Tried to renew brake pads but didn't work
I have a bike that hasn't been used for a while. It's been indoors but it ended up getting quite dusty. I cleaned it up and took it out, but the brakes didn't work very well. I did a bit of research on how to clean them, so I took the pads out and heated them in a frying pan. I then wiped off as much residue as I could, sanded them, and wiped them down again. This didn't help at all though and they seem even worse now. Is there anything else I can do or will I just have to get new pads? I was reluctant to buy new ones at first as these ones are barely worn. I tried to find the exact model of the brakes in case it was relevant but I couldn't find a specification for the bike model I have with it being quite old. It's a Specialized Rockhopper en14766 if that matters.
Also while I'm asking, I was wondering whether the suspension is likely to need any maintenance after being left untouched for a while?
Thanks in advance. Any advice would be appreciated.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
What kind of oil did you use in the frying pan? I prefer olive oil for brake pads.
Time for new brake pads. Canti brakes? Shouldn't be hard to find suitable replacements.
Post a picture of the brakes for suggestions.
Quoted: 2599 Post(s)
Liked 1,924 Times
New pads are cheap. If you had to try frying the old ones, they were probably overdue for replacement.
Really Old Senior Member
You sure this frying pan method wasn't for disc brake pads?
I saw the frying pan thing suggested a few different places. I think the idea was just too loosen anything that may be contaminating the surface, but just on a low heat to avoid damaging the pad.
The pads weren't old or cracked or they weren't due for replacement, they'd hardly been used. That's why I was reluctant to buy new ones. I just guessed that some dirt/dust had found it's way on to them as they'd been sat unused for a couple of years.
If there's nothing else that can be done to renew them though, I'll just look at replacing them. I don't know the exact model, but they're Shimano hydraulic disc brakes.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I have never heard of using a frying pan. I have heard of putting the pads in a hot oven to burn off contaminents, but I never thought that sounded like a good idea, either.
Quoted: 1438 Post(s)
Liked 1,092 Times
Don't forget to bed-in the new pads per the manufacturer's instructions.
Are you sure the pads are the issue? Usually bad pads cause all sorts of squealing rather than poor performance.
When you say poor performance what do you mean? And cable or hydraulic discs?
They're hydraulic. When I first noticed the issue, I'd started going down a very steep hill and the brakes weren't stopping the wheels fully and were squealing very loudly. Since trying to clean them though, I haven't really tested them properly. I just rode up and down my road a couple of times and discovered that they weren't effective enough to actually stop the wheel, but there wasn't any unpleasant noise this time.
Assuming the levers still feel firm, the simplest solution is just buying new pads. The pads aren't particularly expensive and trying to recover pads can be a time consuming and frustrating exercise.
Your best bet is probably to clean the rotors and calipers with isopropanol then install some fresh pads and move on.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
I accidentally got oil on my rear. Had no braking power at all. Cleaning the rotor with alcohol several times and also cleaning with water did the trick for me.
Are the levers still firm or does the lever bottom out? If so they need to be bled.
Anyone got any recommendations for replacements? I'm only a casual rider so I don't need anything special. These are the standard ones that I was going to buy -
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
Ah. UK. I see. Yeah, we don't fry our brakes, over here. We sautee. The difference is subtle, but profound!
Unavilable due to riding
Bikes: Nishiki Olympic
Quoted: 127 Post(s)
Don't make me sing!
Quoted: 308 Post(s)
I've been around the block a time or two but I have not heard of frying brake pads. As rubber pads get older they get hard and don't stop well. It's then time to replace them. Pretty simple, cheap and less time-consuming solution in my opinion.
