Zefal pump disassembly
Did a search and couldn't come up with anything. I'm looking to paint an old Zefal frame pump hpx and need a little help on disassembly. Any diagrams or instructions out there?
Tim
Tim
At the pump handle end, you have a black or silver threaded piece that holds the shaft into the body. Under that, I believe you have a long spring. At the valve stem insertion end: First a large black or silver approx. 1/2 wide medal threaded cap. Under that,if you are set up for presta , there is a black rubber 1/2 " thick spacer, followed by a short spring and washer. Schraeder is the black rubber spacer, a small black cone shaped spacer , than the spring and washer. Not sure if the lever comes out, but if it does there should be a small threaded nut on the end holding it in. Best thing to do, obviously, is to disassemble everything in order , and draw a picture of all as you take it out. I may not be 100% on this, but I hope that this wll help.
Tim
Jack
Bikes: '89 Trek 800 Antelope, '81 Torelli Corsa Strada
Anyone know how to disasseble the handle end of the HPx?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
You've had 9 years to work on it. Any luck ?
Jack
The last time I saw my HPX it was about to go under a truck tire. I had to cover my eyes. Good bye old friend.
Jack
handles are on the plunger there is a threaded ring to remove the plunger.. from the barrel
as I recall the handles were fixed to the plunger in the factory while it was manufactured ..
though the last one I've seen was 25 years ago so memory has faded some..
Quoted: 4806 Post(s)
Liked 3,932 Times
I too would like to be able to take the handle end apart because one of my HPXs and my new Classic both have handles that rattle on less than perfectly smooth roads, sounding just like loose headsets. Or maybe someone here knows how to stop that rattle.
I make the rattle a little better by reducing the vibration transmitted. Both pumps are mounted on brazed on headtube pegs. I cut a say 10" x 3/4" strip of inner tube and stretch the strip over the pum end, holding the handle and stretch strip with my left hand as I put a 1" wide tight fitting innertube ring over the last inch of the handle. Last, I cut the stretched strip with scissors and let it slide back out of sight under the ring. With black pump handles, you don't even see the innertube and it makes the mount much more secure and quieter.
Now if I could just get the pump itself to shut up!
Ben
Ben
Pour in epoxy? use a padded pump strap or 2 to secure the pump to the frame..
I use a twofish strap to keep my Silca Impero from falling off ..
add some inner tube sourced tubing over the pump , that will slide off easily when you need a pump to pump.
Quoted: 1324 Post(s)
Liked 927 Times
I just looked at my Zefal HPX and i see 2 notches on the inside of the pump handle. i don't know if that unscrews (I think it does) or if it's a press fit.
Do you really need to take it apart (and risk breaking something) just to paint it/
Cheers
Cheers
Jack
I'm in the process of turning a #4 into a #3 length - in polished Al. I have the option of shortening the inner rod at the seal end, or inside the handle. Inside the handle would be neater, and give me the option of dampening the vibrations of internal parts to stop the rattles.
Removing the pump head was easy with a homemade long screwdriver made from a 3/8 rod with the end ground down. The front grip removes easily with GooGone dribbled into it. It softens the glue (after about an hour), allowing it to be pulled off.
Next up is shortening the barrel, but saving the rounded end and hex hole, and machining a sleve plug with the same internal volume as the rounded end (wich sets the max pressure it will reach). Then it gets JB Welded together. Sounds like a lot of work for a $40 pump, but the engineering challenge is where the fun is.
Jack
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Time to necro this thread with an update and some pictures!
I bought an old HPX size 4 a while ago for very little money and I too wanted to dissasemble it to polish everything.
So let's tear it apart to figure out how it works.
As several have mentioned before, the inside of the pump handle has two notches. Don't bother with those. My guess is they use two parts to slide it in there instead of making it out of a single piece. No amount of turning seems to do anything.
What you should be looking at is the cap that switches between modes. It is made of a very tough plastic (probably nylon or something) and is held together with a small barbed piece in the switch itself.
The switch is a single piece connected to a long square rod that does the actual switching.
I decided going the heavy handed approach and grabbed a locking plier. Lock it around the switch tightly and just leverage it down, as if to break it off.
(Don't forget to put some protective layers around the plastic switch or you will scratch it up.)
I had the head at a 45° angle at some point and then it just popped off.
Do not twist it around. It will round off the square rod and make for a sloppy feeling switch.
The barbed piece will have popped out and you can use a small screwdriver or a corkpuller to take it out entirely.
Clean and polish everything you want and put everything back together. Push the barbed piece in using a screwdriver of something similar and you're done.
My suggestion would be to compress the pump in its X-mode or to scratch something to make it clear where to put it. Then again, it probably doesn't matter where you put it as it is a square switch anyway.
Pictures:
Good luck!
P.s. I have a brand new HPX on the way and I will try repeating these steps on that one. See if the steps can be reproduced.
I can make a short video of it if people are interested.
Pictures:
Good luck!
No idea this thread has been around so long. Originally I just want to know how to get the AL body off of the plastic to paint it to match a frame it was going on. The handle is easy because is unscrews from the body. The plastic at the bottom is either glued or screwed to the AL body.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Since I have a tendency to buy brand new stuff and take it apart to do some foolish thing with it this was a perfect opportunity for me to get my hands dirty.
I just hope some lost soul runs across this thread in the future when they have the same question.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
I recently saw a youtube video on this pump.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
For those interested:
Disassembled head. The silver screw in the bottom is what you have to unscrew with a long flathead screwdriver (or extensions) to take off the handle.
With the exception of the plastic switch and the replaceable plastic inserts on the pump head everything is basically metal (aluminium)
I'm not done yet but I have a brand new one that I want to properly dissasemble and polish (+clear coat) so I'm not putting too much effort into this one.
Does the handle come any further apart? The weight seems excessive and I would like to remove whatever is in there and just have a compression spring in the handle like and old Silca frame pump.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Mine pumps just fine, but when I compress it to mount on a frame, it sticks in compression mode. It needs more space and a more violent pull to unstick it. Have you figured out how to get that part out? Just inside the handle at the end opposite the switch.__________________
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Timely
