Anyone else built like this?
#52
Quoted: 850 Post(s)
Liked 344 Times
Ah ok. Then it seems to me that you just need a vintage or retro bike with a sloping top tube. That’s one of the biggest innovations in bike fit that road bikes have seen. It’s why the Giant TCR is such a big deal.
Likes For smashndash:
#53
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
I understand that you are baffled. But I can't fix that. There are so many variations to bike geometry and human anatomy that trying to stuff a square peg in a round hole isn't always possible.
#54
climber has-been
Quoted: 3427 Post(s)
Liked 3,564 Times
Answering the Question
To be right for me, my bikes require the low standover height of a 19-20" frame, but a higher seat, and consequently higher handlebars. Finding the right frame size has not been difficult, but I do need to switch out the stem for a longer one. Is this unusual, or fairly common?
I estimated some measurements from the photo:
Saddle to crank spindle: 68 cm
Saddle to pedal in down position: 85 cm
Top tube stand over height: 72.5 cm
Saddle to handlebar center: 51 cm
Saddle to bar vertical drop: 0
Comparing several other cyclists with 68 cm saddle-to-crank, I estimate that @Kross is around 5'6" in height.
I see two questions:
1. @Kross claims to prefer a low standover height, but a high saddle position. The photo supplied indicates that this is the case.
Since the estimated saddle-to-pedal distance is ~12 cm more than the stand over height, that's a very large stand over clearance. But is it "unusual"? I certainly wouldn't fit anyone on a traditional diamond frame with that much clearance.
2. @Kross claims to need a long stem to obtain the estimated 51 cm saddle to bars distance. To find out if 51 cm is unusual, let's look at other cyclists preferring the same saddle-to-crank measurement of 68 cm:
With a 51 cm saddle-to-bars and a 68 cm saddle-to-crank spindle, @Kross is indeed an outlier, with only 3 of the 75 cyclists preferring that distance or longer.
Last edited by terrymorse; 08-30-19 at 12:00 PM. Reason: fixed stand over measurement
#56
Quoted: 212 Post(s)
Liked 111 Times
@Kross wants to know if this bike fit is unusual. One way to find out is to measure it and compare to what other cyclists prefer.
Top tube stand over height: 83 cm
1. @Kross claims to prefer a low standover height, but a high saddle position. The photo supplied indicates that this is a mistaken notion.
Since the saddle-to-pedal distance is ~2 cm more than the stand over height, that's just about the minimum stand over clearance, so the saddle height is not overly high for that frame.
I never claimed I needed a longer stem, as in a long REACH stem. I needed a taller stem to get the bars to seat height.
I moved the saddle back after this photo was taken. So any measurements made from this photo on saddle-to-bar distance are also wrong. I guess I now fall further from the norm. I'm OK with that. Normal is overrated.
When I get a chance I can get you the actual measurements.
#58
climber has-been
Liked 3,564 Times
Likes For terrymorse:
#59
climber has-been
Liked 3,564 Times
Your original quote: "I do need to switch out the stem for a longer one."
There's the confusion. Long describes horizontal distance, tall describes vertical distance.
No matter. Bar drop preference runs the gamut, but regardless of how high or low you want your bars, your saddle-to-bars distance is still quite long for your saddle-to-crank length.
I saw your comment and adjusted the dimensions as if the saddle had been moved to center on the rails. Even adjusted, your saddle-to-bars distance is a high outlier.
That would be great. Please include the following:
Saddle top to ground, vertical
Handlebar top to ground, vertical
Saddle top to crank spindle center
Saddle nose to handlebar top center
#61
Quoted: 212 Post(s)
Liked 111 Times
I do need to be careful about "tall" versus "long".
#62
Quoted: 212 Post(s)
Liked 111 Times
And, unless you measured me, how would you know what my dimensions are and if they are unusual?
Come on, don't get goofy!
#63
Quoted: 212 Post(s)
Liked 111 Times
#64
Quoted: 359 Post(s)
Liked 85 Times
I believe you have.
Not directly, but definitely you are getting answers suggesting that you are not the norm.
But it is hard to say whether anyone is "built like this" when all you have posted that would allow anyone to successfully answer that is a picture of what seems to be a very poorly setup bicycle.
If you really want an answer you should provide a pic of you, maybe a pic of you riding the above-mentioned bike, and probably some dimensions (height, inseam, thigh length, lower leg length, torso length, arm length, forearm length, upper arm length).
#67
Quoted: 212 Post(s)
Liked 111 Times
I believe you have.
And I'm not about to open yet another can of worms by posting my photos and dimensions. I am almost certain to be "poorly setup". Because I'm positive there is an arm length and hair color that is or isn't acceptable.
Please let it go.
#68
Quoted: 359 Post(s)
Liked 85 Times
and yet you have "blathered on", argued back, disputed data, and not provided any additional information asked for.
Here is my answer.
Yes, I have seen lots of people who have badly setup and don't recognise (or don't want to recognise) that their setup is poor.
Again, I cannot answer your original question (and nobody else can either), because you have provided no information whatsoever about how you are built.
At the moment (for lack of any information that tells m otherwise) I am picturing someone with incredibly long legs, incredibly short arms, who is massively overweight and has no flexibility. Given that, my answer is no, I am not built like that, and I don't know anyone who is.
Here is my answer.
#69
Quoted: 359 Post(s)
Liked 85 Times
It's sad that the idea of what is or isn't a "poorly setup bicycle" is so tightly regimented. Are all bike fit enthusiasts prone to OCD?
Please let it go.
Please let it go.
#70
Quoted: 212 Post(s)
Liked 111 Times
Here is my answer.
Here is my answer.
#71
climber has-been
Liked 3,564 Times
Anthropometric studies of the human body have been done many times. For a normal person at a specific height, leg length, arm length, hand size, and torso length all fall within a narrow range. Certainly a narrow enough range to fit on a bicycle specified by rider height.
Also, I've personally gathered bike fit information and fitted thousands of people on bicycles. You're not special or unusual (at least your physical dimensions aren't).
#72
Quoted: 359 Post(s)
Liked 85 Times
I am now convinced this is a troll post, with the only person arguing being you about a topic that nobody will answer to your satisfaction.
Enjoy your tiny bike.
#73
Quoted: 359 Post(s)
Liked 85 Times
Because statistics, that's how.
Likes For sumgy:
#74
Quoted: 212 Post(s)
Liked 111 Times
Remember Mark Twain!
