Threadless external headset - bearing lubrication question (with pics)
I’m about to install the fork that came with the frame I just bought. The headset was already pressed. Do I need to grease the bearings before installing, and if so with what? I have some basic Park Tool grease that I use for pretty much everything. Thanks!
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Are the cups new? If not, inspect them first by running a ball point pen around where the bearings would run. Look and feel for pitting. Then put a liberal amount of the Park grease in the cups, then work some more into the inside of the bearing cages.
And thanks for the advice!
Quoted: 569 Post(s)
Liked 581 Times
Without looking I am sure parktool.com site will show you lubing and importantly how to adjust the bearing pre-load.
Quoted: 4201 Post(s)
Liked 3,857 Times
apply enough grease so that some squeezes out on assembly and initial use. Andy
AndrewRStewart
AndrewRStewart
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...if you're installing a threadless fork and headset that has never been installed before, you need to leave it dry and do some trial assembly first, to see where the fork steerer needs to be cut to shorten it. Unless you plan on taking up all that length with spacers, in which case I guess you're good to go. But it's kind of messy to grease, fit, then disassemble to cut the fork, then reassemble.
Quoted: 2026 Post(s)
Liked 1,096 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Honestly, I’m not getting the “leave it dry” thing. Headsets are pressed in mostly dry to begin with. A little grease will make the press go easier but the grease won’t “dry”.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,379 Times
...thanks Stewart. Always good to hear your valuable insights.
