Lemond Alpe D" Huez 2002" ish" seat post clamp ring size
Quoted: 211 Post(s)
Liked 199 Times
Just picked up an early 2000 Lemond.
Want to replace with black ring, like it came with.
Not this ( pictured).......horrible
Quoted: 332 Post(s)
Liked 743 Times
Should be readily available, just measure the outer diameter of the frame where the clamp slides on. Get Thomson if you want to spend $$$, otherwise Dimension is a decent looking cheap option. There are plenty to choose from though.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
the seat post is 27.2mm... the seat tube's outer diameter is most likely 30.7mm or so... there are dozens of designs available thru amazon and ebay, and any number of other outlets...
do your own shopping.
