Go Back  Bike Forums > Bike Forums > Training & Nutrition
Disable Edge 530 erg mode?
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 09-27-23, 08:45 AM
force10
Quoted: 123 Post(s)
Liked 54 Times in 44 Posts
I use a coach who creates workouts on Training Peaks which I ride on Zwift while indoors. I record the workout on my Edge 530 and run the workout there simultaneously. I specifically do not run in erg mode on Zwift so that I can control my power with cadence and gear changes.
Yesterday, my tacx neo trainer lost connection to Zwift mid workout and after several minutes I just turned off Zwift to follow the workout on hte head unit (I was in the vo2 interval portion of the workout and wasnt paying attention to the screen anyway.) After doing so, the 530 started controlling the resistance - raising it to the point that I couldnt maintain a cadence high enough to stay in the power range.
I was able to go to the trainer settings menu (on the 530) and disable the resistance by selecting "free ride", but it would re-set each time an interval concluded and a new lap started. Fumbling through the menus with a racing heart and sweaty fingers had an adverse impact on the workout.
My primary question is whether I can disable the default to erg mode by the Edge 530? I am also curious whether the lost connection between the trainer and Zwift has any bearing on the issue. Last, judging by the icons on the 530, it appears that the trainer can be connected to the head unit as either an indoor trainer or as separate power and speed/cadence sensors - does this affect the erg mode?
force10 is offline
Old 09-27-23, 04:53 PM
kcjc
Quoted: 90 Post(s)
Liked 47 Times in 34 Posts
You need to pair just to the power not the trainer, either Ant+ or Bluetooth Smart power. On mine, the Ant+ power symbol looks like a dumbbell. I don't use Bluetooth or Neo (Drivo and H2) and looks like there isn't a separate icon for Bluetooth, https://support.garmin.com/en-US/?fa...RnAFS0uVaZatb9. Maybe it's in the name?
kcjc is offline
Likes For kcjc:
Old 10-02-23, 04:16 AM
PeteHski
PeteHski's Avatar
Quoted: 4416 Post(s)
Liked 4,872 Times in 3,016 Posts
Is there any reason why you are recording simultaneously on your Edge 530? I just record workouts in Zwift and automatically export data to Garmin, Strava, TP etc.
PeteHski is offline
Old 10-02-23, 04:24 AM
PeteHski
PeteHski's Avatar
Yes it does. If you connect as an indoor trainer then your Garmin can control the trainer resistance and operate in erg mode. If you connect as a separate power sensor then your Garmin will not control trainer resistance. Which will solve your issue with Garmin taking over erg control, but you won’t be able to manually adjust trainer resistance via your Garmin.
PeteHski is offline
Old 10-02-23, 09:27 AM
force10
Quoted: 123 Post(s)
The Garmin records some metrics (pedal stroke, L/R %) that Zwift does not. I also frequently prefer to have an array of screens that show data differently than Zwift. I export the Zwift file to Strava and Garmin file to Connect and TP. Some of it is probably habit more than anything.
force10 is offline
Old 10-02-23, 09:36 AM
force10
Quoted: 123 Post(s)
Thanks to you both. That is what I thought. And I believe that I only have the trainer connected to the garmin as power and speed/cadence sensors. This is belied by my experience with the garmin taking over resistance once Zwift was turned off. But when I go to the sensor menu, I do not see any option to unpair the trainer. I only se that I have it connected as power (dumbell icon), and speed/cadence (speedometer and crankset icons). The trainer icon (kind of like a hweel-on trainer icon) appears as available across the top screen when I boot up the head unit but does not show thqat it is connected in the sensor menu. Maybe a call to Garmin is in order.
force10 is offline
Old 10-04-23, 09:55 AM
PeteHski
PeteHski's Avatar
It was a while ago, but I had a similar thing happen with my Edge 530. I vaguely seem to remember a pop up message on my Garmin asking if I wanted to connect as a Trainer. But I could be wrong.
I would try unpairing your trainer power and cadence sensors and then start again and see what happens. You might get the same pop up message I did, unless I just dreamt that part, 😂. If it does ask you if you want to pair as a trainer, then just say no.
PeteHski is offline
Old 10-04-23, 10:28 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
Has this only happened once? Try it again. From your op it sounds like you successfully did this many times before.
Iride01 is offline
Old 10-04-23, 04:56 PM
force10
Quoted: 123 Post(s)
I had the same recollection and did as you suggest. Unpairing and re-pairing went fine but the pop up never reappeared. I think there must be some separate way to disable the trainer part.
force10 is offline
Old 10-04-23, 05:03 PM
force10
Quoted: 123 Post(s)
It is the only time that the 530 has taken over resistance. But normally I am running the workout on Zwift also and it “overrides” any trainer control, I guess. This time I lost connection and shut it off, and the issue arose. I suspect you are correct that it would not occur if the Zwift connection is maintained but would like to have it sussed out as the weather cools and indoor riding becomes more frequent.
force10 is offline
Old 10-04-23, 05:23 PM
Iride01
Iride01's Avatar
Yeah, I'd be no help there. I don't use a smart trainer. I'd just hate for this to be a one time thing and then you believe the first thing you did solved it. I don't see anything wrong with starting the thread to ask for the thoughts of others. I was just curious as I occasionally have one time things happen with my Edge 530 that happen once and only once. Sometimes it seems to be the ride after a update. But not always and not frequently.
Iride01 is offline
Old 10-19-23, 08:54 AM
force10
Quoted: 123 Post(s)
Resolution
In case anybody else is ever trying to figure this out, the connection as an indoor trainer is separate from the other sensors like power/speed/cadence etc and unpairing is done in a different place. To unpair as a trainer, go to Menu-->Training-->Indoor Trainer and you can remove/add the trainer there.
force10 is offline
Likes For force10:
Old 10-19-23, 11:14 AM
PeteHski
PeteHski's Avatar
That’s good to know thanks. Out of curiosity if you pair initially as a power source, does it ask you if you would like to also pair as a trainer? I’m just wondering what triggers that pop up.
PeteHski is offline
Old 10-19-23, 04:17 PM
force10
Quoted: 123 Post(s)
There was no pop up this time when paired the power/cadence sensors. I recall that pop up from before but don’t know what prompts it. It may not have popped up this time because I had just unpaired the trainer??
force10 is offline
Old 10-22-23, 07:20 PM
force10
Quoted: 123 Post(s)
The invitation to set-up as a trainer pops up when you first go to do an indoor ride.
force10 is offline
Old 10-23-23, 06:09 AM
PeteHski
PeteHski's Avatar
Mystery solved! I was honestly starting to believe I had dreamt this pop up!
PeteHski is offline
Likes For PeteHski:
