Sturmey archer S2C - trouble shifting after disassembly ..
I took my S2C apart to re-grease it after it got slightly immersed in a river (!) .
Everything looked perfect.
However, After reassembly, the shifting is poor.
It feels like the coaster engages too easily now. Making it hard to get far enough back pedalling to shift.
Shifting can take 2-3 attempts before it happens.
If I am cruising along, and carefully and controlled-ly back pedal slowly - I can make a clean shift. But that's tough in traffic .
And when pedalling in the high gear - It now makes a noise like when you leave your keys in the washing machine
It was suggested to try orientate the planetary gears with the rollers as per the sturmey archer exploded diagram.
https://www.sturmey-archer.com/files...%20-%20S2C.pdf
This worked, but since then, each ride, the hub has become more deranged.
I am keen to try again, but would like to go in with a plan... Would be super grateful if anyone could suggest anything?
Many thanks,
Max
Many thanks,
Max
Quoted: 5930 Post(s)
Liked 2,823 Times
I've never worked on that particular hub, but have on coaster brakes generally. I wonder, if you've somehow overly reduced the travel of the clutch, so there's no longer enough travel for a shift without applying the brake.
FB
Chain-L site
FB
Chain-L site
Yea, that sounds about right. I think I can change the travel by adjusting the relative rotational position of the planetary gears and the rollers. However, I think their positions start to shift over time. I need to figure out if there is some kind of mechanism that stops each segment rotating once reassembled
