Just hanging out shooting the bull
#101
Bikes: confidential infromation that I don't even share with my wife
Quoted: 35 Post(s)
I do have the proper clothing. I wore a base layer, LS Under Armor heat gear, my team jacket, short sleeve team wind breaker, Pearl Izumi heavy tights, wool socks, shoe covers,Head Sweat fleece skull cap and winter gloves. For hydration I put one bottle in my back pocket and had A 50oz Camelback under the wind breaker with the hose running under my arm. About 1:45 into the ride I changed gloves for a dry pair.
I didn't feel like I had too much on and was never hot or cold, I could have skipped the wind breaker but wore it to keep the Camelback from freezing, a problem I had several times recently. Putting the Camelback under the jacket was too confining and I would have had to leave the zipper down some. As it turned out I needed to hide the head inside the windbreaker as exposing it just 2" was allowing it to freeze.
#102
Version 7.0
Bikes: Too Many
Quoted: 1338 Post(s)
Liked 2,474 Times
Here are a couple of pics from yesterday's 3 hour ride. This is a section of road that has a 3 to 4% grade that provides a nice climb in the red woods with very few cars. The road was wet and very slick on the descent. The descent was not a lot faster than the climb.
Iphone self portrait...
#103
I need speed
Bikes: Giant Propel, Cervelo P2
Does Coach know you are stopping during training rides to take pictures? Tsk tsk....
But then I'm guilty as charged. I saw a Peregrine Falcon hunting Saturday and had to stop and watch.
#104
Version 7.0
Bikes: Too Many
Liked 2,474 Times
BTW, one stops at the top of a climb and coasts down. Therefore, with most climbs, there is a break with no power for several minutes.
In the old days, after a climb, the coast down the mountain resulted in my legs turning to concrete - especially if it was cold. When I tried to pedal, they did not want to move. Today, they respond much better but it still takes some spin before they feel like producing power.
#105
I need speed
I would have been crawling down that hill. I'm a total wuss when it comes to downhill turns, and with water or gravel, I practically stop.
#106
I need speed
Doing pedal technique work using a DVD that coach provided is really starting to help my cadence. I can crank it much faster now without getting bumpy in the saddle, and my normal cadence is up quite a bit. My cadence as I am warming up has become my primary clue to how fresh I am for a ride. When I'm feeling good, the cadence is much higher without having to even think about it. If I'm tired for whatever reason (or if it is really cold), I have to push it up.
#108
Quoted: 35 Post(s)
The wheel set with PT came today. I put tires on the wheels, set up the head (somewhat) and did my 2 hr training ride. It was raining and 34 degrees tonight so I rode on the trainer. I had to do 2 hrs with a 1:35 Z3 interval in the middle. I still have to load the software on the computer and then load my first data.
I've got a lot to learn.
#109
Version 7.0
Bikes: Too Many
Liked 2,474 Times
#110
Quoted: 35 Post(s)
He will once I get the system up and running. I developed my first file but I can't seem to be able to copy and send it to my coach. This is all new and I'll need to learn some new things about computers, files and data. I believe there are online places to send the files that I'll need to research.
#111
Version 7.0
Bikes: Too Many
Liked 2,474 Times
To use the software and power training, you will have to determine your functional threshold power. This can be done by doing an FTP test or by a couple of other means. If you have Training and Racing with a Power Meter, they discuss how to do it. FTP is a very tough standard and is the power one can produce at a constant rate for one hour. If you want to enter a somewhat arbitrary number, I would suggest 240 to 260 watts. If you determine it is higher or lower than you can adjust it. It is better to err on the lower side otherwise your workout will be too hard. 300 watts is a lot of power and 10 watts is a big increment. Have fun!
#112
Quoted: 35 Post(s)
Hermes, I will have to determine how to store and relay the info. What is WKO?, another software other than the software supplied by the PT manufacturer.
I will discuss with my coach the method he wants me to determine the FTP. For last night's 2:03 workout I averaged 226 watts and for the 1:35 hr Z3 interval I averaged over 243 watts. For a 1 hour test I know that the number would be higher but I have know idea how much since I was in mid to upper Z3 during the interval. My HR did climb to around 150 during the last 15- 20 minutes as I was trying to keep the same cadence throughout the interval.
Like I've stated this old boy has some learning to do.
#113
Version 7.0
Bikes: Too Many
Liked 2,474 Times
When you load the WKO software, you will input an FTP and weight. You will upload data from your PT into WKO. You can select the power zones you want based upon your favorite guy - Coggan, Friel and etc. I use Coggan.
#114
I need speed
Hermes - So it's worthwhile to use both WKO+ and TrainingPeaks? From searching the Watts list, it's clear WKO+ provides things Trainingpeaks doesn't, like quadrant analysis. I had already subscribed to TP when I got my coach, or I could have been on her Pro account. Instead, I used the feature where you provide your coach access to your own account. I upload my Garmin data with the TP "Device Agent", and it automatically goes into the planned workout based on date and time, so you see planned vs. actual, etc. I didn't realize WKO+ linked into TP; that sounds pretty slick.
#115
Version 7.0
Bikes: Too Many
Liked 2,474 Times
The interesting feature of the WKO are the two boxes for athlete comments. One is for the goal and the other is about the ride. I fill in the goal which TP sends me. For example... 2 hour ride with 4x10 z4. In the comment box, I summarize the four efforts. I then provide a qualitative assessment of how I felt during the efforts by using a matrix designed by him.
When I upload the data to TP, it generates an email to him showing key metrics and my comments. So he gets that long before he sits down at the computer and logs into TP. I have a complete one season data set on my hard drive of workouts, results and impressions plus races.
My wife does this as well and she is into the TP diet program and is logging everything she eats along with body metrics such as BP, HR, sleep and etc.
If you have any inclination toward this type of data keeping and manipulation, I recommend getting your head into the guts of power training and wko. I think it is fun and you will learn a lot that IMO will help your cycling.
#116
Version 7.0
Bikes: Too Many
Liked 2,474 Times
I got on the trainer over lunch and the maids showed up early. i had to get off and quickly clean up. I ended up with 15 and 10 instead of 3x15. I will make up for it tomorrow.
#117
Version 7.0
Bikes: Too Many
Liked 2,474 Times
ATR, Looking over my web based Training Peaks account and tools, it does not have most of the key tools in WKO. It is missing the mean maximal power computations, power distribution graphing and the performance manager based upon TSS. https://www.peaksware.com/articles/cy...ent-chart.aspx And there is no user graph showing actual power, HR, elevation, cadence and etc versus time.
If you are doing HR training, there is no training stress score associated with it. To get a proxy of a TSS, one would have to assign a level of effort to the duration of the HR and then multiply the two together to get some type of score. WKO does all this for you and uses power. So if you are averaging 200 watts for 30 minutes, WKO will calculate a training stress score. The base line score is riding one hour at threshold power. That will equal a score of 100. Since the FTP used in unique for the rider, two riders can score 100 but be a completely different levels of fitness. Contador's TSS of 100 will have an FTP associated with it of maybe 450 watts while a Cat 3's 100 TSS may have 300 watts. Both riders score the same and the training load will be the same for each rider.
For example, if I go on a fast 3 hour group ride, I will have a TSS of 175. But I will not have a lot of time in z4. It will be mostly z1/z2 sitting in, with some z3 and z4 and some huge z5/z6 efforts for me. The huge z5 and z6 count more toward a higher TSS than the same time in z3/z4. So even though a lot of the time, I am not working very hard, the tough efforts drive up the TSS and make me very tired and sore.
I really like the graphs and data presentation in WKO. I like the mean maximal power curve for the day and the 28 day rolling average it provides in the summary. The mean maximal power curve is a compilation of your best efforts on the ride. So when you mouse over the curve, you get the power. So I mouse over the 3 minute time and it displays my best power for the day. I can do that for any time. So if I am doing z5 intervals, the mean maximal power curve will have a discontinuity at 5 minutes and show the best average power for all the intervals I did for the day. On the summary page, I can change the rolling 28 days and look at an entire season. The shape of the mean maximal power curve is indicative of the type of racer i.e. sprinter, TT, climber and etc.
If you have that in the web based training peaks account, and are only missing quadrant analysis then that is great. My web based TP does not.
#118
I need speed
I downloaded WKO last night so I could get familiar with it and be ready when the Quarq arrives. I loaded all my data in, some as a download from my TP account, but most of it directly from my Garmin, which still has everything it has ever recorded (got it last September). I could only download a week at a time from TP, but could load everything at once directly from the Garmin. Loading from TP includes my diary entries, while loading from the device obviously doesn't. But I suspect my 'diarying' will still be done in TP. So my workflow will likely be to load into TP the way I always have, then download from there to WKO. Maybe it will work the other way, which is what it sounds like you do? Entering everything using WKO, then communicating that to your coach via TP? I haven't seen where that is possible for me, but I'm just starting to find my way with the software.
I do have performance manager in TP. It calculates TSS using TRIMP heart rate methodology, so I can see my trends in CTL, ATL, and TSB. I don't get the Intensity Factor WKO provides, but I'm not seeing that in WKO either right now, probably because it will only do it using power, rather than HR. I'll play with WKO some more tonight.
I think the big challenge for me will be to not get TOO caught up in the data; to remember it's all about the riding.
Speaking of which, this morning I did hill repeats on the way to work. 1-2 minutes in a higher gear, at 60-70 cadence. I did them on every hill enroute, and 4 extra repeats on a hill just off my route. Total of ~8 reps. After yesterday's trainer session, with 45 minutes in z3 at a moderate cadence, my legs definitely feel worked today.
Tomorrow is recovery day, and only 50 miles Saturday, as she wants me rested heading into her vist the following the weekend.
#119
I need speed
Today's ride just, well... sucked. I was in a bad mood, for the first time in forever, and thought the 50 miler would cure that. Instead, I faced bad air (hard to hold your breath and pedal!), bad pavement, and a run of red lights on the way back that was not to be believed. The light would change as I approached, and I'd have to ask myself.. "Really!?!?!" Was low on sleep to top it off, so I had to keep telling myself to get the cadence and HR up where they belonged.
Oh well, enough whining.
No, wait, one more whine...
I WANT MY POWER METER TO ARRIVE!!!!!!
Okay, there, I'm done.
#120
Quoted: 35 Post(s)
I was supposed to ride 2.5 hours high cadence today on the XC or mtb. It was 14 degrees with snow and ice on the side of the roads so I took the mtb intending to hit some trail along the way. The snow was too deep to ride the trail so I just stayed on roadways. I cheated and only rode for 2hr and 20 minutes.
#121
Quoted: 8 Post(s)
Liked 10 Times
Hey all you racing guys - check out these two flicks if you want a good laugh. Kinda reminds me of the vids AJet was making. I didn't make 'em, I just stumbled across 'em while surfing.
Be warned...these are XXX rated so if you have sensitive ears or are under 18 do not click on the link. They are sequential, so watch them in order.
#1 : https://www.xtranormal.com/watch/6694173/
#2 : https://www.xtranormal.com/watch/6705475/
#122
Quoted: 35 Post(s)
#125
Version 7.0
Bikes: Too Many
Liked 2,474 Times
My maids are downstairs maids, not upstairs.
