Crankset options...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Crankset options...
If a guy was experimenting with Flight Deck brifters, and putting a Shimano 105 5500 9-speed group set together, for a yet to be determined early 90's steel frame set...would he choose a triple, or a 53/39 double?
If choosing the double, what would be a good cassette range?
How about if choosing the triple?
This guy is 65 years old, rides some hills but no major hills, and would never be loaded.
Well...never loaded with gear, anyway.
Any pros and cons opinions are appreciated!
Quoted: 930 Post(s)
Liked 1,291 Times
I'm 65, in excellent shape, ride hills and think that riding a 53-39 is dumb for this application. That chainring setup was designed for one thing...racing, by young people. (although it can be useful for flatlanders too). I've converted my vintage cranksets to triples. Unless you switch to a "mountain" RD, you'll be stuck with a max rear cog of about 30T = 36" low gear. That is not a good hillclimbing gear for someone whose racing years are far behind them. I would advise a 30" gear or lower. Experiment with a gear calculator like this one: Bicycle Gear Calculator. I stuck with 52-42 through my late 50s, which was a mistake waiting so long.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
5503 triple, obviously.
If you search previous posts you should be able to find numerous suggestions, opinions, and ideas re: this question. Bottom line - to each his own depending upon individual strength, style, cadence, local topography, etc.
But - personally I don't have much use for anything bigger than a 39T chain ring - and I prefer a sub 1:1 lowest gear ratio. I like MTB doubles on road bikes with a decent-range cassette (11 or 12 to 32 or 34). This allows me to pedal at a realistic cadence up to around 22mph and it provides lots of low gears for hill climbing. A MTB double with a 39 or 40T large ring will usually have a 26 or 28T small ring. I prefer double cranks to triples because the shifting seems a little bit cleaner to me.
However, I just installed a new Deore 42/32/22 triple on a (fairly heavy) gravel/adventure bike - and I did this because I got the crank and BB brand new for $60 and the existing brifters/front der. can handle it. So I'll give it a try.
53/39 sounds kind of tall. And if you really don't know what you want, then get an affordable set-up to experiment with - lots of decent used equipment on ebay and Craigslist. Once you figure out your preference maybe then you spring for a shiny new set-up.
I'm not knowledgeable enough to tell you what will/won't work with Flight Deck brifters.
Quoted: 209 Post(s)
Liked 175 Times
I see quite a few 5500 doubles in the 53/39 configuration, that's why I referenced it.
I like the idea of a double being cleaner, but I also have to agree that 53/39 is too big for my riding style. The rear derailleur will be long cage, so it should be compatible with a triple setup.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
I'm 64. I ride an '84 Peugeot I bought new. Some where around 25 years ago I put a 52-42-32 triple on the front. Rear is 13-28. I was having trouble on climbs. The front triple is now 50-42-26, same rear gearing. With the 26-28 combo, climbing is no longer an issue.I spin like Hell to go 7 mph but it works for ME.
Just my $.02 worth.
Jon
Just my $.02 worth.
Jon
Quoted: 3241 Post(s)
Liked 2,512 Times
The OP basically answered his own question in his post. The main advantage the triple has is that you get to keep the high gearing of the standard double. All you are doing is adding a 3rd ring for climbing gears. Or options. You like that 53/39 except for hills? Then keep it and put a 30 on the bottom. There you go. Or go to a classic 52/42/30 road triple. Geared on the high side, but still got the granny for bailouts. You can keep the same gears in the back, or even get a tighter cluster. Best of both worlds.
Liked 2,568 Times
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I always liked the 50, 39 & 30 Shimano 105 and Tiagra triples. I would replace the 30 for a 26 and add a dog tooth chain guide to eliminate the risk of a dropped chain. The 39 could be used on most flat roads and the 50 was useful while going downhill. The 26 when used with a 12-27 cassette could climb any hill.
Campagnolo fans could use a 53, 42 & 30 crankset with a 13-29 ten speed cassette and achieve similar results.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
I setup my Zunow with 5500 9 speed and use a 48x45 chainset and a 12-36 rear.
This gives 34 to 109 Gear inches. I am using a 5500GS RD and Dura-Ace DT shifters. OBy the way, I am 62yo.
If I needed lower GIs, I could swap out the 48 with the 45 and put on a 42.
I also have the following that matches the 5500 group; brifters for 3x9, Barcons for 3x9 or 2x9, a triple crankset(with 53x42x30 chainrings), bottom bracket for a triple, and the triple FD.
I settled on the half step with the 48x45 for ease of use.
IMG_20190215_152201828 by Bwilli88, on Flickr
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
I have a bike with 43+27 chainwheels and 11-to-32 cassette. It gets me up slopes of 18% --and, far more importantly, long slopes of 10% -- and I can go about as fast as I want when going some distance in a straight line slightly downhill. Occasionally I wish that my top gear were higher, but only occasionally. (More often I'm happy to freewheel.) This double is a bit less finicky than the triple I have on another bike.
But of course I am not your acquaintance.
Quoted: 378 Post(s)
Liked 1,409 Times
You say you have a long cage RD? Then, IMLTHO, I'd go double, swap the 130 BCD rings up front for a 50/38, and pick up a nice wide cassette like an 11-32 or 11-34. I just find wide-range doubles easier. I don't know gear inches from saltpeter.
Good climbing, no loss of top end, and chicks dig it.
Or put S-10 wheels on it and call it a day.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I'm 60 years old this summer and am a fairly strong rider for my age. Hills don't phase me in the least. I'm a spinner. I'd probably never design any bike for myself with greater than 105 gear inches, which translates to ~27 mph at 90 rpms. Anything over that, I'm coasting.
My recommendation would be a compact double with a smaller outer ring. Something like a 46-34T double and a 12-27T cogset. That should do him fine, unless he's a complete monster.
Bikes: Masi Giramondo, Trek 830 monstercross build, Raleigh Gran Sport, Lemond Tourmalet
Quoted: 121 Post(s)
Liked 19 Times
53t / 39t chainring doubles, IMO, are a holdover from the days when the highest gear on your freewheel cluster was 14t, which would have been a 3.9:1 gear ratio. Now that we have 11t high (and even some 10t) gears on cassette clusters, and fatter tires, 40t is roughly equivalent. So get approx a 22-32-42 triple up front, and you'll be covered for everything you as a mortal can do.
Quoted: 18375 Post(s)
Liked 4,510 Times
Over the last 5 years, I think I've been evolving to a higher cadence and lower gears.
But, changes in cassettes have also made a big impact.
Say the old bike was:
54/42 X 13/23
Newer cassettes give more sprockets on both ends.
11/30? 11/32?
The higher gearing in the cassettes makes the 53/39 or 54/42 less relevant.
The lower gearing? Heck if I know, I haven't gone down that path yet, except with cargo.
Still, I'd look at a 50/34, or even 48/30 crankset.
Actually, I've gone to a custom wide crankset (53/34) on my road bike, and like the gearing options.
Thanks!
Quoted: 930 Post(s)
Liked 1,291 Times
Note that sometimes it takes a minute or so to pop up, apparently because it's running in java on you browser.
Quoted: 209 Post(s)
Liked 175 Times
Golly, everybody, you sure have given me a lot to think about. I will continue to peruse bike shop parts bins, and the auction site, and see what configuration presents itself.
Thanks again for all the input!
I posted a link to a really good calculator above (post #2 ). Here it is again: Bicycle Gear Calculator
