Upgrading groupset, which gearing for crankset and rear cassette?
Old 06-15-20, 10:30 AM
Nikefutbolero
Cycling Noob
Quoted: 7 Post(s)
I'm upgrading the groupset on my Sirrus X to the Tiagra and am unsure which gearing to pick. We want the keep the bikes versatile and we wont be doing much serious climbing. I'd say it'd be on the road 80% of the time and gravel off road the remaining 20%. We're doing a 2x10.
The Tiagra crankset is offered in 50-34T, 52-36T, 48-34T
As for the cassette I dont know what option to go with, 11-34 comes up in some searches I'm doing, not sure what to go with though.
Thanks!
Nikefutbolero is offline
Old 06-15-20, 12:32 PM
hermanchauw
hermanchauw's Avatar
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times in 9 Posts
Thanks!
Calculate your existing ratios in gear inch, then you can determine what size you need. Otherwise, just stay at the same sizeif the current one is fine.
hermanchauw is offline
Old 06-15-20, 12:42 PM
u235
u235's Avatar
Quoted: 437 Post(s)
Liked 133 Times in 86 Posts
Depends on you.. On my gravel/road bike I swap around a 50/34 and a 46/30 and a 32, 34, and 36 rear cassette depending on need (I don't swap cranks often but the option is there). My hybrid is a 3x8 with some crazy huge range of gears.
One generality.... the wider the cassette range the larger the gaps between each gear. That matters more to some people than others. At some point in cassette range you may need rear different derailleur to support the wider range wrap.
u235 is offline
Old 06-15-20, 01:00 PM
Laseranimal
Quoted: 25 Post(s)
Liked 23 Times in 14 Posts
I think the Sirrus X is a 1x drivetrain. Might be tough to upgrade to a double chainring because it isn't set up for a front derailiuer
Laseranimal is offline
Old 06-16-20, 10:59 AM
Nikefutbolero
Cycling Noob
Quoted: 7 Post(s)
Yeah I didnt think of that im so dumb. I'm looking at the SRAM Apex 1.
