Wet / Winter Weather Tires List
Old 08-31-10, 09:56 AM
ALLSTOTT
ALLSTOTT's Avatar
Quoted: 12 Post(s)
well i've been searchin through this forum and have not really found a good list of tires(700 x 23 or 25) that are for wet / winter weather. so its time to make a list.
- Vittoria Zaffiro Pro Tech
ALLSTOTT is offline
Old 08-31-10, 10:08 AM
DScott
It's ALL base...
DScott's Avatar
Conti GP4000
Conti GP4000S
DScott is offline
Old 08-31-10, 10:27 AM
SpongeDad
Overacting because I can
SpongeDad's Avatar
Bikes: Merlin Agilis, Trek 1500
Conti GP 4 Seasons (a bit tougher than the 4000 series, but not as supple)
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
SpongeDad is offline
Old 08-31-10, 10:43 AM
Dr. Banzai
Oscillation overthruster
Dr. Banzai's Avatar
Bikes: Cinelli Mash / CAAD9 5
Slicks. And I'm not kidding. Sipes are cosmetic. If you want grip, select a tire that wears easily in the summer, it will be a softer compound and in the winter cold/wet it will be softer than other but wear like a summer tire.
This was hashed out yesterday.
So don't change tires if you are happy with what you have. You'll be wasting money. Of course we are not discussing riding on ice.
Dr. Banzai is offline
Old 08-31-10, 10:49 AM
2sixR
ride to climb...^
2sixR's Avatar
+1 on the Conti GP4000s tires... I've had good results in the wet with them...
2sixR is offline
Old 08-31-10, 11:09 AM
banerjek
Portland Fred
banerjek's Avatar
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
Quoted: 232 Post(s)
Liked 53 Times in 35 Posts
Bontrager Hardcases. They're heavy, ride like crap, and the grip is bad, but they're cheap, durable, very resistant to cuts, and easy to mount compared to other puncture resistant tires. Great for cold rides in the dark and the wet.
banerjek is offline
Old 08-31-10, 11:15 AM
roadwarrior
roadwarrior's Avatar
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times in 6 Posts
I love these in the bad weather. Not very sticky so they don't pick up stuff and cause flats. Rode a set on my fixie/ss which is about all I ride outside in winter. Zero flats.
roadwarrior is offline
Old 08-31-10, 11:23 AM
banerjek
Portland Fred
banerjek's Avatar
Quoted: 232 Post(s)
They're not bad for relatively clean roads, but grip is mediocre and mine got cut to pieces, including a flat on the maiden voyage. Having said that, if I had only one set of tires I used all the time, they're decent all 'rounders.
banerjek is offline
