Ideas for bar upgrade/extensions for comfort
Quoted: 92 Post(s)
Liked 88 Times
I am enjoying my first couple of months on my new bike after not riding for literally decades!
I have a flat bar hybrid and am very happy with it. As I start to approach 15+ mile rides, I am considering options for more comfort and hand positions to avoid stiff wrists. Not looking for drop bar conversion.
Done a bit of research on old threads but figured a “bump” on the topic couldn’t hurt in case anyone has suggestions or experience with options that worked/not worked for them.
Any help appreciated, it you can include the brand/name that would be great.
Here is the bike, CTY 1.1
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
You can do bar ends, and you can also try butterfly bars. I have this bar on one of my bikes, and really enjoy all the different ways you can use them and set them up. One advantage I think they have is you have more fore/aft difference in them. You can hold the bottom flats and sit way up, or you can hold anywhere along the sides for both a different wrist position and a different back position (similar to drops), and you can even lean way forward and hold the fronts.
With drop bars, the brake levers and shifting are available only if you're on the hoods or holding in the drops. If you're holding the top, you have to move your hands to get there. Butterfly bars are similar, except opposite. The way most people set them up, the brake levers and shifters are on the bottom flats (similar to riding the tops on a drop bar), and your more racy positions (the sides or the fronts) are without brakes or shifters. This is not unlike dedicated bar ends, where you may be riding on the bar ends and would have to move your hands over to the brakes to use them.
Fortunately, there is a ton of variety, and something out there to suit us all!
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
You bike appears to have the current handlebars set high enough in order to accommodate a more upright and relaxed posture. This would usually reduce hand fatigue for most people. You mentioned that you have just returned to cycling but you mention nothing about your mileage or time on the bike. You may still be in sort of a "break-in" period and your body is still trying to become accustomed to riding and the challenges is produces.
If not, try some bar ends or maybe even a new stem that would increase the angle so you're not too bent over when you ride. Check our Ergon. They have a huge line of grips in various configurations.
Inboard mounted bar ends wrapped in bar tape have been working great for me.
Look at the Jones bar... has many hand and body positions.
I had the same problem as you, but now I have Jones bars on both my bikes. Hand fatigue never is an issue anymore.
Quoted: 92 Post(s)
Liked 88 Times
Thanks!
Im just getting to the 15 mile rides, takes me a little over an hour. I’d like to get to 20 or so.
Mostly, I feel like my posture and position are very comfortable but my fingers seem to get a little numb later in the ride. I’m trying to stay conscious of not bending my wrists and lessening my grip pressure . But it would still be nice to have my palms face each other a bit a times.
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 429 Times
I had good luck with these bar ends when I had a flat-bar hybrid.
Liked 762 Times
The great thing about this type of bar is its 22.2mm diameter, so it takes all the standard flat bar cockpit stuff (levers, shifters, mirrors, etc). I'm using mine with a pair of short-pull brake levers (for my cantilever brakes) and a pair of Microshift thumb shifters (9-speed index, but I'm using these in friction mode on a 7-speed cassette). I also do one layer of wrap with a rubber inner tube first, then do a second layer of with proper handlebar tape. The overall diameter is very nice (about 40mm).
You also get some compliance with this bar design, as it naturally flexes with weight on it. Flat bars, especially 31.8mm clamp ones like you have, are pretty rigid, and that's another contributing factor for hand fatigue.
IMG_20190916_124136269 by jnjadcock, on Flickr
Bikes: 2019 Salsa TimberJack
Quoted: 13 Post(s)
Liked 23 Times
I use the following bars - Velo Orange Crazy Bars . They are compatible with flat bar setup. I had them on my hybrid and now on my mountain bike.
Here is they are on my bike:
My battleship
My battleship
Likes For rodgeman:
Deraill this!
Quoted: 143 Post(s)
Liked 429 Times
Here are the bar ends and pics of the install. I got them at the LBS for around $20. I might add tape in the future.
aka Phil Jungels
I like Specialized Overendz bar ends. The most comfortable ones I have ever used, and converted both my bikes to them.
Quoted: 5224 Post(s)
Liked 3,582 Times
I "roadified" a hybrid for commuting & just swapped drop bars onto it. I have a MTB now that came with small bar ends
I like them way far forward
they were useful for this purpose but I took them off last winter to add bar mitts. when the bar mitts came off in the spring, I realized I had some older ends so thought I would try them & I like them a little more I think
sometimes I do like to ride w/ just my palms on the top of them so those Specialized Overendz that @Wanderer mentioned, look useful!
Likes For rumrunn6:
