I finally finished my 1946 Holdsworth Cyclone
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 139 Post(s)
Liked 1,432 Times
I just finished the final assembly of my 1946 Holdsworth project. I've been working on it for about 6 months! This is a vanity bike, made the same year I was born. A stupid amount of work, I made or totally rebuilt almost every component. The parts are not perfecly period correct, but I want this bike to work. It does! More photos later. Jim Merz
Likes For Portlandjim:
1989Pre, Aardwolf, bargo68, bboy314, BTinNYC, bulgie, cegerer, cinelliguy, cycleheimer, daverup, delbiker1, djkashuba, dphi, droppedandlost, ehcoplex, IdahoBrett, JoeBass, John E, Kekec1965, Kilroy1988, machinist42, Mad Honk, merziac, mpetry912, mtbikerjohn, Nemosengineer, non-fixie, northbend, PilotFishBob, Pompiere, qcpmsame, retroman57, roadcrankr, Robvolz, Sactown_Albert, sced, Small cog, squirtdad, steelbikeguy, SurferRosa, SwimmerMike, thinktubes, tiger1964, tjfastback66, USAZorro, zookster
Quoted: 3464 Post(s)
Liked 2,831 Times
Nice Sprints.
did you exchange the top portion of the rear mech to have the double spring?
Steel stem and post very much are visually in keeping with the period.
Quoted: 981 Post(s)
Liked 1,844 Times
Bravo, sir! It looks exceedingly functional with a relatively period-correct look overall. You've achieved a commendable balance between form and function. The photo is saved to my Holdsworth files for future reference!
-Gregory
-Gregory
Likes For Kilroy1988:
Quoted: 139 Post(s)
Liked 1,432 Times
No double spring on the Gan Sport rear derailleur. I did modify it though. For riding the longer courses in Eroica and avoiding walking, I found that I need a low gear using a 27t rear and a 36t front. I can get this to work with a late version Super Record rear derailleur if the high gear cogs are 14t and 47t. This bike has a Gran Sport rear from the early 1950's, and will not handle this range of gear stock. I modified a SR pully cage to fit on the GS. I had to use a Record spring stop, and I had to modify the upper pivot limit stop. The derailleur angles forward instead of being almost vertical. I also included a pair of my modified Enduro pulleys. The result is it shifts all the gears nicely. The front derailleur is a Cyclo Benlux rod shifter. It was used, I made new parts to reduce all the slop. This works very well also. The stem is a period correct GB Kromo, it's excellent. Bars are aluminum GB. The seat post is period correct, an aluminum Titan. The pedals are period correct Holdworth Allez, very rare. They were hardly used. The clip headset is also a Holdworth Allez item, it came with the frame. The original bearing design, Chater Lea intigrated races, really doesn't work very well. I modifed the lugs to accecpt modern sealed drop in 1" bearings. I remade all the headset parts, they look just like the original but work much better. The crank arms are Chater Lea, with double chainrings made by me with Holdworth Allez design. The saddle is a 1950's B17 that has been modifed for use by a pro racer back in the day. The hubs are Airlite, made by me. The QR's are original Airlite period correct. Brakes are Ballila side pull, Holdworth used brakes from this Italian company starting before WWII. I made amost all the hardware for them. This frame was originally made for use with tubular wheels! I used a pair of 1950's Weinmann rims.Jim
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1087 Post(s)
Liked 1,825 Times
Being a proper British bike, you routed the brake cables for British roads. like it.
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Beautifully executed bike, well done sir on all of your handwork and building the Holdsworth for use. Best of luck on the Eroicas you undertake.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Quoted: 939 Post(s)
Liked 2,961 Times
That's a damn handsome build, Jim. Bravo!
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 934 Times
Lovely.
There is something to be said for the absence of 'patina', otherwise known as 'wear and tear'.
Congratulations!
Congratulations!
Likes For Fredo76:
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Beautiful. Just beautiful.
Likes For bikingshearer:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Very nice, but we do need more pictures
Looks like the paintwork is rather special too.
Likes For Aardwolf:
Edumacator
Quoted: 2444 Post(s)
Liked 3,142 Times
How the heck do you machine all of those different parts?!?! The head lugs look super cool.
Did you paint or send that out for paint. The lug lining and pinstripe work looks awesome!
Stunning little bike.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
The gold lug-lining tops it all off really well. Although later, the Benelux rod is a great addition. It is interesting that it negotiates a jump from 47T to 36T.
Were the brake-lever hoods hard to make?
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Last edited by 1989Pre; 12-19-23 at 05:39 AM. Reason: Cyclo rod-operated f.d. offered in 1953?
Likes For 1989Pre:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
Your customized rear derailleur is giving me ideas for one of the Capo Siegers. I really like what you have done. You are right about your front derailleur being rare -- I have seen only one other, at the Cunninghams' old CyclArt shop in Vista CA.
Likes For John E:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
That's quite nice, sir.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2199 Post(s)
Liked 4,619 Times
Shall we be seeing you in Gaiole next year?
Likes For non-fixie:
Quoted: 139 Post(s)
Liked 1,432 Times
I chose some parts that are a bit later than the frame build date, but only if they offered a way to allow the functionality I needed. Many riders back in those days changed parts as superior versions became available, the parts I added aren't out of the question. The Benilux front derailleur I used has a cage design very similar to Campagnolo GS/NR/SR. The key to having it work with a 36 inner chainring is the tooth count jump. 11 teeth is what I found to be the limit for acceptable front shifting with the Campagnolo front derailleurs, it was also true with the Benilux I have. So, the big ring is only 47 teeth. This makes a rather low high gear, but I'm old and can't average 25 MPH these days! The brake levers were NOS and came with the hoods. Balilla brakes, which were the first aluminum brakes offered for sale, were listed in the Holdworth catalogs even before WWII. The model I got are for sure newer, but the design of the calipers are very similar to the early version side pull. The design of the caliper is very similar to Campagnolo Record, with a quick release that works slightly differently. I wanted a side pull brake with a QR and these fit the bill. However, the construction details were hideous. Pivot holes that were punched, bores pointing off in random directions. Pivot shafts with diameters that had no relation to the bores they rode in. So, I made all the hardware using bronze bushes for pivots. Everything optimized for correct clearance. Weeks worth of work for just the brakes! It turns out that the lever cable pull ratio was really poor, the brakes felt solid but required superman's hands to stop. I am pretty sure Tuillo looked at these brakes when he was designing his Record brake. The lever blade on the Ballila is very similar to the Record blade, but has a much better pivot position. With much work I modified the lever bodies to allow Record blades to be installed. I stripped the anodize off, filed the Campy name off and polished the blades. I have yet to ride them, but the cable pull ratio is much better now. Campy Record brakes require a lot of muscle to stop, but the way the Ballila levers were before was much worse.
Quoted: 139 Post(s)
Liked 1,432 Times
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
Likes For AdventureManCO:
Liked 2,531 Times
Shifting is fun!
Bikes: Yes, please.
Liked 4,619 Times
It would! Think of the audience you'd have there ...
Anyway, I'd have loved to see it in the metal. Did I say it's beautiful?
Standard Member
Liked 940 Times
They do go for a bit of cake.., when available. Jim has the early cage, too. His says Cyclo-Made in England. The later ones just say Benelux in larger font. The earlier ones are panto-graphed, where-as the later ones just have the name stamped in. These mechs are enjoyable and reliable. They give a very sure shift (for those of us fatigued or just clumsy-at-times).., and, speaking of clumsy, one needn't worry about his finger(s) bouncing off his spokes during an attempted f.d. shift.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
What a beauty. And those fork blades. so graceful.
many very nice details
/markp
/markp
Quoted: 175 Post(s)
Liked 452 Times
Outstanding and handsome. I'm all for relaxing the period this and that. That headstock work is beautiful and appropriate!
PS. Dig the pinstripes including the ones circled the stays.
