D-A Front Derailleur Range ?
Quoted: 206 Post(s)
Liked 102 Times
Can a D-A Front Derailleur (Shimano FD-7410 8-sp) handle a triple chainring? Can't find any solid info on it.
Some days, it's not even worth gnawing through the restraints.
Klaatu..Verata..Necktie?
Quoted: 10499 Post(s)
Liked 12,028 Times
You mean FD7410? It's not designed for triples. I suspect the cage isn't long enough to handle one.
Likes For genejockey:
Quoted: 4722 Post(s)
Liked 3,044 Times
The cage of the FD-7410 was only designed to handle a chainring range of 15T, so it's not really appropriate for a triple, even if it had the cage throw. Shimano's triple compatible, road front derailleurs from this era were the FD-A553 (RX100) and FD-A410 (RSX), which had chainring ranges of 26T and 20T, respectively.
Likes For T-Mar:
Likes For Roger M:
Liked 3,044 Times
Likes For T-Mar:
Extraordinary Magnitude
Quoted: 2609 Post(s)
Liked 1,704 Times
IMG_1728 by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Quoted: 503 Post(s)
Liked 466 Times
I’ve encountered similar problems with recent Shimano triple FD’s (those with that deep squarish inner cage plate like the 7703 shown above) with triple cranks having other than the design ring difference. That inner cage plate hits the middle ring unless the FD is adjusted too high. No such problems with my trusty Campy Racing T FD’s.
Likes For Dfrost:
Quoted: 359 Post(s)
Liked 582 Times
Shimano made a triple FD with a 50T max limit. It works great on compact triples. They used it on the hybrid 10-speed triples in the early 2000’s. I think it’s an FD-730. Identical to the 7703 but the cage is for a smaller diameter set of rings.
Likes For bamboobike4:
Liked 1,704 Times
If anyone wants to pore through my attempts when I built my Trek 720- you can see where I went back and forth using different derailleurs, getting another chainring, TRYING to go back to the DA triple derailleur, failing- going to another derailleur- but *REALLY* wanting a DA derailleur on there... then finding the double 7700 works perfectly...
https://www.bikeforums.net/classic-v...e-rebuild.html
Likes For The Golden Boy:
Quoted: 359 Post(s)
Liked 582 Times
Are you thinking of the CX70? That's the unit that gets used and talked about for road-ish triples.
For a while I thought it was a 7730, but closer inspection indicated FD-730.
Not a 7703, either, but holding the two together reveals little differnce.
There was a sticker on the back that said "50T MAX."
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
