Carbon forks..1 1/8" to 1 1/4" scarce?
Ok, so my "forever" titanium bike has a tapered carbon fork, 1 1/8" to 1 1/4". I understand it''ll accept a straight 1 1/8" as well. So if one day this plastique fork @SSPlodes after hitting a big pot hole, what are my options for replacement with another tapered fork? I've looked online and have found nothing in the 1/4" taper like the fork I have. According to specs, the fork has room to fit a 48mm tire. I'm using 42mm right now, and I'd like to continue to use 42". Anyone? Anyone?
Bikes: old clunker
Quoted: 684 Post(s)
Liked 104 Times
The problem with future availability is that it's still in the future. Will you buy a new fork if you find it today? If not, then what are you playing at?
Maybe get a new fork from the same source as the one you have. (Shoppin' ain' easy!)
If I cracked the fork today, I don't think I could find an aftermarket equivalent...I've looked! The future? Maybe I'll be able to go to a "Print-your-Own" kiosk and print one out. Right now, the only place I know I could get one is from the the manufacturer.
Do you need any other information?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
You gave less than half the check-items needed to spec the fork. What brake type? What brake mounting? What trail? What axle-crown? What price? rack/fender mounts?
Bikes: old clunker
Quoted: 684 Post(s)
Liked 104 Times
Well, if that's all that's holding you back, then....I might buy, depending on price. Let me know when you find something in 1 1/4" tapered. Preferably unpainted. Oh, and it ought to be thru-axle. Gotta be able to fit at least a 42 mm wheel. No slave-labor factories either.
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 63 Post(s)
Liked 28 Times
This one comes with a straight 1 1/8 steerer, which you mentioned your frame can accept. You'd also have to get a flat mount caliper or adapter though.
This one comes with a straight 1 1/8 steerer, which you mentioneI apd your frame can accept. You'd also have to get a flat mount caliper or adapter though.
Why would a manufacturer make a bike in 2016 with such a rare spec?? There are 1 1/2" tapers out the wazoo online.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Giant make some models with that 1 1/8 to 1 1/4 taper a few years back. Here's an option I found just now one eBay: https://www.ebay.com/i/352406611389?chn=ps
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 735 Times
I would be worried about replacing pedals, bottom brackets, wheels, cranks, derailleurs, headsets, shifters and saddle before I worried about the fork.
-Tim-
-Tim-
Quoted: 685 Post(s)
Liked 55 Times
Thanks guys, those forks are close in spec to what I have and might be a suitable replacement. An update...I called Salsa to see whether they have replacements available forks for my 2016 Vaya, to see if they make them available for sale. The 2017 and 2018 Vayas use the same carbon fork. Surprisingly, the answer is no!
Lol, well right now there's not one replacement fork available that matches the specs of my Vaya's fork. You think it's going to get easier to find a replacement? I doubt it. Salsa chose a standard (1 1/8 to 1 1/4 taper) that's gone the way of the Dodo bird.
Quoted: 685 Post(s)
Liked 55 Times
Salsa did that? I thought only Giant had done that. Yeah, I don't see the 1 1/4 taper making a comeback. A straight 1 1/8 fork is probably the solution, if it ever comes to needing a replacement. I don't suppose there's any sort of headset solution that would allow a 1 1/2 taper to work, is there?
Quoted: 63 Post(s)
Liked 28 Times
My GT Grade had a 1 1/4 taper and Cannondale uses 1 1/4 taper in the Topstone. They also have 3 different size-specific steerers on the carbon Synapse
Tire clearance is not ideal, but this Whiskey fork looks to use a 1 1/4 tapered steerer as well: No. 9 RD Fork
trends come and go, then stay gone .. Race type Bike biz is now subject to that .. at the avant garde end .. things keep changing..
- Soli Deo Gloria -
Liked 735 Times
Consumables are a given. I suppose bottom brackets and headsets are consumables.
Either way, I'd worry about the saddle breaking before the fork.
Are you considering buying a spare fork? I'm a melancholic and having a closet full of spares makes me very happy but not sure I would go that far.
-Tim-
-Tim-
-Tim-
-Tim-
