pound fixed speed bike. Possible?
Quoted: 761 Post(s)
Pardon my intrusion into your illustrious forum! I am contemplating to add a fixed bike to my stable and I think a light one I can ride fast would do the trick.
I like to build bikes and thought a 12 pound fixed speed bike would be a nice project. I already have a 17 pound CAAD12 so I want this one to be extra light.
I figure 4 pounds for the frameset, 4 pounds for the wheelset and tires and 4 pounds for the saddle,post,bars, stem etc is doable.
But when I look at the bikes on offer (i.e. Kilo TT) they are all close to 20 pounds which seems odd as my CAAD only cost $1300 and has a full 5800 groupset on it. That groupset weights 5.5 pounds and if you subtract the crank and chain it would weight 3.5 pounds.
So is a 12 pound fixed speed bike doable and is it desirable (i.e. does having weight add something). I'm riding this on the road/MUPs not on a track.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
Doable, yes. It’s just a matter of $. However, for your needs, it is really not necessary. Weight matters only when climbing hills and accelerating. Far more important is wind resistance, which is a function of body position, not bike weight.
Quoted: 761 Post(s)
I'm a bit puzzled by the lack of light-weight track parts. In the road bike world my CAAD12 frameset weights 1500 grams (frame and forks) and cost brand spanking new $650. But a lot of the ALU track framesets are upwards of 2000grams and cost more! Also, the lack of lightweight clincher track wheels is puzzling. I see lots of 1900 gram wheelsets by Campy and Mavic but not only 1500 gram ones.
Am I missing something or is weight not seen as that important in the track world?
Veteran Racer
Liked 765 Times
Generally speaking, strength and stiffness are more important than weight in track racing. Also, the emphasis is more on aerodynamics for timed events such as the pursuit.
As far as lightweight track wheels, they are readily available at affordable prices from companies like Wabi. I own a 15 lb Wabi Lightning fixed gear, which has an aluminum frame and mostly aluminum parts, although it is a small 650c wheeled version that is lighter than a larger bike would be.
Bikes: Tern Link A7 Folding Bike, Marin Gestalt 2019
Quoted: 73 Post(s)
I recon you can make 12lb fixie that's actually nice to ride for under $1500 with clinchers, bullhorns, and a front brake.
enginerd
cheapest route would be finding a used carbon road bike on craigslist, stripping off the drivetrain and building some light-ish wheels (all city sheriff SL and 300g kinlin rims?).
should be able to do 15lbs for maybe $1k? helluva lot cheaper than building a 15lb road bike.
Veteran Racer
Liked 765 Times
Quoted: 1332 Post(s)
Liked 398 Times
Bingo. There are no hills on the track. Some riders in international competition actually have to add weight to their bikes to meet UCI regulations because track bikes just wind up being lightweight due to having far fewer parts.
Quoted: 761 Post(s)
But why. If I can get a 1500g CAAD 12 frameset for $650 can't I get a 1500g fixie frameset for as cheap?
I can buy 1500g campy Zondos for my road bike for $400
So that's 3000g for the main parts of the bike.
For tires/tubes add 500g
Cog/chain/crankset 1000g
Seat post and saddle 500g
Handle bars 350g
So that's 5.35 kilograms which is about 12 pounds?
Veteran Racer
Liked 765 Times
Pedals, stem, front brake...? It all adds up. Do the cranks include a bottom bracket ? I suggest you make a detailed list of every single part that you need to build a complete bike. Even little stuff like bar tape and toe clips/straps weighs something.
Quoted: 4806 Post(s)
Liked 3,932 Times
You have the advantage now of carbon fiber for the frame, bars and stem, crankset and wheels, allowing you to get to same weights at far less (very expensive) labor.
Ben
But the speeds are high and aerodynamics are important, so high-end track bikes tend to burn lots of weight on aerodynamic shaping.
Very doable. Consider that there are full-featured production road bikes that weigh less than that. And no, there's no magical performance issue that crops up from a bike being "too light"; super-lightweight bikes feel great to ride, and to carry, and whatnot.
The question is just how much you're willing to spend to get the weight down.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Handle bars 350g
Handle bars 350g
Alibaba has sub 1500 gram Chinese carbon track frames for between $400 and $600 all day long.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
I bet some custom frame builder would love to build a super light version of that little red bike and someone who does cranks as well could probably make something pretty neat with like a splined WI fixed cog mounted to it. Plus with the tons of lightweight parts out there you could really have some fun.
Quoted: 73 Post(s)
I can only find Pinterest links to the picture, but no details anywhere of anyone doing something like it. But it looks proper fun!!
Clark W. Griswold
Liked 4,000 Times
That is a cool bike I actually wouldn't mind one of those with maybe a Rohloff for a sweet whackadoo touring thing.
