Waterproof Shoe for Cycling
Quoted: 80 Post(s)
Liked 9 Times
Okay, I am a pretty active road cyclist, probably 100+ miles a week. However, I do not clip in. I ride with partial toe clips and running shoes. I can maintain 13-14 mph and if I want to stop and walk around all is good.
So I need a pair of shoes or maybe two pair of shoes for when the weather turns. As long as the weather is dry I am good in my running shoes, but when it is a bit raining (not a downpour - cause I will just hit the trainer) I need a waterproof shoe that will work with my toe clips? Any suggestions?
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
I do not have a particular recommendation, but I will say that waterproof shoes are guaranteed to make/keep your feet wet (waterproof gloves will do the same for your hands, IMO).
Likes For epnnf:
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
maybe something simple.. been around for decades?
Likes For Flip Flop Rider:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I have a set of waterproof socks. They are Sealskin brand I believe. They work good and are about the overall thickness of a set of winter wool socks. I usually just wear performance wool socks all the time and don't worry about my feet much. We don't get the endless cold weather here though.
Quoted: 1364 Post(s)
Liked 1,678 Times
I commute year round in toe clips and straps and firm-soled sneakers. I usually get inexpensive synthetic shoes so the rain doesn't hurt them. In the winter I have sneakers with LED lights in the soles for visibility.
I let my shoes get wet.
If there is snow I put my foot with sock in a plastic grocery bag before putting on my shoe and ties the bag loosely around my ankle, tucking the excess plastic into my shoe.
As far as rain, a long front fender that tucks under the curve of the wheel with a flap that skims the pavement works wonders at keeping your feet dry while cycling in the rain and wet.
2. Buy a bunch of running shoes and rotate them daily.
3. Dont wear socks.
4. Get yourself a pair of old style leather cycling shoes.
5. Water proof shoes most likely will be a step backwards as your feet and socks will get soggy with sweat. Shoes need to breathe.
6. It usually doesnt rain long so find somewhere to sit it out.
Quoted: 427 Post(s)
Liked 700 Times
There are sprays made for making hiking boots, and shoes water resistant. I"ve used spray for my hiking boots, and it works very well. Might be worth a try. Might try some 3M Scotchgard: https://www.scotchgard.com/3M/en_US/...4529207&rt=rud
I have mudguards and when raining heavily a rain cape
water proof ? : L L Bean shoes rubber with leather uppers..
Want your clipless pedal system? you buy rain covers for your shoes probably still not be bones in the desert dry.
Showers Pass brand of rain booties work well, although, like already written, you'll still feel damp/wet from perspiration.
Longbikes Slipstream
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
In light rain, you can keep your feet dry with some of the ideas already recommended here. In a heavier or consistent rain where you're out for a longer period of time, like more than 15 minutes, your feet will get wet from water running down your leg. There isn't much you can do about this unless you get gators for your shoes and water proof pants that go over the gators. Then you're probably gonna get wet from all the sweat.
Waterproof shoes will rarely be waterproof 3 hours into a cycle, it's just a long time for a piece of clothing with a large hole in the top to keep water out. The rest of your clothing must also be waterproof as if the pants are not waterproof, water gets in the top. Also need a good jacket. For heavy rain you need a full setup.
For commuting I have a pair of Columbia outdry hiking shoes. If it's raining heavy I have a pair of waterproof "breathable" trousers and over them a pair of regular hiking gaiters. This does a great job at keeping heavy rain out for at least an hour.
It's not a typical cycling setup, but it works for hiking so I assumed it would work for cycling and it does. It is used by more than I, an accomplished athlete who cycles a lot recommended it to me.
Have realistic expectations, nothing is waterproof in definately and the longer you're out in a downpour the more time water has to find all the little paths in.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Lightweight hiking shoes with GoreTex treat me very well.
I don’t seem to have the problem with hot feet that some others complain about with GoreTex
Quoted: 4806 Post(s)
Liked 3,932 Times
Unless you have a foolproof way to keep water from running into your shoe, water will flow down your ankle and into your shoe unless you either address that or simply don''t ride when itia that wet. If you ride long enough distances in enough wet, water will find its way. Between extremely high local humidity, the capillary action of almost al fabrics and gravity ...
I rode a race back in a distant millennium where it started raining 12 hours before the start and didn't stop until after we finished (4 1/2 hours later). Not "hard", but a solid steady the entire time. I've never been so wet. Neither have my bikes. At the 1/3rd point of the race, we were riding beside a river and it crossed all of our minds that we could veer into it and not get any wetter.
After the race there was arather animated idscussoin of shoes. Now, traditional leather cycling shoes back then had one to three holes in the sole between the ball of the foot and toes. mOst of us wore such shoes and never thought about it. Yes, our feet were just as wet as the rest of us but so what? But the few wearing shoes without the holes? They had a lot to say? Pure misery for their feet; sitting in full, sloshing. heavy bathtubs
I've never tried to verify their experience. Just took it as "the word'. Holes in the sole are good! I've drilled them on shoes that came without.
Ben
Ben
Liked 3,932 Times
Now, I did go to real lengths to keep my feet as warm as possible with my 45North cycling boots. I made special gators of stretchy outdoor fabric (not waterproof). They fit snug over my ankles. under my tights or leg warmers and over the boots. Idea is to get water to run down inside the fabric past the ankle opening of the boot. Works quite nicely but it is is for temperatures below 40F. (Also keeps much of the cold air out. I am long enough that a gap between leggings and boot tops is a given unless I go custom clothes.)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
My feet are prone to Athlete's Foot for some reason, so hermetically sealing them in order to keep out rain water is the last thing I'd want to do! I go in the opposite direction and let them breathe. Get some biking sandals, and though your feet will get wet in a downpour, they will also dry quickly once the sun comes out again.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Agree with @epnnf that truly waterproof shoes will simply trap the sweat and your feet will get wet anyway. Traditional bike shoes had drain holes in the soles to allow water to drain out rather than accumulate in the shoe. Can you put such holes in your current shoes, or search up some traditional bike shoes?
One advantage in SiDis synthetic leather used by them is they get wet & dried repeatedly without much damage..
there's Gore-tex Over socks to try to keep your socks from being drenched..
At colder temps when wet shoes and socks become uncomfortable I use the Vaude Bike Gaiter shoe covers. They are very much water proof and work very well. In summer I don't mind getting wet feet. The shoes will dry over night.
