Bottom bracket problem.
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I was having quite a bit of play on the axle of my 85 Sequoia and I thought I had actually broken it. I refurbished it a few weeks ago cleaned relubed and put new bearings in.
Well I took it apart and the axle ,cups and cones looked good so I put it back together.There is a fine line in tightening it that I can't seem to achieve
If I tighten it to where there is no play in the axle the axle is quite stiff to turn by hand. If I loosen it up a bit to where it turns a little bit easier I have
a small amount of play in the axle.. I refurbished all 4 of my other vintage bikes and had no trouble adjusting the tightness and none of them have any play
at all in the axle.
at all in the axle.
Quoted: 3811 Post(s)
Liked 3,338 Times
loose balls or retainers?
one possibility might be a faulty ball
as an experiment you could repack with all new balls, making sure you have eleven per side, and see if there is a difference...
another thing you could do is to face the shell
with symptoms of this sort i like to do the easy straightforward stuff first. if that resolves it you are done. if it does not then one needs to vector deeper...
Likes For juvela:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
No chance that you have a bearing cage backward is there?
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 790 Post(s)
Liked 1,767 Times
Also check the cups closely a crack in one of the cups can cause the described issues.
Quoted: 502 Post(s)
Liked 466 Times
Advocate
Check the threads and seat on the right side too. If the right side is not seated correctly, you'll never get it adjusted correctly.
Quoted: 677 Post(s)
Liked 460 Times
Problem finally fixed. I took the bearings out of the cages and put them in loose and it worked like a charm.
Was very easy to adjust and no axle play.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Literally the first time that I took apart a hub (age six, while fixing a flat by myself for the first time, and with curiosity getting the better of me), I reinstalled the cages backwards.
That's my oldest memory of making a mechanical mistake. I've since taken apart many an old bike having the same assembly error.
The symptom was just as the OP described, and which I attributed to faulty parts at the time.
Years later, preparing the same bike for sale to a neighbor (repainting fully-stripped frame), I discovered my error. I had readjusted the bearings a few times over the years, and by this time the bearing cages were, shall I say, "well worn"!
Here's me on that hard-ridden old bike, the front hub no doubt still grinding, but not too long before I sold it:
Quoted: 677 Post(s)
Liked 460 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Quoted: 677 Post(s)
Liked 460 Times
señor miembro
Liked 6,485 Times
No, this one you started a day later where you show a photo of the retainer:
https://www.bikeforums.net/classic-v...direction.html
Quoted: 677 Post(s)
Liked 460 Times
