Addiction LXXV
#1026
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
If it were my choice, I would aim for 70-75F and 75-80R. But tweak to comfort and if you start getting pinch flats (assuming not tubeless) you are too low.
#1027
Administrator
Quoted: 11952 Post(s)
Liked 6,602 Times
It's best that you start getting used to these separations now, because when college departure comes . . . that's a biggie.
The one I remember most fondly was the first time we let our son go to an evening HS football game alone. We knew he was in good company, but that didn't stop us from fretting.
#1028
Quoted: 20808 Post(s)
Liked 9,450 Times
So, the new Cervélo has Hed Belgium + rims and 25 mm tires. Hed say 67 psi (!) for that combination and my weight band (see below). I have gradually come down from the low 90s to just below 80 on the rear, and a few less on the front, without noticing much more than a small low frequency shift in the peak power detected by my crotch sensors. As for speed, who knows? I want it to ride like a beach cruiser and go like a rocket. Should I continue to lower the pressure?
#1029
Liked 8,918 Times
It's funny, but so many cyclists did not get the memo about tire pressure and continue to pump them up to 115PSI or whatever the "max PSI" on the sidewall says.
FWIW I run 23mmF and 25mmR and narrow rims, but even so have settled on 80-ish PSI. Ordinarily you should be 5-10 PSI higher in back but since I am 2mm wider I run same front and back.
#1031
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
#1033
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
He has a habit of asking "why" questions about current trends in cycling -- wider tires at low pressures, 1x for CX, tubeless, discs, etc. And then when I explain why--without endorsing these trends, but rather providing the objective rationale behind various choices--he will then argue with me about them mainly based on the fact that that's not how things were 20 years ago.
So when he shows up with his 38mm tires pumped up to 100 psi I don't argue with him.
#1034
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Thanks. I keep joking I’ll sneak in and kidnap him
But he's going to absolutely love it.
i don't want to think about college yet! Too soon for me
#1035
Liked 9,450 Times
#1036
Liked 9,450 Times
I'm thinking that I'm going to give the 28mm Pro Ones a try next. I know that they're not going to be as durable, but I want to see how much faster/more supple they are vs the GOSpeeds. I was tempted to order them on Amazon just now, pretty good price ($45ea) and they'd be here tomorrow, but I'm still without a rear wheel.
#1037
Quoted: 18397 Post(s)
Liked 15,492 Times
I pump up my tires to 11.
#1038
Quoted: 4717 Post(s)
Liked 1,882 Times
Merlin has them slightly cheaper, but you'll have to wait 10 days for them to arrive.
https://www.merlincycles.com/schwalb...yre-89170.html
#1040
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I went lower pressure for awhile. And wider for awhile. I'm currently riding 23mm - 27mm tires at 100psi rear and slightly less front. Most of them are 25mm. I don't like squishy tires. But then I still ride steel.
#1041
Liked 8,918 Times
I saw a patient today who has sleep apnea. His sleep specialist made an adjustment to the CPAP settings, and raised the setting to 11.
I joked to the patient that he has his device "cranked up to 11" but I am afraid he did not get the reference.
Sad.
Sad.
Likes For datlas:
#1043
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times
#1044
Liked 15,492 Times
I have been doing some cross-Pennsylvania tour planning in anticipation of September. Thinking either Pittsburgh to Philly, which I did in 2013, or starting in Erie like in 2017 but this time visiting an old friend who runs a B&B/camping/sky diving place just below the NY border before continuing on home.
#1045
Bikes: Shmikes
Liked 5,841 Times
As a lapsed neurologist, I'm here to tell you that Spinal Tap jokes rarely produce much hilarity among patients.
#1046
Liked 9,450 Times
Let us know how that goes. I'll probably stick with G-One Speed tires, but I was thinking about giving those a try.
And yeah, I always check with Merlin first, but the Amazon price is close enough and I'm a sucker for (almost) instant gratification.
#1047
So it is
Quoted: 11393 Post(s)
Liked 4,729 Times
In this thread?
Asking for a friend.
Likes For LAJ:
#1048
Liked 8,918 Times
#1049
Bikes: Shmikes
Liked 5,841 Times
#1050
Liked 9,450 Times
Important news - I got my grubby paws on some white chocolate peanut M&Ms. Initial impression is that they're pretty good, but not that much different than regular peanut M&Ms - a little bit of a lighter/sweeter aftertaste. The dark chocolate version is more pronounced and still my favorite overall, but I'll be sure to update with a long-term review when I get some more miles in.
