My pump just blows!
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
My pump just blows!
And it doesn't inflate! I went to change tubes after flatting, and just could not get the chuck to stay on the valve stem. Upon inspection, the little thingy inside the pump head/nozzle was missing.
What good is a Road Morph G gonna be if a vital piece goes AWOL?
Community guidelines
nashcommguy
Bikes: Commuters: Fuji Delray road, Fuji Discovery mtb...Touring: Softride Traveler...Road: C-dale SR300
Some clarification is needed. Is it a new pump? It may have come from the manufacturer that way. Did you flip the presta/shrader adaptor and forget to flip it back? I've got 3 TPRM w/gauge and the only problem I've had is the adaptor getting out of round over a period of time from threaded valve stems. Do you use it regularly to 'top off' your tires? Not a good thing as they weren't designed for that purpose. Better to get a floor pump w/a 160 psi limit.
But, +1 to the above post. Contact Topeak, explain your experience and I'm pretty confident they'll send you another one. They've always been very co-operative w/me on a variety of equipment questions.
Not to rub salt, but as an 'experience is the best teacher' encouragement I always carry a CO2 unit in addtion to my frame pump as I've had this exact situation. Same w/a chain tool and a few links.
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
I bought the pump back in '08 just after getting the bike. Had the LBS configure it for the non-presta valve, and it sat on my bike unused all this time- until 3 weeks ago. Used it to change out a flat (that tube lasted all of two weeks ).
According to Topeak's website, I'll have to call their customer service during regular hours M-F. I'm going to inquire about replacement mounting hardware while I'm at- I want to relocate the pump to the downtube. I took the bracket off of the top tube.
And I have been looking into CO2 systems for the redundancy factor. I'm also looking for a floor pump- the compressor at QT don't seem to cut it anymore...
nashcommguy
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
I added a bottle and cage to that outer position this past summer, and quickly discovered that I prefer to drink water and not chew it. So I keep tire levers, a patch kit, and a multi-tool in that bottle now (seat wedge has the tube and another patch kit).
I quit carrying pumps a while back, CO 2 inflaters are a lot more convenient.
born again cyclist
i found hand pumps to be useless for the PSI that i run my tires at. the only set-up that makes any sense at all is having a nice floor pump at home for everyday top-offs and a CO2 pump in the saddle bag for emergencies out on the road. once you use a CO2 pump for the first time and inflate a road tire to over 100 PSI in a matter of seconds, you'll never be inclined to use a hand pump again.
eMail Sold to Spammers
I use an air compressor at home. For a frame pump I found that I like the cheap $12 PlanetBike pump at REI to be my favorite. It has the autohead, it has two stages for volumn which you change to single stage for pressure. It is also one of the lightest pumps you can get. I had a flat on my road bike that I inflated two weeks ago with my cheap $12 pump.
nashcommguy
Yeah, I know I could sacrifice a cage mount, but at the time I didn't want to. My bike has two mounts, both on the down tube- one inside the triangle, the other on the outer, bottom side.Attachment 178213
It's fine to just carry CO2 inflators, but the risk of getting a pinch flat is too great for me. My preference is to use a pump and inflators in combo. My TPRMgs go to 160 psi and I run my tires at 120, so I'm covered regardless. The advantage in the TPRMg is that it's built like a small floor pump. And while there's nothing wrong w/a cheap frame pump, when it's freezin' *** cold or full rain the least effort the better. Get started w/t pump and finish w/t CO2 is real quick and consistant. At least, that's been my experience.
The best thing I've done to get a handle on flats is to invest in Schwalbe Mararthon Plus'...but that's a whole other thread.
on by
Quoted: 927 Post(s)
Liked 690 Times
https://www.bikeforums.net/showthread...1#post11380801 Post #44
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I had the same problem with a Topeak minipump, and they wanted to sell me the rebuild kit when it needed one part. I bought it from Performance, and they replaced the part for free. I'm carrying a CO2 cartridge now too.
Acts 2:38
Bikes: '10 Marin Lucas Valley, '13 Scott Speedster 20
I recently had to change out a tube because the pump end wouldn't stay locked onto the valve. Nothing wrong with the stem other than time and friction seems to have had its way with it.
genec
Quoted: 13659 Post(s)
Liked 4,532 Times
Lezyne- - -frame pumps and floor pumps. They thread onto the valve stem rather than press fit a rubber grommet. Their top-end floor pump is the best I've ever had. Also the most expensive but I expect it to last for a very very long time
yeah. . .just make sure you carry more C02 cartridges than you need. Carry only one and have two flats. . .. it's pump time. Have I ever had more than one flat on a ride / commute? Yes. Not often, but it can happen. A pump doesn't weigh much and will get you home when you need it.
born again cyclist
^ I always ride with two full cartridges. If I were ever to get more than two flats on my comute, I would be so damn frustrated that I would simply just hail a cab at that point. Just one of the advantages of an urban commute.
Bikes: Cannondale Synapse 4 Carbon Feminine
Max
