What type of suspension fork on an e-utility bike ?
What type of suspension fork do you recommend for an eBike that's used for utility .
Mostly a grocery getter but also used to carry stuff .
700c tires ; 28 x 2.15 .
Bike has a rear rack and 2 panniers .
So , coil or air ? Any specific model ?
Currently running the stock coil fork w/60mm travel and heavy duty spring ; looking to upgrade .
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
What’s lacking in the fork you have, and what do you want to spend? What steerer size, brake style, and axle style does it have
Genesis 49:16-17
Genesis 49:16-17
Spend ? , Up to $300 .
Disc Brake , Quick Release Axle , 28.6mm Steerer
Disco Infiltrator
Liked 2,105 Times
Options are limited, most fancier bikes with suspension forks are thru axle, tapered head tube. But disc is good. What size wheels/tires? Suntour forks can be upgraded with damping cartridges and firmer or softer springs. Rock Shox makes the Paragon for hybrids with 700c tires.
So , Rock Shox or Suntour ?
Air or coil ?
Paragon has a Max Tire width of 45mm . (on 700c)
I think a good quality short travel coil fork with lock out that accepts wider tires is what I want .
