Need help identifying this bike
Old 06-20-19, 03:49 PM
bikeaddiction1
bikeaddiction1's Avatar
Bikes: Many
Quoted: 78 Post(s)
Liked 32 Times in 27 Posts
I pulled this bike out of my stock pile for my next project. The frame has been repainted by a previous owner and I can't identify it. It is a lugged steel frame with forged Brev. Campagnolo drop outs. There are three small holes in the head tube which I assume where used to secure a now missing head badge. The following numbers are stamped in the bottom bracket in two rows:
WK7000231
11 620 492
There is a bit odd a mix of components. Mostly Campagnolo, which I canít find any model name or number for. Components are as follows.
Camagnolo crank, shifters, derailleurs, headset, seat post
Madolo Speedy brakes and levers
Brooks professional saddle
3ttt (Italy) handlebar stem
Wheels: Shimano 105 hubs with Wolber rims and Suntour 6 speed cassette
Can anyone identify the frame manufacture, model, and possibly year? Maybe the model and date of components? Thanks in advance.
bikeaddiction1 is offline
Old 06-20-19, 03:59 PM
jdawginsc
Edumacator
Quoted: 274 Post(s)
Liked 163 Times in 109 Posts
Those are the deepest lug cutouts I have ever seen. Nervex lugs...?
That seems like a mish mash of parts someone updated as needed.
jdawginsc is offline
Old 06-20-19, 04:08 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1409 Post(s)
Liked 758 Times in 428 Posts
A July 1977 Worksop-built Raleigh would be my guess.
Peace!
non-fixie is offline
Likes For non-fixie:
Old 06-20-19, 04:19 PM
juvela
juvela's Avatar
Quoted: 2116 Post(s)
Liked 333 Times in 294 Posts
The lug pattern is BOCAMA Professionelle Luxe with cutout pattern B4.
The domed stay ends are somewhat suggestive of a UK origin.
Possible that one of the numbers on the shell is from a licensing agency. Note that the "W" number is very evenly spaced and well struck while the second number less so.
You do not mention threading. Would expect Italian not to be a possibility.
No good images of crown are provided. All we can tell is that it is semi-sloping (perhaps it belongs in the forum's recent thread on semi-sloping crowns ).
Since we have a respray we cannot place too much weight on the presence/absence of specific braze-ons.
Possible frame may be slightly earlier than one would guess at first glance.
DCI Maurice AKA @MauriceMoss is sure to knock the question out the ballpark in two shakes of a lamb's tail.
juvela is online now
Old 06-20-19, 04:44 PM
bikeaddiction1
Bikes: Many
Quoted: 78 Post(s)
I popped out the BB and it is standard 1.370" x 24 tpi. Here are pictures of the cups as well as a couple of the fork crown and fork dropouts.
Old 06-20-19, 04:46 PM
bikeaddiction1
Bikes: Many
Quoted: 78 Post(s)
The BB is square taper. I was pleasantly surprised to have the crank bolts remove the arm without needing a puller.
Old 06-20-19, 05:13 PM
bikeaddiction1
Bikes: Many
Quoted: 78 Post(s)
The three holes in the head tube are arranged in the same pattern as the rivets in a Raleigh head badge. I should measure them on one of my Raleighs. The head badge pic here is just pulled from the web.
Old 06-20-19, 05:32 PM
juvela
juvela's Avatar
This is something Magistroni did in 1965 with the Super Zenith set.
When copied years later by Shimano it was hailed as a great innovation.
Thank you for the additional information & images.
Can see nothing to contraindicate @non-fixie 's assessment.
Crown bears some similarity to Cinelli MR & Everest C52, but there are several with this shape...
TI understandably inclined to go with a provider such as Davis, for obvious reasons.
Old 06-21-19, 02:28 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
WRT the model: something doesn't jibe here. Raleighs of that era - at least the European models - typically didn't have top tube cable guides or shifter bosses. Shifters were clamped, and rear bake cables used either cable clips or a couple of housing stops, like this:
They may have been added later.
Peace!
Old 06-21-19, 05:03 AM
T-Mar
Quoted: 3299 Post(s)
Liked 716 Times in 552 Posts
+1, my initial thought, even before I started reading through the responses, was a Worksop built 1977 Raleigh. It's obviously a repaint and looks to originally have been black. This and Campagnolo dropouts with eyelets, would be indicative of a Competition GS. Given the repaint, the cable tunnels are likely an addition, as would be the shift lever bosses and bottle bosses.
T-Mar is offline
Old 06-21-19, 05:29 PM
bikeaddiction1
Bikes: Many
Quoted: 78 Post(s)
After all the great input here I spent way to much time researching this and I believe you are correct. I found the paint is actually quite good once I started cleaning and I think was likely done at an auto body shop. The black you see is from residue from electrical tape used to hold computer wires and other items, however I see what appears to be black paint on the the edges of the bottom bracket tube right next to the threads so I believe it was black. Except for the items you point out (cable tunnels, shift lever bosses and bottle bosses) it seams to match the 77 Competition. Although there is a bit of rust spotting on the chrome it is coming off quite easily and I see no trace of rust inside the frame.
Components are another matter. The Campagnolo seat post, front derailleur, and head set, Brooks saddle, and possibly the bottom bracket match the 77 Competition. I don't think the 3ttt stem and unbranded handlebar, or Modolo brakes do. The wheels and remainder of the drive train appear to be of newer vintage.
Unless someone else knows something else I think this is as close to an identity as I can get. Unfortunately I am too big for the bike and the repaint and miss matched components likely reduce the value fore resale, but it will still be a nice ride when I am done.
I have another bike with identical paint that I got from the same guy, but it has definite Bianchi identifiers (B stamped in the fork crown, etc.). I will likely be looking for help determining the model and year of it too.
Thanks for yours, and everyone else's help.
Old 05-09-20, 07:27 AM
bikeaddiction1
Bikes: Many
Quoted: 78 Post(s)
To bring things full circle I thought I would post the finished bike. The new owner is happy/
Likes For bikeaddiction1:
Old 05-09-20, 09:01 AM
obrentharris
obrentharris's Avatar
Bikes: fewer (n-1)
Quoted: 780 Post(s)
Liked 436 Times in 216 Posts
Beautiful!
Very clean look.
Brent
obrentharris is offline
Likes For obrentharris:
Old 05-09-20, 09:54 AM
John E
feros ferio
John E's Avatar
Quoted: 815 Post(s)
Liked 171 Times in 137 Posts
... as he damn well better be, assuming that is his size. I'll bet it rides beautifully. Nice job, and great find.
John E is offline
Likes For John E:
itf6
Classic & Vintage
23
11-24-18 02:28 PM
Rollnsteve
Classic & Vintage
14
09-22-16 01:08 PM
non-fixie
Classic & Vintage
20
01-02-13 04:47 PM
beakgeek
2
02-20-12 11:25 AM
ColonelJLloyd
Classic & Vintage
15
09-29-11 08:11 AM
